How many VRF-Lite Routing Instances can a 6509-E with a 720-Sup module run?
pciaccio
Level 4
Level 4
I know that in a 4500 style switch it supports a maximum of 64 VRF-lite routing instances. However what is the maximum amount of VRF-Lite routing instances can a 6509-E switch support with a Sup-720 sup module?
Reza Sharifi
Sup 720  supports 1024 VRF Lites
see table-1 in this link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a0080159856.html
Reza Sharifi
Thank you . I had a feeling that it supported that many VRF's but I could not find any actual documentation on it.   Thanks...
