%SYS-2-MALLOCFAIL in 3550
aircel.dishnet
Visitor
Hi All,
I am getting following error message in my 3550 Switch console.Pleae help to identify the problem.
%SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0xF2D894, alignment 0
Pool: Processor  Free: 322388  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Virtual Exec", ipl= 0, pid= 148
-Traceback= 8E27BC 8E2ED0 F7F440 F882F4 127CB98 F2D898 F2CB0C F29EAC F31950 14637C 146408 86B6B4 8E862C 8E89EC 8E877C 897110
sh proc memory
Processor Pool Total:   36779168 Used:   35845080 Free:     934088
      I/O Pool Total:    8388608 Used:    3338724 Free:    5049884
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   31078156    8699672   19122188          0          0 *Init*
   0   0      13584   26816788      13584          0          0 *Sched*
   0   0  666071460  656434224     777044    4649136     872640 *Dead*
   1   0   13845592   32146592      19084          0          0 Chunk Manager
   2   0        180        180       3924          0          0 Load Meter
   3   0    1980280    2497180       6924       5040          0 SpanTree Helper
sh memory failures alloc
Caller       Pool          Size   Alignment   When
0xF2D894    Processor     259644      0      02:42:12
0xF0B3E8    Processor      64476      0      02:40:23
0xF2D894    Processor     259644      0      02:31:22
0xF2D894    Processor     259644      0      02:13:09
0xF2D894    Processor     259644      0      02:05:38
0xF2D894    Processor     259644      0      01:52:44
0xF2D894    Processor     259644      0      01:45:00
0xF2D894    Processor     259644      0      01:19:30
0xF2D894    Processor     259644      0      00:33:56
0xF2D894    Processor     259644      0      00:31:14
sh memory summary
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor    1D2A360    36779168    35857012      922156      192976      692432
      I/O   80000000     8388608     3338928     5049680     4822244     4783168
sh version
SWTH uptime is 14 weeks, 3 days, 11 hours, 33 minutes
System restarted at 23:24:26 GMT Sat Mar 23 2013
System image file is "flash:c3550-ipservicesk9-mz.122-44.SE6.bin"
Cisco WS-C3550-24 (PowerPC) processor (revision P0) with 65526K/8192K bytes of memory.
Processor board ID CAT0849N1TM
Last reset from warm-reset
Running Layer2/3 Switching Image
Arun Mohan
InayathUlla Sharieff
Arun,
Whats the software running on the switch?
Have you recently done any S/W upgrade or downgrade?
Get me the output of following commands:
show ver
show log
-show clock
--show process memory sorted
--show process memory summary
--show memory allocating-process totals
--show memory dead /show memory dead total
Inayath
Hi ,
We didn't done any activiy recenetly on this switch.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.03 11:13:40 =~=~=~=~=~=~=~=~=~=~=~=
sh ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 20:28 by gereddy
Image text-base: 0x00003000, data-base: 0x012A99FC
ROM: Bootstrap program is C3550 boot loader
uptime is 14 weeks, 3 days, 11 hours, 47 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
--More--
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:12:D9:8A:BA:80
Motherboard assembly number: 73-5700-12
Power supply part number: 34-0966-04
Motherboard serial number: CAT08490M9U
Power supply serial number: DTH084656JW
Model revision number: P0
Motherboard revision number: A0
Model number: WS-C3550-24-EMI
System serial number: CAT0849N1TM
Configuration register is 0x10F
#sh ver | in IOS
#SH CLO                  sh clock
11:16:28.004 GMT Wed Jul 3 2013
#sh log
Syslog logging: enabled (0 messages dropped, 45 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 1110 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
    Trap logging: level informational, 1309 message lines logged
        Logging to 202.148.202.175  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              1309 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
--More--
Log Buffer (4096 bytes):
rnate pool
-Process= "Virtual Exec", ipl= 0, pid= 159
Jul  3 09:27:31.944: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
Jul  3 09:27:32.948: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to down
Jul  3 09:31:05.314: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
Jul  3 09:31:06.314: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
Jul  3 09:41:44.465: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
Jul  3 09:41:45.469: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to down
Jul  3 09:42:27.738: %SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0xF2D894, alignment 0
Pool: Processor  Free: 316640  Cause: Memory fragmentation
Jul  3 09:42:30.922: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to up
Jul  3 09:42:32.078: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
Jul  3 10:00:02.310: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
Jul  3 10:00:03.310: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
Jul  3 10:12:49.096: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
Jul  3 10:12:50.100: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to down
Jul  3 10:12:52.224: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to down
Jul  3 10:12:54.228: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
Jul  3 10:13:01.632: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to down
Jul  3 10:13:02.636: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to down
Jul  3 10:13:08.481: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to up
Jul  3 10:13:09.481: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
Jul  3 10:14:58.088: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to down
Jul  3 10:14:59.092: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to down
Jul  3 10:15:04.464: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
Jul  3 10:15:05.908: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to up
Jul  3 10:15:11.592: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
Jul  3 10:15:12.592: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
Jul  3 10:28:01.531: %SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0xF2D894, alignment 0
Jul  3 10:30:43.807: %SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0xF2D894, alignment 0
--More--                           Pool: Processor  Free: 322716  Cause: Memory fragmentation
Jul  3 11:12:50.113: %SYS-2-MALLOCFAIL: Memory allocation of 123640 bytes failed from 0xF2CB54, alignment 0
Pool: Processor  Free: 226248  Cause: Memory fragmentation
-Traceback= 8E27BC 8E2ED0 F7F440 F882F4 127CB98 F2CB58 F29EAC F31950 14637C 146408 86B6B4 8E862C 8E92A4 896AFC 896DC8 86F54C
# sh proc memory sorted
Processor Pool Total:   36779168 Used:   35854140 Free:     925028
      I/O Pool Total:    8388608 Used:    3325664 Free:    5062944
116   0   13525368   10131520    5793260          0          0 IP RIB Update
119   0 2906068364   43019272    4885528          0          0 OSPF-10 Router
174   0    8524092   45230212    4194664          0          0 BGP Router
   0   0  666071460  656434224     776976    4649136     872640 *Dead*
   5   0 2707242716 2756715528     576832 2561723284 2592960496 Pool Manager
  68   0    1662436     163656     413580          0          0 DTP Protocol
  85   0  222683528  208030712     391244    9407232          0 CDP Protocol
  76   0     207072     897280     213996          0          0 VMATM Callback
177   0    8998944 2810895348     198812    5781888          0 OSPF-10 Hello
   8   0   96824464  653527476     161668          0          0 ARP Input
161   0     131876        180     144620          0          0 CEF: IPv4 proces
  13   0     198240     163628     124564          0      17680 Entity MIB API
  58   0    2859244    1225036      96208          0          0 VegasPM
115   0      73756       4080      94932          0          0 Crypto ACL
109   0     113512     468644      80652          0          0 L2MM
  61   0      71308          0      78232          0          0 Switch Backup In
145   0     103872      98952      62080          0          0 VFM/VQM Merge Pr
  77   0          0       1392      60924          0          0 HL3U PBR bkgrd p
  59   0   21892980  102663532      59512          0          0 VUR_MGR bg proce
140   0    2310292    4101552      54316          0          0 PM Callback
169   0 3345280464  244978680      52244          0          0 SNMP ENGINE
  30   0     191512        180      34276     121824          0 Logger
  94   0  653677144        180      30880          0          0 ADJ resolve proc
  52   0     480316        452      25188          0          0 HMATM Learn proc
   7   0          0          0      24924          0          0 Crash writer
148   1    1241148    1250376      21628          0      18180 Virtual Exec
  56   0 3450737016 3440859080      19840    6254640          0 L3MD_STAT
113   0      12864        180      19608          0          0 L2TRACE SERVER
142   0      14588          0      18988          0          0 RIP Router
128   0       9204       4316      18244          0          0 Crypto IKMP
  91   0    8092168    4207112      18176     153240     127260 IP Input
   1   0   13850640   32153248      17476          0          0 Chunk Manager
106   0  129656404  129863300      17392        780          0 HTTP CORE
141   0      95852      82216      16428       2340          0 VLAN Manager
111   0      14044        100      16152          0          0 IGMPSN
164   0       5692     616136      15616          0          0 BGP Scanner
153   0     259904     257344      15484          0          0 Syslog
133   0     400904     394964      14864          0          0 Crypto CA
167   0 1609766892 1558279340      13800    2954232          0 IP SNMP
170   0       1056        180      13800          0          0 IP SNMPV6
110   0      20756       5868      13416          0          0 MRD
129   0      13860      12112      13388          0          0 IPSEC key engine
  28   0      17916          0      13332        780          0 Net Background
  42   0       5416      11992      13268          0          0 Collection proce
  98   0        756        224      13248          0          0 CEF background p
