How many CAB-RPS2300-E is included with PWR-RPS2300?
WeiKwongOng5555
Hi, when we order 1 unit of PWR-RPS2300 for Catalyst 2960X switch, how many CAB-RPS2300-E comes with the RPS?
Reza Sharifi
1 RPS cable.
From the datasheet:
Ordering Information
●   A typical Cisco RPS 2300 order includes the following:
    Cisco RPS 2300 (PWR-RPS2300)
    1 RPS cable. Users may order either the CAB-RPS2300-E= compatible with Cisco Catalyst 3750E/3560E, 3750v2/3560v2, and 2960/2960S/2960P/2960X Series Switches or the CAB-RPS2300= compatible with all other network devices.
    At least 1 power supply, either a C3K-PWR-1150WAC that can back up 48 ports of Class 3 (15.4W) PoE or a C3K-PWR-750WAC that can back up 24 ports of Class 3 15.4W) PoE or 48 ports of Class 2 (7W) PoE. One power cable is included for every power supply ordered. There will be an additional charge for the power supplies, as they are not included in the base price of the RPS 2300.
    1 fan module (BLWR-RPS2300=)
    1 power supply bay insert (BLNK-RPS2300=) to block a power supply bay for effective cooling in the Cisco RPS 2300. Note: This insert will only be provided when ordering an RPS 2300 with just one power supply. It will need to be ordered as a spare while ordering an RPS 2300 with two power supplies.
    1 Cisco RPS 2300 accessory kit (ACC-RPS2300=)
link to the datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-system-2300/product_data_sheet0900aecd805bbef6.html
Hi @Reza Sharifi, thank you for your response.
So does it mean we must order the fan module BLWR-RPS2300= and rack mount bracket ACC-RPS2300=?
And we have to order more CAB-RPS2300-E= cables if the RPS2300 to support more Catalyst 2960X switches, right?
No, the RPS comes with BLWR-RPS2300= and should also come with rack mount brackets.
Yes, you need one cable per switch.
Hi Reza,
Im quite confuse on the RPS2300 datasheet. Do it really need to order spare BLANK-RPS2300 if the RPS2300 has a two power supply?
