N7K - defaulting an interface causes the module to reset
pokwan
Has anyone experienced the problem where a default interface command causes the module to reset?
For instance
default int e1/10 - 11
The command above resets module 1.
We are using version 6.2(16).
TIA
PF
Reza Sharifi
I have never seen that.  You may want to upgrade to a newer version (7.x) and test again.  If not you may have to RMA the module back to Cisco.
Thanks Reza,  this is the error messages on the log
2017 Sep 14 10:51:08.546 TP-H7-CSW-01 %SYSMGR-SLOT1-2-SERVICE_CRASHED: Service "aclqos" (PID 2376) hasn't caught signal 11 (core will be saved).
2017 Sep 14 10:51:12.681 TP-H7-CSW-01 %SYSMGR-SLOT1-2-SERVICE_CRASHED: Service "aclqos" (PID 29925) hasn't caught signal 11 (core will be saved).
2017 Sep 14 10:51:16.904 TP-H7-CSW-01 %SYSMGR-SLOT1-2-SERVICE_CRASHED: Service "aclqos" (PID 29982) hasn't caught signal 11 (core will be saved).
Thanks.
PF