  90   0        416        200      13140          0          0 CEF switching ba
103   0     469736    6269228      13132          0          0 TCP Timer
172   0          0          0      12924          0          0 SNMP Traps
  29   0          0          0      12924          0          0 IDB Work
104   0   20001660          0      12924          0          0 TCP Protocols
  26   0        180        180      12924          0          0 XML Proxy Client
  97   0        180        180      12924          0          0 KRB5 AAA
171   0          0          0      12924          0          0 SNMP ConfCopyPro
168   0 1147875980       4132      12924          0          0 PDU DISPATCHER
  12   0          0          0      12924          0          0 Policy Manager
  34   0       5416        268      12072          0          0 IF-MGR control p
  51   0 3383607600 3374013352      12044    6073200          0 Vegas Statistics
147   0       4824       7964      11568          0          0 VTP Trap Process
163   0       1556          0      11272          0          0 IP Background
160   0    2627808    2178512      11184          0          0 SSH Event handle
117   0 1017835460 1018282236       9976          0          0 crypto sw pk pro
124   0     557444          0       9932      35532          0 BGP I/O
  40   0      93080          0       9924          0          0 BGP Scheduler
  31   0        180       9024       9924          0          0 TTY Background
  64   0        180        180       9924          0          0 802.1x Accountin
  93   0        180        180       9924          0          0 IP ARP Track
  99   0          0          0       9924          0          0 IP IRDP
  96   0        180        180       9924          0          0 EAPoUDP Process
  72   0        180        180       9924          0          0 Switch IP Host T
125   0    6260308    3999932       9116          0          0 TPLUS
146   0      18260      19072       9060          0          0 VFM Deferred Upd
134   0          0          0       8924          0          0 Crypto PKI-CRL
135   0          0          0       8924          0          0 Crypto SSL
  87   0          0          0       8924          0          0 Key Proc
  20   0       1688          0       8612          0          0 IPC Seat Manager
102   0   72044896   72043984       7836          0          0 Cluster Base
  43   0        524          0       7448          0          0 Vegas LED Proces
132   0      11496       1736       7416          0          0 crypto engine pr
173   0     103928     103556       7296          0          0 NTP
  74   0        472        180       7216          0          0 UDLD
  95   0    1378112     214320       7172      38480          0 Spanning Tree
  70   0        216          0       7140          0          0 Port-Security
152   0        216          0       7140          0          0 DATA Collector
162   0        216          0       7140          0          0 ADJ background
151   0        216          0       7140          0          0 DATA Transfer Pr
  63   0        296        180       7040          0          0 Dot1x Mgr Proces
  80   0          0          0       6924          0          0 AAA ACCT Proc
  89   0          0          0       6924          0          0 DHCP Snooping
  62   0          0          0       6924          0          0 MMN bkgrd proces
  60   0        180     461780       6924          0          0 PI MATM Aging Pr
  79   0        180        180       6924          0          0 AAA Server
   4   0          0      36952       6924          0          0 Check heaps
  84   0          0          0       6924          0          0 IP Admin SM Proc
  78   0          0          0       6924          0          0 Vegas PBR n-h re
  67   0          0          0       6924          0          0 802.1x Webauth F
  83   0          0          0       6924          0          0 Auth-proxy AAA B
  53   0        180        180       6924          0          0 HMATM Age proces
  82   0          0          0       6924          0          0 AAA System Acct
  75   0          0          0       6924          0          0 Vegas IPSG Proce
  73   0        180        180       6924          0          0 Ethchnl
  71   0      56408          0       6924          0          0 TACACS+
  57   0          0          0       6924          0          0 Vegas Bridging
  81   0          0          0       6924          0          0 ACCT Periodic Pr
105   0          0          0       6924          0          0 Socket Timers
  48   0          0          0       6924          0          0 JADE Gbit lockup
107   0          0          0       6924          0          0 RARP Input
108   0          0          0       6924          0          0 802.1x Critical
  47   0          0          0       6924          0          0 VLAN Info Update
  69   0          0          0       6924          0          0 EAP Framework
  45   0          0          0       6924          0          0 RAM Access
112   0          0          0       6924          0          0 IGMPQR
   6   0        180        180       6924          0          0 Timers
114   0          0          0       6924          0          0 Vegas wccp manag
  92   0          0          0       6924          0          0 ICMP event handl
  55   0          0          0       6924          0          0 L3MD
  41   0        180        180       6924          0          0 DownWhenLooped
118   0          0     860072       6924          0          0 Transport Port A
  65   0          0          0       6924          0          0 MAB Framework
120   0        180        180       6924          0          0 Crypto Support
121   0        748        892       6924          0          0 LOCAL AAA
  54   0     348088     394816       6924          0          0 VL2MM
123   0        180        180       6924          0          0 LINE AAA
  38   0          0          0       6924          0          0 HC Counter Timer
  66   0          0      45348       6924          0          0 802.1x switch
126   0          0          0       6924          0          0 CRYPTO QoS proce
127   0          0          0       6924          0          0 Crypto INT
  37   0        180        180       6924          0          0 Compute load avg
  36   0          0          0       6924          0          0 AggMgr Process
130   0          0          0       6924          0          0 IPSEC manual key
131   0          0          0       6924          0          0 Crypto PAS Proc
100   0        180        180       6924          0          0 Cluster L2
  35   0          0          0       6924          0          0 IF-MGR event pro
101   0          0          0       6924          0          0 Cluster RARP
122   0        180        180       6924          0          0 ENABLE AAA
136   0          0          0       6924          0          0 encrypt proc
176   0          0    1517416       6924          0          0 RIP Timers
138   0        180        180       6924          0          0 VTPMIB EDIT BUFF
139   0        180        180       6924          0          0 DHCP Security He
  33   0      10680        908       6924       6840          0 Per-minute Jobs
  32   0   63010152   63010152       6924          0          0 Per-Second Jobs
  27   0          0          0       6924          0          0 Critical Bkgnd
143   0        180        180       6924          0          0 dhcp snooping sw
144   0          0          0       6924          0          0 VFM Queue Proces
  25   0        180        180       6924          0          0 GraphIt
  88   0        204        204       6924          0          0 AAA Dictionary R
  24   0          0          0       6924          0          0 Net Input
  23   0          0          0       6924          0          0 ARP Snoop
149   0     236728     752132       6924          0          0 AAA SEND STOP EV
150   0          0          0       6924          0          0 Syslog Traps
  19   0          0          0       6924          0          0 IPC Deferred Por
  18   0          0          0       6924          0          0 IPC Managed Time
  22   0          0          0       6924          0          0 Dynamic ARP Insp
165   0          0          0       6924          0          0 TCP Listener
166   0          0          0       6924          0          0 SNMP Timers
175   0          0          0       6924          0          0 RIP Send
   9   0          0          0       6924          0          0 CEF MIB API
  11   0        180        180       6924          0          0 AAA high-capacit
  21   0          0          0       6924          0          0 IPC Session Serv
  14   0          0          0       6924          0          0 IFS Agent Manage
  15   0          0          0       6924          0          0 IPC Dynamic Cach
  16   0          0          0       6924          0          0 IPC Zone Manager
  17   0          0          0       6924          0          0 IPC Periodic Tim
  10   0          0          0       6924          0          0 AAA_SERVER_DEADT
158   0        180        180       3972          0          0 CSRT RAPID TRANS
  44   0          0          0       3924          0          0 SCQ_PROCESS
  49   0        180        180       3924          0          0 L2TM Process
  46   0        180        180       3924          0          0 SW Frame Ager
154   0          0          0       3924          0          0 C3550 DHCP Snoop
  39   0        180        180       3924          0          0 Vegas Storm Cont
  50   0        180        180       3924          0          0 L3TM
137   0        180        180       3924          0          0 Vegas EnvMon Pro
155   0        180        180       3924          0          0 STP STACK TOPOLO
156   0        180        180       3924          0          0 STP FAST TRANSIT
157   0        180        180       3924          0          0 STP STACK TOPOLO
                                 39087964 Total
# sh proc memory su      ?
  <1-4294967295>  [pid]
  sorted          Show sorted output based on memory used by process
  |               Output modifiers
