How to add Vlan 4030 in cisco 2960 Series switch
Bikas Giri
I have got a WS-C2960S-48TD-L catalyst switch and cisco 1841 router. I want to create a Vlan 4030 and 4035 in a switch and send it  to cisco 1841. I got a 4030 and 4035 vlan id from my isp. The isp send the vlan 4030 and 4035 tag from the router. Now I want to create this vlan, trunk the same vlan to a switch port and resend it as a trunk to cisco router 1841 so that I can create 2 sub-interface with dot1q. I am being unable to create the vlan id 4030 and 4035. I have done as below but can't see the vlan through show vlan althouth it says it is creating vlan id 4030 and 4035 when configuring it as trunk. So, please verify the following code and write me a process of it one by one.
ISP port (link from the ISP router to my managable switch)
int fa0/30
switchport trunk allowed vlan 4030, 4035
switchport mode trunk
My side port (Link to my cisco 1841 from my managable switch)
int fa0/31
Router Port (My router interface)
interface FastEthernet0/1
description *****CONNECTED TO FIBER*****
no ip address
interface FastEthernet0/1.4030
encapsulation dot1Q 4030
ip address xxx.xxx.xxxr
interface FastEthernet0/1.4035
encapsulation dot1Q 4035
Thank you in advance.
Bikas
Hi Bikas Giri,
I have one WS-C2960-48TT-L with version 12.2(52)SE and as you can see if I try to configure vlan 4030 it is possible.
Can you upgrade the IOS to the version 12.2(52)SE with IOS image c2960-lanbasek9-mz.122-52.SE.bin?
At your service,
ADAJio
---------- My configurations ----------
ecr-b01-sw03#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:49 by sasyamal
Image text-base: 0x00003000, data-base: 0x01500000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
ecr-b01-sw03 uptime is 28 weeks, 6 days, 1 hour, 53 minutes
System restarted at 11:20:52 UTC Mon Mar 7 2011
System image file is "flash:/c2960-lanbasek9-mz.122-52.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48TT-L (PowerPC405) processor (revision B0) with 65536K bytes of memory.
Processor board ID FOC1048X4MW
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1A:6C:FC:81:00
Motherboard assembly number     : 73-10391-03
Power supply part number       : 341-0097-02
Motherboard serial number      : FOC10480UJ3
Power supply serial number     : DCA103351UU
Model revision number           : B0
Motherboard revision number     : C0
Model number                   : WS-C2960-48TT-L
System serial number           : FOC1048X4MW
Top Assembly Part Number       : 800-27222-02
Top Assembly Revision Number   : C0
Version ID                     : V02
CLEI Code Number               : COM3H00BRA
Hardware Board Revision Number : 0x02
Switch Ports Model             SW Version           SW Image
*   1 50   WS-C2960-48TT-L   12.2(52)SE          C2960-LANBASEK9-M
Configuration register is 0xF
ecr-b01-sw03(config-if)#swi ac vla ?
<1-4094> VLAN ID of the VLAN when this port is in access mode
dynamic   When in access mode, this interfaces VLAN is controlled by VMPS
21 Replies 21
Jon Marshall
Bikas
If you do a "sh vlan brief" do you see these vlans ?
Is your switch in VTP transparent mode because it needs to be to create vlans in that range.
Jon
Yes I have done sho vlan brief but could not see the vlan 4030 and 4035. I have also configured other vlans in this but below 1000. It's a running well with others. I don't think the VTP mode is set to transparent, if I set it as transparent mode will it effect to other vlan or not. Can I issue this command confidently ?
- Bikas
changing to vtp transparent won't have no effect on the VLANS  and it's the only to configure an extended range VLAN.
Regards.
Alain.
Hello Alain and Bikas,
Before reconfiguring the switch into VTP Transparent mode, please verify using the show vtp status if the VTP Pruning is deactivated. If it is active, deactivate it using the no vtp pruning command before modifying the switch VTP mode. Moving a switch into VTP Transparent mode with VTP Pruning activated could result in all VLANs being pruned off the trunks leading to the newly transparent switch and breaking the network connectivity.
Best regards,
Peter
Hi Alain/Peter,
I switched vtp mode status to transparent. The show vtp status gives the result as follows.
Switch#show vtp status
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 255
Number of existing VLANs        : 6
VTP Operating Mode              : Transparent
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x7D 0x5A 0xA6 0x0E 0x9A 0x72 0xA0 0x3A
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
But, till now also I am not being able to set vlan 4030 and 4035. When I tried to add vlan 4030 it gives result as,
Switch(config)#vlan ?
  <1-1005>  ISL VLAN IDs 1-1005
Switch(config)#vlan 4030
% Invalid input detected at '^' marker.
What wrong did I do ? What should I do now to add vlan 4030 ? Is there another command to add this vlan.
With best regards,
Bikas
Hi Bikas,
Looks like you are running a Standard Image on the switch. For support of vlans 1 through 4094, you need to upgrade to an Enhanced Image.
Kapil
Please rate helpful posts.
Kapil,
To my best knowledge, there are no Standard/Enhanced images for 2960 series. There are LAN Lite and LAN Base - you probably mean the LAN Base?
Bikas, can you post the complete output of the show version command here?
Best regards,
Peter
Hi Peter,
My bad! You are right, Enhanced Image is now Lanbase while Standard Image is now Lanlite!
Kapil
Hi all,
The image is lanbase, I will paste the sho version after few hours.
With best regards,
Bikas
Hi Bikas,
This is interesting. What is the IOS version being used? AFAIK, support for 4096 VLAN IDs is there on 2960 switches with LANBase since 12.2(25)FX
Kapil
*    1   26     WS-C2960-24TT      12.2                    C2960-LANBASE-M
Bikas,
Can you post the exact image name or the complete show version?
Bikas,
In your first post, you wrote that the switch is WS-C2960S-48TD-L. The output of the switch you have posted right now is from a different switch.
Best regards,
Peter
Dear Peter,
Sorry I pasted the above information from packet tracer. I will paste the correct one after an hour.
Bikas
