How to administer cisco router 1801
malai.joseph
Hi All
I want to administer my cisco router 1801
by checking the bandwidth assigned to a site?
what users doing behind it?
or what type of traffic passing behind it or incomming traffic or maliscous activities running?
what others administration can be done as daily basis?
thx
mate,
There are lot of freewares (MRTG, cacti etc...) to monitor the bandwidth.
If you want to see the traffic from individual users, you need to configure netflow in your routers and collect the stats in a netflow analyzer.
Good luck!
InayathUlla Sharieff
Malai,
For this you have to use any monitoring tool to check the things mentioned above.
Eg:
http://www.cisco.com/en/US/products/ps9422/products_configuration_example09186a0080b2f103.shtml
http://www.cisco.com/en/US/products/sw/secursw/ps5318/index.html
Inayath
Inayath
1.by checking the bandwidth assigned to a site?
2.what users doing behind it?
3.or what type of traffic passing behind it or incomming traffic or maliscous activities running?
4.what others administration can be done as daily basis?
sory ur answer does it answer one of the above?which one ? am not asking for conf pls
thanks
J
mate,
Good luck!