# sh proc memory
Processor Pool Total:   36779168 Used:   35847504 Free:     931664
   8   0   96824464  653532004     161668          0          0 ARP Input
  32   0   63010224   63010224       6924          0          0 Per-Second Jobs
--More--                            PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
  51   0 3383613096 3374019028      11864    6073200          0 Vegas Statistics
  56   0 3450742392 3440864456      19840    6254640          0 L3MD_STAT
  85   0  222683988  208031172     391244    9407232          0 CDP Protocol
  94   0  653682748        180      31956          0          0 ADJ resolve proc
148   1    1256200    1270980      16076          0      18180 Virtual Exec
167   0 1609768412 1558280860      13800    2954232          0 IP SNMP
168   0 1147876956       4132      12924          0          0 PDU DISPATCHER
169   0 3345306656  245005848      52244          0          0 SNMP ENGINE
                                 39083308 Total
# show memory allocating-process totals
Processor    1D2A360    36779168    35866828      912340      192976      692432
      I/O   80000000     8388608     3330660     5057948     4822244     4783168
--More--
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x0093A350    4882056       6  Init
0x00094F4C    3958608     120  TAL: MTRIE n08
0x00C4A138    2724228      40  IP single NDB
0x001583EC    1763784    1925  *Packet Header*
0x00D72D54    1730544      26  OSPF lsdb
0x003EA444    1403876     179  Interrupt Stack
0x0095D898    1180440      18  CEF: fib
0x006F18B8     974244      14  IPv4 Unicast n
0x006F171C     852540      13  BGP IPv4 path-
0x00C4D7EC     786960      12  IP RDB Chunk
0x00E31C70     580804    3417  RIP ndb
0x006DC8E4     459060       7  BGP (0) update
0x004031AC     411804      41  Flashfs Sector
0x00EA6454     393480       6  STP Port Control Block Chunk
0x00D74690     380836      19  OSPF sum-lsa
0x006DBD30     327900       5  BGP path-chunk
0x006F1944     327900       5  IPv4 Tunnel net-chunk(8)
0x00E311B8     281124    3176  RIP rdb
0x00D72DE0     263152       8  OSPF lsidnode
0x0099093C     262232       2  CEF: hash table
0x00F6D0B0     246420      15  TW Buckets
0x0015D690     240560       4  pak subblock chunk
0x004C8C64     236556      22  VUR_MGR_FIB
0x0016595C     212524      67  *Hardware IDB*
0x00091630     207072       3  Mat Addr Tbl C
0x00EA2E3C     206312       3  STP Port Contr
0x00A86928     204000    3000  IPC Fragment
0x00A85D28     196740       3  IPC Message He
0x002306AC     188972       1  L3TCAM Shadow CAM
0x002DFF78     163884       1  Init
0x012688B0     151424      18  TAL: rtree nodes
0x00D9EEAC     143032       5  OSPF path
0x00226D80     133676       1  Init
0x00094F0C     131936       4  TAL: MTRIE n08
0x00992510     131160       2  CEF: fib GSB
--More--                               PC          Total   Count  Name
0x0040174C     127296     221  vegas_flash init
0x0095745C     123816      12  CEF: pathl
0x00FB339C     122500     175  Process
0x006DC71C     118480       4  BGP (1) attr
0x0026BDB8     113612       1  PM port_data
0x00220924     106584       2  Init
0x008605E0     104280       2  event_trace_tbs
0x0016597C     102644      67  *Software IDB*
0x000C6834      87564       2  TAL: item list elem
0x00BA1C34      82516       1  Init
0x011E1754      79484    1163  Init
0x009AEB8C      78824       2  CEF: dQ elems
0x0096B924      78824       2  CEF: fib_fib_src_adj_sb_avl_node
0x000DA6E4      78120      18  TTY data
0x00E9E5C8      76844       1  Spanning Tree Opt Port Block
0x0097011C      75080       2  CEF: fib deps
0x0096C804      75080       2  CEF: fib_fib_src_interface_sb
0x002857A4      74224     571  PM vp_data
0x00230700      73772       1  L3TCAM handle tbl
0x009B53D0      73000       2  CEF: subtree context
0x00F737B8      72996     327  *Init*
0x009AE060      72272       2  COLL: coll rec
0x0096ED70      72272       2  CEF: cover need deagg chunk
0x00975F38      71676       2  CEF: mpls path exts
0x0096BAC0      71676       2  CEF: fib_fib_src_adj_sb
0x000B6A24      71308       1  Switch Backup If Chunk
0x0096DD58      71180       2  CEF: fib_fib_covered chunk
0x00999FF8      70760       2  OCE reinject handles
0x00984C5C      70400       2  CEF: pathl ifs
0x00E8CA90      70096       6  SNMP SMALL CHU
0x00975F60      69168       2  CEF: mpls long path exts
0x0097CB40      68380      65  CEF: FIBHWIDB
0x00C9BD60      67492      58  ATF node
0x0094166C      67084       2  CEF: loadinfos
0x00C4515C      66568       2  IP: Control Block
0x0066740C      66400       2  ADJ: adjacency
0x00991B24      65900       2  CEF: fib_rib_route_update
0x0005B174      65880       2  Init
0x00260134      65832      26  PM port sub-block
0x0018FD5C      65580       1  IDB List Element Chunks
0x00A8685C      65580       1  IPC Message Header Cache
0x00052CA4      65580       1  IF-MGR DB elements
0x0005CC70      65580       1  IF-MGR Stack tree elements
0x0005F138      65580       1  IF-MGR TDB node
0x00093830      65580       1  Mat Addr Tbl Chunk
0x007FEF00      65580       1  ACCT Temp chunk
0x009236FC      65580       1  DHCP Circuit ID chunk
0x0095D488      65580       1  CEF: fib
0x00C454F0      65580       1  IP single NDB entry
0x0005CCC8      65580       1  IF-MGR No layer stack tree elements
0x00053C54      65580       1  IF-MGR control process elements
0x009236D4      65580       1  DHCP Glean binding chunk
0x00C440CC      65580       1  IP RDB Chunk
0x00C45518      65580       1  IP subnet NDB entry
0x00D56430      65580       1  OSPF lsdb
0x006DC960      65580       1  BGP battr chunk
0x00812BC0      65580       1  AAA DB Elt Chunk
0x00945F4C      62616       6  CEF: paths
0x000B2928      61720     703  State Machine debug data
0x005C0EF4      60776       1  mtree root
0x000B28E0      56464     703  State Machine debug meta data
0x00C9DB74      56208      98  ATF tracked
0x00435814      55536      42  Init
0x006EA040      50796       2  BGP gwcache-ch
0x008B45E0      49196       1  Virtual Exec
0x004C4EBC      49140      50  VUR_DRV_HWD_FA
0x00EA1A8C      47316     106  Spanning Tree Control Block
0x0000A28C      45888     407  DTP Protocol
0x009482E0      44800     614  CEF: terminal fibs list
0x00F09634      43840      10  PM Callback
0x01266AD4      43568      48  ATF route node
0x00D44E0C      41004       1  Init
0x00052144      40044       1  Init
0x00D4733C      39244       1  Init
0x00F73324      36792      18  Reg Function 1
0x0127E93C      36572     178  *Init*
0x0087A89C      35112     462  Init
0x000BC138      34856       1  MMN macs vlan data
0x01266A70      34384      38  ATF route node
0x008D06DC      32816       1  Init
0x0086AB08      32812       1  Parseinfo Blocks
0x01261644      32812       1  Radix trie mask chunks
0x00D5620C      32812       1  OSPF lsidnode
0x00A6A834      32812       1  vrf selection chunk
0x00D563D8      32812       1  OSPF redist RI
0x00653B80      32812       1  AAA Acct Req chunk
0x006DC0D8      32620       1  Init
0x006DC164      32620       1  Init
0x00FB5C0C      32232     178  Process Events
0x00871C9C      31868     465  Parser Linkage
0x00226B04      31724       1  Init
0x00447838      31512      26  Port Counter Info
0x0038CC18      26848     106  L2MM
0x00C9CDFC      26808      46  ATF route
0x008F7528      26444       1  PM Event Pool
0x0005DA5C      25940       1  IM Event small chunk pool
0x0005DAD8      25840       1  IM Event big chunk pool
0x003806EC      24320     106  L2MM
0x00D7E1DC      24044       1  Init
0x00A868D0      23600     100  IPC Message
0x00C45540      23516       2  NET REDIST
0x00FB572C      23176       4  Watched Semaph
0x002E88A4      22192       4  Init
0x00CDF198      22184       2  CEF: arp throttle chunk
0x00CFBFE4      21848       2  ADJ: request resolve
0x0097C16C      21628      65  CEF: FIBIDB
0x0126AF88      21612       2  acl subtree
0x00793F10      21016       2  URPF dropcnt samples
0x009454D0      20872       2  CEF: paths
0x009560B0      20736       2  CEF: pathloutputchain
0x009561F8      20636       2  CEF: pathl
0x00E8AE9C      20424     118  SNMP Trap
0x005AC9DC      20424       1  Init
0x005ACA04      20424       1  Init
0x011379AC      20424       1  Init
0x00F67B00      20088       2  List Elements
0x00F7E68C      20044       1  Managed Chunk Queue Elements
0x0086AB84      20044       1  Parse Nodes
0x00A3F2B8      20044       1  File Descriptors
0x00A7B818      20044       1  IPC port info
0x0044236C      20044       1  VPD_STP_CHUNK
0x005A9F14      20044       1  Crypto DHtable Chunk
0x00D5645C      20044       1  OSPF stub-lsa
0x00D564B4      20044       1  OSPF ex-lsa
0x00093858      20044       1  Mat Addr Entry Chunk
0x00D56488      20044       1  OSPF sum-lsa
0x00D564E0      20044       1  OSPF path
0x00D56538      20044       1  OSPF req hasht
0x006DC7D4      20044       1  BGP gwcache-chunk
0x00C86CBC      20044       1  IP Prefixlist Info Chunks
0x00817F14      20044       1  AAA Acct DB chunk
0x00E5E88C      20004     232  Entity MIB API
0x00208144      18264       6  HMAT Dynamic c
0x012669A4      18080      20  ATF route node
0x00311E88      17584      28  iprl
0x006DBD84      16860       5  Init
0x00226DB8      16748       1  Init
0x00C535BC      16608      65  OSPF-10 Router
0x0022090C      16472       2  Init
0x0000B920      16432      41  Init
0x006DC5DC      16428       1  Init
0x006DC518      16428       1  Init
0x006DC550      16428       1  Init
0x006DC5F8      16428       1  Init
0x00F73294      16352       8  Reg Function 1
0x006DC4FC      15316       1  Init
0x006DC0BC      15316       1  Init
0x00386080      15232     106  L2MM
0x006789DC      14528     105  ADJ resolve process
0x00592750      14380       1  Init
0x00D97DEC      13296     155  OSPF-10 Router
0x00873EA8      13264     132  Parser Mode
0x010E46F4      13172       3  Crypto Engine Object Table
0x00D4F6B8      13004       1  Virtual Exec
0x0126FE78      12864      12  Index Table Block
0x00E8A3E8      12848       1  Init
0x0127C4B8      12844       1  *Init*
0x006DC084      12516       1  Init
0x006DC470      12516       1  Init
0x006DC4E0      12516       1  Init
0x006DC2E0      12428       1  Init
0x00F32304      12412       1  Ext Vlan DB Init
