09-13-2017 04:00 PM - edited 03-08-2019 12:01 PM
Hi. I've searched online and looked at my CCNA book. I can't seem to find how many trunks can be created on Cisco 2960G switch.
I logged into 2960 switch, and ran "switch#sh int trunk" and output indicates for port Fa0/17 is
1-4094? My switch has 48 ports, and I would like to know how many trunks can be created?
Thanks for your time..
Solved! Go to Solution.
09-13-2017 05:27 PM
09-13-2017 05:27 PM
09-13-2017 06:50 PM
09-13-2017 07:14 PM - edited 09-13-2017 07:22 PM
As mentioned Franscesco, It depends of the amount of ports (port density) you have on the switch, for example if your switch has 24 ports + 2 SFP ports (if it has) you can create 26 trunks. If you have a switch with 48 ports + X number of SFP ports, you can have 48 trunks + X trunks related to the SFP ports.
Hope it is useful
