How to add Default Route in Nexus switch
amitga001
Hi ,
I am very new for nexus switches now i have to put default route towards one of my firewall to get the internet access can anybody help to know what exactly the commands i need to put into the switch.
It;s really urgent...
Thanks in Advance.
8 Replies 8
Mark Malone
Its the same as a router/switch basically just use the / 10.1.1.1 being your next-hop or you can set your interface Instead
ip route 0.0.0.0/0 10.1.1.1
Ohh really but i was reading some blog where its mentioned that we need to put below command:
vrf context management ip route 0.0.0.0/0 10.2.1.1
What it means
That's for your management vrf interface the purpose of that default route is to manage the switches remotely , is the nexus 5k or 7k ? if its 5k its vrf default as it will be most likely l2 but if its l3 7k you can use whats a default vrf route as well as there isolated from each other
depends on your overall setup just try both 1 should work for you
Example my default in mgmt. setup on 7k
  ip route 0.0.0.0/0 172.21.9.254
interface mgmt0
  vrf member management
  ip address 172.21.9.7/24
standard default
ip route 0.0.0.0/0 192.168.10.254
My device is 6k and use as a L3 device.
service dhcp
ip dhcp relay
vrf context KEEPALIVE
vpc domain 10
  peer-switch
  role priority 1000
  system-priority 4000
  peer-keepalive destination 1.1.1.1 source 2.2.2.2 vrf KEEPALIVE
  delay restore 60
  peer-gateway
  ip arp synchronize
Then you will be able to have a mgmt. vrf default route and a standard default route if needed as they will be isolated by the vrf
Thanks that will be very helpful.
Much appreciated
ok one more question still i need to run only ip route 0.0.0.0/0 10.1.1.1 this command right??