0x006EA17C      12176       4  BGP nhop-info
0x00F7E9DC      12168       6  PROTO_COUNTER
0x00A868F4      12044       1  IPC Frag Cache
0x00BC1FBC      12044       1  Init
0x004C9628      12044       1  VUR_MGR_FIB
0x0041B3E8      11860      37  Virtual Exec
0x00F07458      11696      97  VLAN Manager
0x0080111C      11244       1  AAA attr list handle IDs
0x009B16C4      10848       2  CEF: nh entry context
0x00936EA8      10800     110  Entity MIB API
0x009AFE78      10772       2  CEF: non_ip entry context
0x0066A3AC      10772       2  ADJ: sevs
0x00956618      10708       2  CEF: plist dq it
0x00226B40      10604       1  Init
0x0094C998      10552       2  CEF: table
0x0038B980      10460       5  IGMPSN
0x00F68914      10320       2  List Headers
0x00F68E60      10044       1  List Elements
0x00FB835C      10044       1  Watched Queue
0x00FB8384      10044       1  Watched Boolean
0x00FB83AC      10044       1  Watched Bitfield
0x00A45E5C      10044       1  Pathents for parsing
0x00A45E84      10044       1  TTY Pathents for parsing
0x004A968C      10044       1   GCE COOKIE DEFAULT CHUNK
0x004CC2B0      10044       1  VUR_MGR_ADJ
0x00546478      10044       1  VMM
0x00E8CE44      10044       1  SNMP MEDIUM CHUNK
0x000C969C      10044       1  Time Range Entry Chunks
0x005DB1E8      10044       1  KMI sa request chunk pool
0x005DB218      10044       1  KMI sa list chunk pool
0x005A9EEC      10044       1  Crypto conntable Chunk
0x00D56404      10044       1  OSPF redist PI
0x00D5650C      10044       1  OSPF rl timer
0x00C86CF0      10044       1  IP Prefixlist Seq Chunks
0x0081A17C      10044       1  AAA Acct Rec chunk
0x00408368      10044       1  Flashfs Sector Pointers
0x00401F3C      10044       1  Flashfs Sector
0x004CC288      10044       1  VUR_MGR_FIB
0x00546450      10044       1  VMDB
0x00652248      10044       1  AAA chunk
0x00E8CDFC      10044       1  SNMP SMALL CHUNK
0x005925F4      10044       1  SADB SA Header List Chunk
0x00592648      10044       1  SADB RootChunk
0x001B3DC0      10044       1  DHCP binding entry chunk
0x00D562C0      10044       1  OSPF nbr retx unit
0x01266094       9900      33  *Init*
0x007FEED8       9644       1  SYS ACCT LISTS
0x00CC2104       9632       8  TCP CB
0x00DDDA88       9240      30  CLASSMAP_MODULE
0x00F64BF4       9132       3  radius
0x00873F14       9128     132  Parser Mode Q1
0x00873F38       9024     132  Parser Mode Q2
0x007EA438       8844       1  PPP ACC LISTS
0x0008D6A0       8628      61  Init
0x002CB9A0       8572     106  PM app data
0x00936F3C       8464     110  Entity MIB API
0x00F73B4C       8440       4  Reg Function 1
0x0082A494       8408       2  ID MGR
0x00936F48       8392     110  Entity MIB API
0x00E6C174       8356     110  Entity MIB API
0x0021AB40       8320       4  Init
0x00046AEC       8320      26  Init
0x0021AB18       8320       4  Init
0x00E6C188       8312     110  Entity MIB API
0x0054A318       8300       1  Init
0x0054A2F4       8300       1  Init
0x0054A33C       8300       1  Init
0x00C45718       8260       1  IP PDB
0x00D55848       8260       1  Init
0x00E2FEF8       8260       1  RIP pdb
0x006DCE6C       8260       1  Init
0x00C456A8       8260       1  IP PDB
0x0041C620       8248      26  Init
0x004CC3E0       8236       1  Init
0x012469CC       8236       1  SSH Process
0x002B6DB8       8056     106  Virtual Exec
0x007EA47C       8044       1  NET AUTHOR LISTS
0x007EA4C0       8044       1  SUBSCRIBER-PROFILE AUTHOR LISTS
0x00D73D58       7736      40  OSPF-10 Router
0x001F3820       7652      24  DTP SWSB
0x004A3C6C       7544     106  L2MM
0x00FB0850       7452      23  Pool Info
0x00DDEB38       7240      46  CLASSMAP_MODULE
0x009BBE1C       6848       2  CEF: up event chunk
0x00CAA4D8       6800       4  Syslog
0x00A81220       6704       4  IPC Port
0x0046C678       6424      86  Init
0x00DDEC78       6360      30  CLASSMAP_MODULE
0x00D60B50       6276       3  OSPF-10 Router
0x008FB690       6276       3  Init
0x008FB610       6276       3  Init
0x008FB65C       6276       3  Init
0x009BBE44       6184       2  CEF up event subblock chunk
0x00F73858       6132       3  Reg Function 1
0x009803C4       6076      32  CEF: FIBSWSB control
0x00C67628       6048      70  OSPF-10 Router
0x00DE268C       6000      55  POLICYMAP_MODULE
0x01149918       5940      58  Crypto CA
0x00936FC4       5924      29  Entity MIB API
0x00C437BC       5888      64  IPRTG SWSB
0x002FB278       5720      26  HWIF-QM-SB
0x00F065A0       5708       1  VLAN Manager
0x006ED198       5692       1  Init
0x00C60C88       5692       1  BGP Scanner
0x009562B0       5684       2  CEF: pathl recompute sb
0x002E88C0       5680       4  Init
0x001658F8       5644       1  Init
0x00C45400       5644       1  IP: Cblk-table
0x0097CF4C       5644       1  CEF: fibidb table
0x00C713D8       5644       1  Init
0x0097CF6C       5644       1  CEF: fibhwidb table
0x00E36A08       5644       1  RIP: ip Cblk-table
0x00592740       5540       1  IPSEC debug rate limit array Chunk
0x00058A8C       5536      65  Init
0x009B2D18       5496       2  OCE: QoS
0x00C8DA70       5432      64  IDB: IPINFO
0x0099E2A8       5392       2  OCE: Push Counter
0x006DBCA4       5340       5  Init
0x0015274C       5304      78  Init
0x00051B9C       5148      62  IF-MGR control process
0x00AA9F50       5088      15  Init
0x00F68EA0       5044       1  List Headers
0x00FB83F8       5044       1  Watcher Info
0x004097D8       5044       1  Flashfs Sector buffers
0x00A165E4       5044       1  HTTP_SMALL_CHUNK
0x00534D7C       5044       1  RIPv6 routes
0x005DB038       5044       1  KMI sa pair chunk pool
0x005DB068       5044       1  KMI prop list chunk pool
0x005DB098       5044       1  KMI proposal chunk pool
0x005DB0F8       5044       1  KMI sa delete chunk pool
0x005DB128       5044       1  KMI notify chunk pool
0x005DB158       5044       1  KMI num ipsec sas chunk pool
0x00592674       5044       1  IPSEC Ident list Chunk
0x00592718       5044       1  IPSEC SA sibling Chunk
0x00D56284       5044       1  OSPF work
0x0054EBCC       5044       1  vpbr_BKG_MSG
0x0007B4F4       5044       1  IP cache bitfield chunk
0x00FB53C4       5044       1  Watcher Info
0x00DDFC40       4928      16  Runtime matchparams
0x00181640       4728      51  Virtual Exec
0x0097BCA4       4704      65  Init
0x005A9F3C       4644       1  Crypto flowtable Chunk
0x0059261C       4644       1  SADB Peering Chunk
0x00AE1F70       4644       1  ip localpool
0x01052AB0       4644       1  IP SLAs Hash Element Chunk
0x004D6740       4644       1  VTP Trap Messages
0x006DC6C8       4644       1  BGP fcache-chunk
0x00652450       4644       1  AAA Acct AVLnode chunk
0x005925A4       4644       1  SADB SA Info Chunk
0x00DABADC       4644       1  OSPF_outputq
0x00D56338       4644       1  OSPF flood info
0x006DC694       4644       1  BGP rcache-chunk
0x005C0E7C       4644       1  mtree leaf
0x000863A0       4588      65  SNMP IDB
0x0097BBC8       4544      65  Virtual Exec
0x0097BBE8       4532      65  Init
0x0097BCC4       4516      65  Virtual Exec
0x00DEAAEC       4480      56  POLICYMAP_MODULE
0x00D1F368       4452       1  LSD Client Context
0x00796570       4336       6  Init
0x012526BC       4332      23  OSPF Summary ASBR LSA RBTree
0x00006FD4       4328       1  Init
0x00006FE4       4328       1  Init
0x01270A08       4320       4  Minmax8u
0x0008D654       4300      61  Init
0x006DC34C       4268       1  Init
0x011379D4       4208       1  Init
0x00DEA870       4188      29  POLICYMAP_MODULE
0x00CE4F7C       4160      28  IPv4 FIB subblock
0x01242D10       4152       1  SSH memory
0x012417C0       4152       1  SSH memory
0x008DA908       4140       1  Init
0x0047A2C4       4140       1  Init
0x011E1780       4140       1  Init
0x00A165B8       4140       1  HTTP
0x0089A6A0       4140       1  AAA Unique Id Hash Table
0x006DC1F0       4136       1  Init
0x006DC2A8       4136       1  Init
0x006DC3D4       4136       1  Init
0x006DC20C       4132       1  Init
0x006DC3F0       4128       1  Init
0x006DC228       4128       1  Init
0x006DC19C       4124       1  Init
0x006DC254       4124       1  Init
0x006DC380       4124       1  Init
0x006DC454       4124       1  Init
0x006DC1B8       4124       1  Init
0x006DC270       4124       1  Init
0x006DC39C       4124       1  Init
0x006DC438       4124       1  Init
0x006DC0A0       4116       1  Init
0x006DC328       4116       1  Init
0x008B1150       4080       3  Graphit Client
0x011323DC       4048       1  Init
0x001914D4       4044       1  Packet Elements
0x0067C004       4032       1  AUTH-PROXY hash pointer
0x008F333C       4000       8  Chain Cache No
0x00667434       3932       2  ADJ: adj sev context
0x00D558C0       3844       1  Init
0x00EFD614       3752      32  PM Callback
0x003E4CFC       3744      26  UDLD sw subblock
0x000B16B8       3676      26  Init
0x005A9E1C       3628       1  Init
0x005A9E30       3628       1  Init
0x005A9E44       3628       1  Init
0x0096A1D8       3612       2  CEF: fib_fib_src_special_sb
0x00088000       3564      52  Init
0x00088014       3536      52  Init
0x00DDEBC8       3456      16  Runtime classmap
0x000BE8B4       3416       2  TAL: mtrie control block
0x004C4E38       3376       3  VUR_DRV_TCAM_F
0x00923734       3344       1  DHCP Snooping Message Workspace
0x00374A54       3328      32  dai_log_entry_t
0x00CD9528       3268      11  IP SNMPV6
0x00992980       3204       3  db epoch stats
0x0013D9C4       3140       1  Init
0x0077D3B8       3092      10  CDP Protocol
0x00FB8474       3044       1  Read/Write Locks
0x00F649EC       3044       1  CCA CCB chunks
0x00F64A1C       3044       1  CCA CLL chunks
0x0020C5CC       3044       1  HMAT Dynamic cookie
0x004A9704       3044       1   MCAST BULK UPDATE
0x00A95544       3044       1  IP Addresses
0x000C96C4       3044       1  Time Range Item Chunks
0x005DB248       3044       1  KMI route chunk pool
0x005A94D0       3044       1  Crypto Dropped Packets Chunk
0x005C763C       3044       1  Crypto ACL Commands
0x005926C8       3044       1  IPSEC TED Chunk
0x005C0EA4       3044       1  mtree leaf-multiple
