Avoiding HSRP Active/Active
lyonsp001
I have a branch office with 2x 3560s connected to the main office via separate L2 links. The 3560s are connected via these links to 2x 6509 routers with L3 SVIs acting as the gateway for clients in the branch office. I am running HSRP between the 2 6509s for redundancy and all is well once the 2x links are up.
If a single link goes down, the 2 routers can't pass HSRP control traffic to each other as they are not connected at L2 anymore. They both assume the active state and I end up with 2x gateway addresses. This renders certain parts of the network unreachable.
This configuration is in place in other parts of the network too, but there must be a better way. Bar adding an L2 link at the core, is there any way I can achieve redundancy?
Thanks for reading.
7 Replies 7
Jon Marshall
Is each 3560 connected to both 6500s ?
If so HSRP should flow via the 3560s.
If they aren't then you need a L2 link between the 6500s which I appreciate you don't want.
There must be a L2 path somewhere for HSRP to work.
Jon
Thanks Jon.
No, each is connected to just one 6509 and I can't add any more because of limited ports on the provider equipment.
I thought as much. Funny thing is, this config is all over our access layer. Am I looking at manually shutting down the SVIs when a link dies?! Can I track something or have a HSRP node automatically assume standby if it can't see its peer?
Apologies, the 2x 3560s are indeed connected to each other. Well-spotted.
I'm glad they are otherwise I was totally confused :-)
The thing that still confuses me is if a link dies and both 6500s go active for HSRP then traffic from the 3560s can still only go to one of the 6500s so it should still work.
Yes you have the annoyance of the other switch being active but it shouldn't stop traffic flow from the 3560s.
If the SVI is staying up then a possible issue is that the 6500 is still advertising the IP subnet to other parts of your network so traffic could come to it and then it cannot forward it which sounds like what is happening.
However that shouldn't happen if the only port on the 6500 in that vlan (or vlans) for  the access switches is the one connecting to the 3560 because if the link goes down then the SVI should as well.
So what is keeping the SVI up/up is the question ?
Are the vlans used on the 3560s used anywhere else in your network ?
Jon
You've got it exactly there. The SVI stays up because the direct physical connection from the 6509 is to a piece of provider kit which in turn connects to the WAN link. So even if the WAN link is down, the gigabit ethernet int on the router stays up, keeping the SVI up.
Return traffic from the main office thinks the branch network is available through the 6509 connected to the dead link and, as you said, the traffic has nowhere to go.
The vlans are not used anywhere else.
Any ideas? Thanks for your help and insight so far.
Even if you could make it go standby it would still advertise that IP subnet to the rest of your network.
You need to shut the SVI down but this could prove somewhat problematic because there is no L3 hop between the SVIs for the same vlan on each 6500.
So if you could guarantee the path a ping from one SVI to the other SVI was via the 3560s you run an EEM applet and if the ping failed it would shut the SVI.
But I suspect the ping could work via the rest of the network as well.
Even if the 3560s had management IPs that you could ping I suspect you woud be advertising these to the rest of your network so there would be an alternate path for the 6500 with the failed link.
A possible solution is if the vlans on the 3560s are only used in the branch is to move the SVIs to the 3560s as they are interconnected anyway.
Then make the links between the 3560s and the 6500s L3 links and each 3560 would advertise the vlan IP subnets.
If the link fails then the 6500 no longer receives the advertisement and so doesn't advertise it to the rest of the network.
You could use a default route on each 3560 to keep the routing tables to a minimum.
However that is a big change especially as you mention you have this configuration on a lot of access switches.
I suppose the really obvious solution is the one you don't want :-) ie .interconnect your 6500s.
Can't help feeling I am missing something more obvious so perhaps others will join in and if I think of a better way i'll add to this post.
Edited -  removed first solution as there is no next hop IP for the loopback route.
Jon
Jon Marshall
Sorry on rereading your post I am not understanding this.
If each 3560 is only connected to one 6500 switch then there is no L2 path anyway.
If each 3560 is connected to both 6500s then a single link failure should not mean the loss of a L2 path between the 6500s.
Are the 3560s connected to each other ?
Can you clarify.
Jon
