How to add additional switch to a stack
bluesea2010
Level 7
Level 7
Hi ,
How to add additional switch to a stack (3850 switch ) .Does it require downtime .
Reza Sharifi
No, it doesn't require downtime. Just make sure the new switch is turned off before you connect the stack cable to the existing switches.
Follow this link to add a switch to your stack:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#stack3
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/ha_stack_manager/configuration_guide/b_hastck_3se_3850_cg/b_hastck_3se_3850_cg_chapter_010.html#task_1177470