0x00D562FC       3044       1  OSPF nbr retx block
0x00D56374       3044       1  OSPF LSA hdr
0x006DC808       3044       1  BGP nhop-info chunk
0x006DC870       3044       1  BGP NLRI-chunk
0x00402F84       3044       1  file_map_entry_chunk
0x00402FA8       3044       1  file_map_entry
0x004A96C8       3044       1   VDB COOKIE GCE CHUNK
0x006DC76C       3044       1  BGP attrlist-chunk
0x006DC9C8       3044       1  BGP BFD MSG
0x009F8C14       2944      32  HTTP
0x00ABE170       2940      35  IP Sticky ARP subblock
0x00DDEC98       2924      30  CLASSMAP_MODULE
0x00A88C70       2916       8  IPC Thread Slot
0x00E8C050       2900       1  SNMP trapObjectSyntax Pool
0x00877848       2808       9  Init
0x003F597C       2756      12  Process Signals
0x00191284       2744       2  PROTO_COUNTER
0x0041B9E8       2728      37  Init
0x0041B92C       2688      37  Init
0x00D97DC8       2676      36  OSPF-10 Router
0x00786840       2648      26  CDP sw subblock
0x0041BA28       2620      37  Init
0x0044FC68       2580      15  Init
0x01260618       2560      17  BGP Router
0x0046AB64       2496      26  LES STACK-MIB HW subblock
0x0087DCB0       2460      15  Init
0x0099E93C       2432       2  OCE: lookup
0x0099D540       2432       2  OCE: Special
0x00786914       2432      26  CDP hw subblock
0x006DC1D4       2416       1  Init
0x006DC28C       2416       1  Init
0x006DC2C4       2416       1  Init
0x006DC3B8       2416       1  Init
0x000E0200       2404      34  Init
0x00D6FD34       2384       4  OSPF-10 Router
0x00C9B96C       2324       2  ATF node
0x00784D70       2320      10  CDP Protocol
0x00956270       2288       2  CEF: pathl its
0x00305278       2288      28  Init
0x00937014       2240      28  Entity MIB API
0x0071DDFC       2196       3  Init
0x00936FE4       2196      29  Entity MIB API
0x00994CC8       2184       2  OCE queue linkage
0x009F87E4       2176      32  HTTP
0x00AEEC3C       2152       2  Init
0x004D611C       2140       1  Vegas BridgeQ
0x0030B8C4       2128      30  QM_IDB
0x00937058       2124      29  Entity MIB API
0x010E4BF8       2092       1  Crypto requests
0x006DC5C0       2092       1  Init
0x009355FC       2084      29  Init
0x00DEAA28       2084      25  POLICYMAP_MODULE
0x00D453C8       2084       1  Init
0x0087A998       2072      29  Init
0x00AEED88       2064      26  Virtual Exec
0x011323E8       2048       1  Init
0x000DBFD8       2044       1  TTY Input Buf
0x00F731D4       2044       1  Reg Function 12
0x00409694       2044       1  vegas_flash init
0x0054A494       2044       1  L3MD stats
0x0054A718       2044       1  L3MD RPF Timers
0x0068FD8C       2044       1  IP Admin Host Info Chunk
0x005DB0C8       2044       1  KMI spi chunk pool
0x006DC7A0       2044       1  BGP worktype-chunk
0x0048C57C       2044       1  VFM VMR Chunk
0x004CC2D8       2044       1  VUR_MGR_MULTIPATH
0x007FEF4C       2044       1  AAA Call Dict
0x00534D54       2044       1  RIPv6 paths
0x00E8CE98       2044       1  SNMP BIG CHUNK
0x0048C444       2044       1  VFM VMR Chunk
0x006DC83C       2044       1  BGP nbr-info chunk
0x0087AAEC       2028      29  Init
0x002FC294       2020      28  Init
0x00305238       2016      28  QM_ACTP
0x008F342C       2012       4  Chain Cache No
0x004ADC00       1996      29  Init
0x0087AB9C       1972      29  Init
0x00DEA890       1972      29  POLICYMAP_MODULE
0x00A106F8       1960       2  HTTP
0x00DDEDCC       1952      26  CLASSMAP_MODULE
0x002FC2B8       1952      28  Init
0x008D67F0       1932       2  Bitfields
0x00D746A4       1912      15  OSPF-10 Router
0x01252628       1904      23  Init
0x002FBFCC       1904      28  Init
0x0041C08C       1868      26  Init
0x0090F2B8       1868       2  DHCPD Radix Information Nodes
0x00AA9F5C       1860      15  Init
0x00937158       1848      26  Entity MIB API
0x0108DFF8       1844       1  Init
0x004C1838       1836       1  Init
0x00A45F18       1812       1  vegas_flash init
0x00717DF0       1812       3  Init
0x0087D6A0       1804      24  Init
0x00796264       1800       6  Init
0x0041B664       1768      26  Init
0x0041B6B0       1768      26  Init
0x00467BA4       1768      26  Init
0x000B1EF4       1768      26  State Machine Instance
0x00DE6DE4       1728      16  Runtime actiongroup
0x008B1134       1728       3  GraphIt Data
0x0087D690       1716      24  Init
0x002EB234       1708      20  VFM/VQM Merge Process
0x004CFA94       1664      22  DWL SWSB
0x004CFB0C       1644      22  VegasPM
0x0045A8C4       1620       1  CPU Interface Instance
0x00A3DFDC       1596      19  Init
0x00A3E00C       1596      19  Init
0x004115F8       1580       1  vegas_flash init
0x0041328C       1556       1  vegas_flash init
0x00FB8304       1544       1  messages
0x00FB8330       1544       1  Watched messages
0x00FB83D4       1544       1  Watched Semaphore
0x00FB8448       1544       1  Watcher Message Queue
0x00F731FC       1544       1  Reg Function iList
0x00F73224       1544       1  Reg Function Caselist
0x00A7B6F4       1544       1  IPC Split Init Func Cache
0x0000D928       1544       1  SNMP card chunk pool
0x0000D954       1544       1  SNMP card big chunk pool
0x0041381C       1544       1  vegas_flash init
0x004CC350       1544       1  VUR_ADJ_INFO
0x00D47370       1544       1  NTP Chunk
0x00F5FFA4       1544       1  UDLR hw subblock chunks
0x00F60004       1544       1  UDLR sw subblock chunks
0x000C96EC       1544       1  Time Range User Chunks
0x005DAFA8       1544       1  KMI id chunk pool
0x005925CC       1544       1  IPSEC transient spi Chunk
0x00E2FF40       1544       1  RIP IDB List Element Chunks
0x00436544       1544       1  VRA Req Handles
0x004C2D1C       1544       1  VUR_DRV_MULTIADJ
0x004CC3C8       1544       1  VUR_BACKWALK_CONTEXT_CHUNK
0x001F16AC       1544       1  DTP messages
0x0068FDD4       1544       1  IP Admission Policy Info Chunk
0x005C0ECC       1544       1  mtree hash-table
0x0005FBC4       1540      22  Init
0x00F71D40       1540      19  *Sched*
0x00D65BD4       1528       2  OSPF sw subblock
0x000DDD84       1456      20  Virtual Exec
0x001ACA64       1440       5  Event Dampening Library
0x00843758       1428       1  Connection
0x00E9E968       1420       1  stp_timer_tree_type
0x005AAC1C       1420       1  Crypto Background Requests
0x002EB258       1396      18  VFM/VQM Merge Process
0x00D60DC8       1380      16  OSPF-10 Router
0x006EB2B0       1364       1  Init
0x006ED188       1364       1  Init
0x006EF9E0       1364       1  Init
0x006F1228       1364       1  Init
0x007472EC       1364       1  Init
0x00AEF158       1360      17  Init
0x00995D88       1344      16  Init
0x00DE6E78       1340      16  Runtime action map
0x01261664       1328       8  Init
0x00F32430       1328      13  Ext Vlan entry
0x0046DCC4       1324       1  Init
0x004357CC       1320       4  VRA User Handl
0x00152B20       1312       8  Init
0x00E5E87C       1240       5  Init
0x008764BC       1216      16  Parser Alias
0x00C8278C       1188       3  Init
0x0041E524       1184       1  VEGAS_OIDB
0x009B246C       1164       2  OCE: multicast
0x00C9E0B8       1164       2  ATF route
0x00DE6D94       1152       8  Runtime policymap
0x00D5623C       1152       1  Init
0x00C9E090       1140       2  ATF tracked
0x00934F48       1116       1  Init
0x008764EC       1088      16  Init
0x00FB1320       1076       1  Process Array
0x00FEAABC       1076       1  Init
0x00AEEFEC       1076       1  Init
0x00864D54       1068       1  String DB Hash Table
0x0040980C       1068       1  vegas_flash init
0x001FF1E8       1068       1  EAP session handle table
0x00CDF168       1068       1  CEF: IPv4 ARP throttle
0x006DC534       1068       1  Init
0x006DC56C       1068       1  Init
0x006DC5A4       1068       1  Init
0x004CC408       1068       1  Init
0x00FE3A78       1068       1  Init
0x006DC588       1068       1  Init
0x00801C28       1068       1  AAA attr list handle IDs
0x0005E648       1068       1  Init
0x00435ECC       1052       7  Init
0x00863E34       1020       8  ACL Header
0x00429760       1016       1  Init
0x0046C51C       1016       8  Init
0x008F029C       1016       1  Init
0x010981D8        992       1  Init
0x008A1490        976      13  Cond Debug definition
0x0045DDD4        976      13  Init
0x010DBDF4        956       2  Init
0x0006BBB8        944       1  Init
0x00783C30        920      10  CDP Protocol
0x00864D14        916       1  String-DB owners
0x00864D3C        916       1  String-DB contexts
0x004C2D44        916       1  VUR_DRV_TCAM_FAIL
0x004CC3A0        916       1  VUR_MGR_ARP_THROTTLE
0x00093880        916       1  Mat Port List Chunk
0x00136538        916       1  Init
0x00E8CF9C        916       1  SNMP VB CHUNK
0x00F5FFD4        916       1  UDLR hwsb list element
0x005DB008        916       1  KMI pyld chunk pool
0x005DB188        916       1  KMI key mgr profile chunk pool
0x005DB1B8        916       1  KMI ipv6 delete chunk pool
0x0024688C        916       1  mac notify history
0x0049FAB4        916       1  VFM L4Op Lists
0x0020C61C        916       1  HMAT Multicast Cookie
0x004C2D6C        916       1  VUR_DRV_HWD_FAIL
0x004CC328        916       1  VUR_FIB_INFO
0x0007B690        916       1  IP Cache Info Chunk
0x00493070        916       1  VFM Filter Use
0x0049CE90        916       1  VFM VLMAP ACLs
0x007FEEA0        908       1  EXEC ACCT LISTS
0x00E88EFC        904       7  Init
0x00871BB0        892      13  Init
0x0064E7D0        884       1  crypto VDI
0x00AF46F0        864       4  HWIDB_SB: ip feature
0x006DBD9C        860       5  Init
0x007836DC        856      10  CDP Protocol
0x00A91840        844       1  IPC Seat Manager
0x00A91858        844       1  IPC Seat Manager
0x00E9E584        844       1  Spanning Tree Opt Tree Block
0x007EA3A4        836       1  LOGIN ACC LISTS
0x00CACA68        816       4  HTTP CORE
0x0084A998        816       4  Ion New Block
0x007FEEB8        812       1  NET ACCT LISTS
0x00414A4C        768      11  vegas_flash init
0x002E8BC8        768       6  Init
0x007EA3F4        764       1  SHELL AUTHOR LISTS
0x0054A4C0        764       1  Init
0x00D63238        764       1  OSPF sw subblock
0x00D40774        764       1  Init
0x00414A2C        756      11  vegas_flash init
0x005DB5CC        756       3  KMI Msg Stats
0x00414A1C        748      11  vegas_flash init
0x0030B030        736       8  QM_FEAT
0x0126F344        728       2  Hashtable Buckets
0x00CAA594        712       4  TPLUS
0x00A88C40        704       8  IPC Thread
0x00C71B04        704       4  VPN ecomm list
0x007DDA80        696      10  Virtual Exec
0x004AD654        680      10  Init
0x00C6C780        660       5  Init
0x00C9B998        656       2  ATF nbr
0x00FE3A00        656       1  Init
0x0093C284        644       7  Init
0x004ACF20        644       9  Init
0x004ACE3C        640       8  Init
0x00DEA0A8        640       4  POLICYMAP_MODULE
0x00C86FC0        640       5  Init
0x001AC940        640       5  Event Dampening Library
0x0125CFB8        636       9  Init
0x007FFD78        632       7  AAA MI SG NAME
0x00A0BBBC        624       1  HTTP
0x008322B0        620       1  AAA Server handle
0x0125CFD0        612       9  Init
0x0125CFFC        612       9  Init
0x0062CC60        608       1  Init
0x006E525C        604       1  Init
0x008604B4        600       2  event_trace_tbs
0x00D47F0C        592       1  Init
0x0052A7F0        584       2  Init
0x010DB29C        580       5  crypto_handle_table
0x005225D0        580       1  Init
0x008FAA3C        580       1  Init
0x00863E48        576       8  Init
0x0030B07C        560       8  QM_MAPNAME
0x000DC010        556       1  TTY Output Buf
0x004C1828        556       1  Init
0x00D3CBBC        556       1  Init
0x0068AE7C        556       1  AUTH-PROXY wlist hash
0x008ED90C        556       1  Init
0x0093A328        552       6  Init
0x0030B12C        552       6  QM_FEAT
0x00D3B3A0        552       1  Init
0x00FDB78C        548       8  Init
0x010DA060        548       1  crypto sw pk proc
0x008473A8        544       4  SDB String
0x00A7B780        544       1  IPC Split Init level
0x008473DC        544       4  SDB String
0x00220620        544       1  Vegas jade lockup chk msag
0x00152B30        544       8  Init
0x005926A0        544       1  IPSEC If MAP Chunk
0x005926F0        544       1  IPv6 IPsec ACE struct chunk
0x00D3B3B8        544       1  Init
0x00F64B8C        540       3  CCA Component
0x00A7B4F8        540       1  IPC Global Info
0x00A7B564        540       1  IPC Global Cache Info
0x00D6CF74        528       3  OSPF-10 Router
0x00972CF0        528       4  bg context
0x00E8C308        524       7  Init
0x009B3F80        520       2  CEF:test fib entry sbs
0x0094C9D8        520       2  CEF: table walks
0x008FB630        516       3  Init
0x00A1C6C4        512       4  HTTP
0x009725BC        504       6  bg event reg
0x002E88E4        504       4  Init
0x00972318        504       6  bg event reg
0x00831118        504       2  AAA Public Server Group
0x008573F0        504       5  TTY timer block
0x000D9AFC        500       1  Virtual Exec
0x0002C3E0        496       2  Cluster Base
0x00490AB8        488       6  Init
0x00CA03D0        484       2  ATF v4 query
0x002FA830        480       4  Init
0x004AD184        480       6  Init
0x00443F94        480       1  Init
0x008A7318        476       7  Init
0x008A7340        476       7  Init
0x008A7364        476       7  Init
0x0086AB5C        476       1  Chain Cache Nodes
0x0054E5E8        476       1  VPBR_NH
0x000E0D4C        476       1  vlmap chunks
0x00152CEC        476       7  Init
0x008F3254        476       1  Chain Cache No
0x0048E7B4        476       1  VFM VLAN/idb lists
0x004AFC0C        476       1  VLAN/idb pairs
0x006DC8A4        476       1  BGP SNPA-chunk
0x00991F30        460       5  Init
0x00A51E28        460       1  Init
0x00C86FE0        460       5  Init
0x006E3A20        460       5  Init
0x001ACC48        460       5  Event Dampening Library
0x00D4A914        456       5  Clock buffer
0x007FF488        456       2  AAA SG HEAD
0x0030B180        452       6  QM_MAPNAME
0x011323F4        448       1  Init
0x00A8688C        444       1  IPC Msg Cache
0x0109216C        444       1  HTTP CORE
0x00C5FF64        440       5  Router Init
0x00995D7C        420       5  Init
0x00D001BC        420       5  FIB acl subblock
0x00A89864        416       6  IPC Name String
0x00FB8420        408       1  Watched Message Queue
0x00658150        408       2  AAA MLIST
0x0086AB34        408       1  tokenQ node
0x00876A88        408       6  Init
0x00876A98        408       6  Init
0x007965A8        408       6  Init
0x00FDB5C4        408       6  Init
0x00876AA8        408       6  Init
0x004AD1BC        408       6  Init
0x00006FF4        404       1  Init
0x00008B9C        404       1  Init
0x00D40784        404       1  Init
0x00007004        404       1  Init
0x00008BAC        404       1  Init
0x008FABFC        400       5  Init
0x00DDD044        400       4  Qos hw subblock
0x00DDD0C4        400       4  Qos sw subblock
0x001AC5FC        400       5  Event Dampening Library
0x00307B20        392       3  QM_IFPOL
0x005DAFD8        388       1  KMI msg chunk pool
0x000BCC1C        388       1  Syslog History
0x0084AD78        380       4  Ion Password
0x00666C70        380       1  ADJ: NULL adjacency
0x006F18F0        380       5  Init
0x006DBC74        380       5  Init
0x006D7200        380       5  Init
0x0021AAF4        376       4  Init
0x010939F8        376       2  HTTP CORE
0x0035DE3C        372       1  Init
0x00248688        368       4  Init
0x006F191C        364       5  Init
0x00991F7C        360       5  Init
0x0126B000        360       4  Init
0x004ACAC0        360       5  Init
0x0084C0A8        360       2  AAA Request Data
0x0063DB9C        360       5  ipsmRing
0x00C86FD8        356       5  Init
0x0074A3D0        352       2  Init
0x00782134        352       2  CDP Protocol
0x0063DBD8        352       5  Init
0x008785A8        340       1  PRC Blocks
0x00F6D070        340       5  TW Wheels
0x00436514        340       1  VRA User Handles
0x0053FD8C        340       1  FBM Vlan List Chunk
0x004CC378        340       1  VUR_ADJ_SINGLE_INFO
0x005D5F04        332       1  Crypto Dynamic Template ACL entry
0x00658714        328       2  AAA MLIST
0x00A9B9A4        328       4  OSPF-10 Router
0x00860490        320       2  event_trace_tbs
0x002E885C        320       4  Init
0x002E88F8        320       4  Init
0x0030AEBC        308       3  Init
0x00F71DB8        300       1  Init
0x0041E544        300       1  Init
0x004CC300        300       1  VUR_MGR_ICMP_REDIRECT_Q_CHUNK
0x00C4561C        300       1  Init
0x00F6D648        300       1  TW timer Table
0x002468E8        300       1  Init
0x00FE3A5C        300       1  Init
0x01021120        300       1  IP SLAs LatestSetError
0x00C735EC        300       1  VPN record
0x006DC994        300       1  BGP vpnv4 soo
0x00D4A490        300       1  Init
0x00C455FC        300       1  Init
0x0065842C        296       2  AAA MLIST
0x00992064        292       4  Init
0x0045ADD0        288       4  Init
0x002FAB54        288       4  Init
0x0004516C        288       3  Init
0x008715D8        284       1  Init
0x0030BBA0        284       3  QM_ACLS
0x007E6AF4        280       4  AAA Secrettype encrypt
0x00784EF4        280       2  CDP Protocol
0x00A8124C        276       4  IPC Name
0x00C82644        276       3  Init
0x008EFD0C        272       2  Init
0x004B4CC4        272       1  VMat Port List Chunk
0x00992114        272       4  Init
0x009921AC        272       4  Init
0x007E6ABC        272       4  AAA Secrettype
0x00D13F34        272       1  Init
0x00C83828        272       4  Init
0x0020C5F4        272       1  HMAT Unicast Cookie
0x0053FD64        272       1  FBM Port List Chunk
0x009920C0        272       4  Init
0x00992160        272       4  Init
0x009921F8        272       4  Init
0x0030CA20        264       3  QM_IFACL
0x00782BE8        260       1  Init
0x00074EE0        256       1  DNS Host
0x0005F814        256       1  Init
0x00E8CB84        252       1  Init
0x00E2FE18        252       1  RIP i_pdb procinfo
0x00783850        252       3  CDP Protocol
0x00E2FF14        252       1  RIP pdb info
0x009FBE24        240       3  HTTP
0x0084C110        240       2  AAA Attr String
0x00C9E00C        232       1  Init
0x0013772C        228       3  Init
0x0054A418        224       1  Init
0x0040958C        220       1  vegas_flash init
0x0007B50C        220       1  Init
0x0007B524        220       1  Init
0x00CAFF70        220       2  Syslog
0x00A40240        216       3  Init
0x00551BF4        216       2  Init
0x010DA044        216       1  crypto sw pk proc
0x00865A10        212       1  SDB Owner info
0x006DC41C        212       1  Init
0x008B1164        212       3  Init
0x00CDD1A0        208       2  TCP Timer
0x00F64E74        204       3  CCA UserType
0x00553AA0        204       3  Init
0x000649E0        204       3  Init
0x00045144        204       3  Init
0x005DB584        204       3  KMI Client Table
0x008FB5F4        204       3  Init
0x010DA054        204       1  crypto sw pk proc
0x00C44314        204       3  Virtual Exec
0x00C82664        204       3  Init
0x000649B0        204       3  Init
0x00E75AB4        204       3  Init
0x010DC260        204       1  Init
0x000BEBA4        200       2  TAL: rtree aux
0x00D8866C        192       2  OSPF-10 Router
0x008310E0        192       2  AAA nvgend sg elt
0x000BE828        192       2  TAL: control block
0x0126F32C        188       2  Hashtable
0x00831310        188       2  AAA pub SG name
0x002EA830        188       2  VFM Deferred Update
0x007FF6D8        188       1  AAA SG HQ
0x0088C618        180       1  Init
0x0054A370        176       1  Init
0x00D45218        176       1  Init
0x0054A3C8        176       1  Init
0x001D3DE8        172       1  MAB session handle table
0x006C4D7C        172       1  BGP Router
0x006C4D9C        172       1  BGP Router
0x006C4DBC        172       1  BGP Router
0x00D45230        172       1  Init
0x00D45248        172       1  Init
0x00D45260        172       1  Init
0x006C4D3C        172       1  BGP Router
0x006C4D5C        172       1  BGP Router
0x0008D740        168       2  Init
0x00857558        168       2  TTYBKG Timer
0x001FD0D4        168       2  EAP LL Auth Config
0x000BE880        168       2  TAL: tree control
0x0098ABD8        168       2  Init
0x009BDBD0        168       2  CEF: Table rate Monitor Stats
0x00FD9EB4        168       2  Init
0x000BEA9C        168       2  TAL: tree control
0x00A83770        164       1  IPC Seat
0x008717F0        164       1  Init
0x00D40794        164       1  Init
0x006616F0        160       1  AAA Attr List
0x00FDBAF0        160       1  Init
0x000BEC44        160       2  TAL: rtree control block
0x0093DBBC        156       1  *Init*
0x00C73574        156       1  VRF sub record
0x009920A0        156       1  Init
0x0093DC38        156       1  Init
0x00C62D90        152       2  Init
0x001FD01C        152       2  EAP LL Context
0x0048C678        148       1  Init
0x009679C8        148       1  Init
0x00A88074        144       1  IPC Zone
0x0003922C        144       1  shelf_info
0x00831158        144       2  AAA Public Server Group wrapper
0x0107284C        144       1  Init
0x00C540C8        144       2  OSPF-10 Router
0x00A4AAE0        144       2  Init
0x00C45174        140       2  Init
0x00F37D5C        140       1  TAC lp
0x0016A6D0        136       2  Init
0x0016A74C        136       2  Init
0x00419010        136       2  vegas_flash init
0x0084B688        136       1  Init
0x008EFA38        136       1  Init
0x00992190        136       1  Init
0x00094EC8        136       2  Init
0x0085738C        136       1  TTY timers array
0x007E6B68        136       2  AAA_Secrettype pw
0x007FF4C8        136       2  AAA SG NAME
0x00831274        136       2  AAA pub SG wrap name
0x010EE250        136       2  Init
0x00FD9FF4        136       2  Init
0x0094DB04        136       2  Init
0x0084DA38        136       2  AAA_Secrettype pw
0x00898C9C        136       2  Init
0x00FD9F68        136       2  Init
0x00992144        136       1  Init
0x00992048        136       1  Init
0x0063DA80        136       2  Init
0x00FD9EFC        136       2  Init
0x006C4D00        132       1  BGP Router
0x006DC0F4        128       1  Init
0x006DC110        128       1  Init
0x006DC12C        128       1  Init
0x006DC148        128       1  Init
0x006DC48C        128       1  Init
0x006DC4C4        128       1  Init
0x006DC4A8        128       1  Init
0x00C71E08        124       1  VPN Target VPN hash ent
0x01072888        124       1  Init
0x010752B0        124       1  Init
0x0107533C        124       1  Init
0x01261838        124       1  Init
0x00E88E6C        124       1  Init
0x000DDC8C        124       1  Virtual Exec
0x00781DA8        116       1  Cluster Base
0x00CDE994        116       1  CEF: IPv4 not-sw si
0x004D1C0C        116       1  Init
0x004A9754        116       1  Init
0x00CDE974        116       1  CEF: IPv4 not-sw cnt
0x009F7D50        116       1  HTTP
0x01227B4C        116       1  Init
0x00304648        116       1  QM_MUT
0x001B6004        116       1  Dot1x Mgr SW subblock
0x00FDBAD0        112       1  Init
0x00203B7C        108       1  EAP-MD5 session handle table
0x009F7180        108       1  HTTP
0x00037954        108       1  Init
0x0052A408        108       1  Init
0x009920F8        104       1  Init
0x009921DC        104       1  Init
0x004CC430        100       1  Init
0x0126AEA0        100       1  Init
0x0126AEB8        100       1  Init
0x00C86C5C        100       1  Init
0x0093C248         92       1  Init
0x00436460         92       1  Init
0x00E36A40         92       1  RIP: per-ribdb data
0x000BC0F4         92       1  Init
0x0046DC90         88       1  Init
0x00D53B40         88       1  Init
0x00840A8C         84       1  Init
0x002F44A4         84       1  Init
0x000BC0C0         84       1  Init
0x00871910         84       1  Init
0x00E19494         84       1  wfq state
0x00D80E9C         84       1  Init
0x00FDB2C0         84       1  Virtual Exec
0x00F4F5A0         84       1  TPLUS socket
0x010DA070         84       1  crypto sw pk proc
0x008B45C4         84       1  Virtual Exec
0x008D8E0C         84       1  Virtual Exec
0x00468FD4         84       1  Init
0x00037894         84       1  Init
0x01242D78         84       1  SSH memory
0x00FDA328         84       1  Virtual Exec
0x00C9A850         84       1  Virtual Exec
0x00840AD0         80       1  Init
0x0041163C         80       1  vegas_flash init
0x004131CC         80       1  vegas_flash init
0x004131E8         80       1  vegas_flash init
0x00413760         80       1  vegas_flash init
0x0041377C         80       1  vegas_flash init
0x00C741A4         80       1  Init
0x0108E76C         80       1  Init
0x00C9B940         80       1  Init
0x00ADE878         80       1  ippeerinfo
0x00610DE0         80       1  Crypto IKMP
0x00610DCC         80       1  Crypto IKMP
0x0060CBA8         80       1  Crypto IKMP
0x00E6B834         80       1  Init
0x00610E0C         80       1  Crypto IKMP
0x00610DFC         80       1  Crypto IKMP
0x0009E85C         80       1  Init
0x0087D8FC         76       1  Init
0x0082FF54         76       1  Init
0x001DC870         76       1  Init
0x00BA7C8C         76       1  Init
0x00C7D644         76       1  Init
0x005D36C4         76       1  CE info table
0x003E68A8         76       1  UDLD
0x00939074         76       1  Entity MIB API
0x00937034         76       1  Entity MIB API
0x00CCB648         76       1  Init
0x00CA0330         76       1  Init
0x006DC180         76       1  Init
0x00C9B92C         76       1  Init
0x006C4D1C         76       1  BGP Router
0x00BC1F88         72       1  Init
0x00304678         72       1  Init
0x006CADA8         72       1  BGP Router
0x00136644         72       1  VUR_MGR bg process
0x008EF7F4         68       1  Init
0x008EFB38         68       1  Init
0x008EFBA4         68       1  Init
0x00840A64         68       1  Init
0x00840AA8         68       1  Init
0x007EA504         68       1  AAA PROMPT P1
0x007EA520         68       1  AAA PROMPT U1
0x004115C8         68       1  vegas_flash init
0x0041332C         68       1  vegas_flash init
0x004138B4         68       1  vegas_flash init
0x00416F24         68       1  vegas_flash init
0x0042973C         68       1  Init
0x004297BC         68       1  Init
0x002F4490         68       1  Init
0x001379F8         68       1  Init
0x008EF944         68       1  Init
0x008EF9DC         68       1  Init
0x0126F9F0         68       1  Iterator
0x00A6C260         68       1  Init
0x009B5390         68       1  CEF: FIB subtree context client
0x00F70C9C         68       1  Init
0x0007A7B0         68       1  Init
0x010DC284         68       1  Init
0x00E559E0         68       1  Init
0x00E55534         68       1  Init
0x00E5574C         68       1  Init
0x008311A0         68       1  AAA pub SG servers
0x008311E8         68       1  AAA pub SG server stats
0x006A5728         68       1  workqueue_create
0x010D9B88         68       1  Init
0x00633B64         68       1  Init
0x00633B74         68       1  Init
0x0113276C         68       1  Software engine status
0x000D1C44         68       1  Init
0x002CB8E4         68       1  Init
0x0064E92C         68       1  crypto VDI avl node
0x00FDB9E0         68       1  Init
0x00D13F48         68       1  Init
0x0108E020         68       1  Init
0x01061B3C         68       1  Init
0x01072830         68       1  Init
0x010752F8         68       1  Init
0x010728B4         68       1  Init
0x0016E708         68       1  Init
0x00AECF80         68       1  Init
0x00CE56D0         68       1  CEF: IP secondary address
0x00D55A60         68       1  Init
0x00DABAF4         68       1  Init
0x00D55A98         68       1  Init
0x00D55AC0         68       1  Init
0x008D67C4         68       1  Bitfield pool
0x00D60CE0         68       1  Init
0x0000C988         68       1  Init
0x00E6B850         68       1  Init
0x0082EABC         68       1  Init
0x0096F240         68       1  fib defnet source sb
0x00CD416C         68       1  Virtual Exec
0x002F44B8         68       1  Init
0x002F447C         68       1  Init
0x001FFEB0         68       1  EAP Method Context
0x0077E5BC         68       1  CDP Protocol
0x0126FA28         68       1  Iterator Hash Entry
0x00CDF308         68       1  Init
0x012417D4         68       1  Init
0x008EF8D0         68       1  Init
0x0127B3D0         68       1  Linear ID desc
0x00E87070         68       1  Init
0x00E54274         68       1  Init
0x00E542AC         68       1  Init
0x00E55AA8         68       1  Init
0x00E55638         68       1  Init
0x0000C1F4         68       1  Init
0x00F64D38         68       1  CCA Notification Flags
0x00E37E30         68       1  Init
0x00E38F94         68       1  Init
0x00937028         68       1  Entity MIB API
0x00877C08         68       1  Init
0x00937040         68       1  Entity MIB API
0x0093704C         68       1  Entity MIB API
0x00937064         68       1  Entity MIB API
0x00152C44         68       1  Init
0x0084C140         68       1  AAA Attr String
0x00D55A4C         68       1  Init
0x00D55A84         68       1  Init
0x00D55AAC         68       1  Init
0x00D55EB4         68       1  Init
0x00D60C74         68       1  Init
0x000378F4         68       1  Init
0x0082EAE8         68       1  Init
0x0084BB40         68       1  Init
0x0084BB18         68       1  Init
0x00897E5C         68       1  Virtual Exec
0x00897DDC         68       1  Virtual Exec
0x00849978         68       1  Virtual Exec
0x00F48D58         68       1  AAA AUTHEN Username
0x00057CEC         68       1  Init
0x0008CFA0         68       1  SNMP IDB
0x000F7CFC         68       1  Init
Allocator PC Summary for: I/O
    PC          Total   Count  Name
0x00158568    3301812    1924  *Packet Data*
0x0045E0C4      12684      13  Init
0x0045E6F4       8088       2  Init
0x0045ADE4       1728       4  Init
0x0045D86C       1688       2  Init
0x0045AFE8       1660       3  Init
0x0045DA2C        844       1  Init
#                         show memory dead
Processor    1D2A360    36779168    35868872      910296      192976      692432
--More--
          Processor memory
Address      Bytes     Prev     Next Ref     PrevF    NextF Alloc PC  what
01D4283C 0000000040 01D427E8 01D42890 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0206A704 0000000024 0206A3B8 0206A748 001  -------- -------- 004115C8  vegas_flash init
0206A748 0000001536 0206A704 0206AD74 001  -------- -------- 004115F8  vegas_flash init
0206AD74 0000000036 0206A748 0206ADC4 001  -------- -------- 0041163C  vegas_flash init
0206ADC4 0000000036 0206AD74 0206AE14 001  -------- -------- 004131CC  vegas_flash init
0206AE14 0000000036 0206ADC4 0206AE64 001  -------- -------- 004131E8  vegas_flash init
0206AE64 0000001512 0206AE14 0206B478 001  -------- -------- 0041328C  vegas_flash init
0206B478 0000000024 0206AE64 0206B4BC 001  -------- -------- 0041332C  vegas_flash init
0206B4BC 0000000036 0206B478 0206B50C 001  -------- -------- 00413760  vegas_flash init
0206B50C 0000000036 0206B4BC 0206B55C 001  -------- -------- 0041377C  vegas_flash init
0206B55C 0000001500 0206B50C 0206BB64 001  -------- -------- 0041381C  vegas_flash init
0206BB64 0000000024 0206B55C 0206BBA8 001  -------- -------- 004138B4  vegas_flash init
0206BBA8 0000000176 0206BB64 0206BC84 001  -------- -------- 0040958C  vegas_flash init
0206BC84 0000002000 0206BBA8 0206C480 001  -------- -------- 00409694  vegas_flash init
0206C480 0000005000 0206BC84 0206D834 001  -------- -------- 004097D8  Flashfs Sector buffers
0206D834 0000001024 0206C480 0206DC60 001  -------- -------- 0040980C  vegas_flash init
0206DC60 0000000040 0206D834 0206DCB4 001  -------- -------- 00A3DFDC  vegas_flash init
0206DCB4 0000000040 0206DC60 0206DD08 001  -------- -------- 00A3E00C  vegas_flash init
0206DD08 0000001768 0206DCB4 0206E41C 001  -------- -------- 00A45F18  vegas_flash init
0206E41C 0000000024 0206DD08 0206E460 001  -------- -------- 00419010  vegas_flash init
0206E460 0000000040 0206E41C 0206E4B4 001  -------- -------- 00A3E00C  vegas_flash init
0206E4B4 0000000040 0206E460 0206E508 001  -------- -------- 00A3DFDC  vegas_flash init
0206E508 0000000024 0206E4B4 0206E54C 001  -------- -------- 00414A1C  vegas_flash init
0206E54C 0000000532 0206E508 0206E78C 001  -------- -------- 0040174C  vegas_flash init
0206E78C 0000000532 0206E54C 0206E9CC 001  -------- -------- 0040174C  vegas_flash init
0206E9CC 0000000024 0206E78C 0206EA10 001  -------- -------- 00414A2C  vegas_flash init
0206EC50 0000000532 0206EA10 0206EE90 001  -------- -------- 0040174C  vegas_flash init
0206EE90 0000000024 0206EC50 0206EED4 001  -------- -------- 00416F24  vegas_flash init
0206EED4 0000000040 0206EE90 0206EF28 001  -------- -------- 00A3DFDC  vegas_flash init
0206EF28 0000000040 0206EED4 0206EF7C 001  -------- -------- 00A3E00C  vegas_flash init
0206F000 0000000044 0206EF7C 0206F058 001  -------- -------- 00414A4C  vegas_flash init
0206F058 0000000024 0206F000 0206F09C 001  -------- -------- 00414A2C  vegas_flash init
0206F09C 0000000024 0206F058 0206F0E0 001  -------- -------- 00414A1C  vegas_flash init
0206F0E0 0000000024 0206F09C 0206F124 001  -------- -------- 00414A4C  vegas_flash init
0206F124 0000000024 0206F0E0 0206F168 001  -------- -------- 00414A2C  vegas_flash init
--More--                            Address      Bytes     Prev     Next Ref     PrevF    NextF Alloc PC  what
0206F168 0000000024 0206F124 0206F1AC 001  -------- -------- 00414A1C  vegas_flash init
0206F1AC 0000000024 0206F168 0206F1F0 001  -------- -------- 00414A4C  vegas_flash init
0206F1F0 0000000028 0206F1AC 0206F238 001  -------- -------- 00414A2C  vegas_flash init
0206F238 0000000024 0206F1F0 0206F27C 001  -------- -------- 00414A1C  vegas_flash init
0206F27C 0000000024 0206F238 0206F2C0 001  -------- -------- 00414A4C  vegas_flash init
0206F2C0 0000000024 0206F27C 0206F304 001  -------- -------- 00414A2C  vegas_flash init
0206F304 0000000024 0206F2C0 0206F348 001  -------- -------- 00414A1C  vegas_flash init
0206F348 0000000024 0206F304 0206F38C 001  -------- -------- 00414A4C  vegas_flash init
0206F38C 0000000024 0206F348 0206F3D0 001  -------- -------- 00414A2C  vegas_flash init
022E9F80 0000000080 022E9F2C 022E9FFC 001  -------- -------- 000B28E0  State Machine debug meta data
022F68D0 0000000532 022F682C 022F6B10 001  -------- -------- 0040174C  Virtual Exec
022F6CCC 0000000024 022F6C78 022F6D10 001  -------- -------- 007DDA80  Virtual Exec
022FAAF8 0000000532 022F8ACC 022FAD38 001  -------- -------- 0040174C  Virtual Exec
022FCD68 0000000040 022FCD14 022FCDBC 001  -------- -------- 00C8DA70  IDB: IPINFO
022FCDBC 0000000048 022FCD68 022FCE18 001  -------- -------- 00C437BC  IPRTG SWSB
022FD0D8 0000000532 022FD074 022FD318 001  -------- -------- 0040174C  Virtual Exec
022FF030 0000000028 022FEFEC 022FF078 001  -------- -------- 007DDA80  Virtual Exec
02359CEC 0000000028 02359C80 02359D34 001  -------- -------- 007FFD78  AAA MI SG NAME
023730F0 0000000532 02373034 02373330 001  -------- -------- 0040174C  Virtual Exec
02373A9C 0000000040 023737E4 02373AF0 001  -------- -------- 000B2928  State Machine debug data
02373AF0 0000000080 02373A9C 02373B6C 001  -------- -------- 002857A4  PM vp_data
02373B6C 0000000040 02373AF0 02373BC0 001  -------- -------- 000B2928  State Machine debug data
02378ECC 0000000224 02378E68 02378FD8 001  -------- -------- 0127E93C  Virtual Exec
0237A60C 0000000124 0237A5B8 0237A6B4 001  -------- -------- 0008D6A0  Virtual Exec
0237A7FC 0000000080 0237A790 0237A878 001  -------- -------- 00D4A914  Clock buffer
0237AB74 0000000532 0237AB20 0237ADB4 001  -------- -------- 0040174C  Virtual Exec
0237B088 0000000028 0237AFA8 0237B0D0 001  -------- -------- 007DDA80  Virtual Exec
0237D340 0000000040 0237D2F0 0237D394 001  -------- -------- 000B28E0  State Machine debug meta data
0237D540 0000000456 0237D490 0237D734 001  -------- -------- 008F342C  Chain Cache No
0237E8F8 0000000080 0237E8A4 0237E974 001  -------- -------- 000B28E0  State Machine debug meta data
0237EA20 0000000532 0237E974 0237EC60 001  -------- -------- 0040174C  Virtual Exec
0237EDB4 0000000040 0237ED08 0237EE08 001  -------- -------- 002B6DB8  Virtual Exec
0237EE08 0000000452 0237EDB4 0237EFF8 001  -------- -------- 008F333C  Chain Cache No
02380CC0 0000000532 02380C6C 02380F00 001  -------- -------- 0040174C  Virtual Exec
023813E4 0000000532 02381050 02381624 001  -------- -------- 0040174C  Virtual Exec
02384CBC 0000000532 02384928 02384EFC 001  -------- -------- 0040174C  Virtual Exec
02384F50 0000000064 02384EFC 02384FBC 001  -------- -------- 0000A28C  Virtual Exec
02384FBC 0000000104 02384F50 02385050 001  -------- -------- 000B2928  State Machine debug data
0238576C 0000000040 023856F0 023857C0 001  -------- -------- 000B28E0  State Machine debug meta data
0238580C 0000000040 023857C0 02385860 001  -------- -------- 000B28E0  State Machine debug meta data
023869F4 0000000032 0238692C 02386A40 001  -------- -------- 00E5E88C  Virtual Exec
02387550 0000000532 023874BC 02387790 001  -------- -------- 0040174C  Virtual Exec
023A00DC 0000000532 023A0010 023A031C 001  -------- -------- 0040174C  Virtual Exec
023A0418 0000000040 023A03C4 023A046C 001  -------- -------- 000B28E0  State Machine debug meta data
023A0ED4 0000000040 023A0E84 023A0F28 001  -------- -------- 00AEED88  Virtual Exec
023A21B4 0000000484 023A2160 023A23C4 001  -------- -------- 008F333C  Chain Cache No
023A59FC 0000000040 023A5668 023A5A50 001  -------- -------- 000B2928  State Machine debug data
023A7684 0000000532 023A75E8 023A78C4 001  -------- -------- 0040174C  Virtual Exec
023A7C58 0000000532 023A78C4 023A7E98 001  -------- -------- 0040174C  Virtual Exec
023A8048 0000000532 023A7F90 023A8288 001  -------- -------- 0040174C  Virtual Exec
023A8D94 0000000532 023A8CC4 023A8FD4 001  -------- -------- 0040174C  Virtual Exec
023A9530 0000000532 023A9490 023A9770 001  -------- -------- 0040174C  Virtual Exec
023A9D38 0000000532 023A9C58 023A9F78 001  -------- -------- 0040174C  Virtual Exec
023AA28C 0000000100 023AA210 023AA31C 001  -------- -------- 0003922C  shelf_info
023AA464 0000000532 023AA38C 023AA6A4 001  -------- -------- 0040174C  Virtual Exec
023AA6A4 0000000532 023AA464 023AA8E4 001  -------- -------- 0040174C  Virtual Exec
023AC690 0000000040 023AC63C 023AC6E4 001  -------- -------- 0097BBC8  Virtual Exec
023ACB14 0000000452 023ACAC0 023ACD04 001  -------- -------- 008F342C  Chain Cache No
023AD858 0000000532 023AD7E0 023ADA98 001  -------- -------- 0040174C  Virtual Exec
023ADD0C 0000000532 023ADA98 023ADF4C 001  -------- -------- 0040174C  Virtual Exec
023AEA60 0000000532 023AE9BC 023AECA0 001  -------- -------- 0040174C  Virtual Exec
023AED48 0000000212 023AECF4 023AEE48 001  -------- -------- 00074EE0  DNS Host
023AF060 0000000040 023AEFE4 023AF0B4 001  -------- -------- 00ABE170  IP Sticky ARP subblock
023AFB78 0000000080 023AFAEC 023AFBF4 001  -------- -------- 004CFA94  DWL SWSB
023B05D8 0000000288 023B058C 023B0724 001  -------- -------- 0041B3E8  Virtual Exec
023B2984 0000000532 023B2938 023B2BC4 001  -------- -------- 0040174C  Virtual Exec
023B32EC 0000000080 023B32A4 023B3368 001  -------- -------- 002857A4  PM vp_data
023B3368 0000000040 023B32EC 023B33BC 001  -------- -------- 000B2928  State Machine debug data
023B33BC 0000000080 023B3368 023B3438 001  -------- -------- 002857A4  PM vp_data
023B3438 0000000040 023B33BC 023B348C 001  -------- -------- 000B2928  State Machine debug data
023B3E80 0000000064 023B3E38 023B3EEC 001  -------- -------- 0000A28C  Virtual Exec
023B3EEC 0000000064 023B3E80 023B3F58 001  -------- -------- 0000A28C  Virtual Exec
023B4C68 0000000040 023B4C14 023B4CBC 001  -------- -------- 0097BCC4  Virtual Exec
0246EAFC 0000000068 0246EAAC 0246EB6C 001  -------- -------- 00871C9C  Parser Linkage
026313E4 0000001632 026303B8 02631A70 001  -------- -------- 00A81220  IPC Port
0267DBB0 0000000056 0267DB60 0267DC14 001  -------- -------- 00873EA8  Parser Mode
0267DC14 0000000036 0267DBB0 0267DC64 001  -------- -------- 00873F38  Parser Mode Q2
026E6028 0000000080 026E5FD8 026E60A4 001  -------- -------- 002857A4  PM vp_data
026E60A4 0000000040 026E6028 026E60F8 001  -------- -------- 000B2928  State Machine debug data
026E6558 0000000532 026E6510 026E6798 001  -------- -------- 0040174C  Virtual Exec
026E6798 0000000040 026E6558 026E67EC 001  -------- -------- 000B28E0  State Machine debug meta data
026E69C4 0000000064 026E6938 026E6A30 001  -------- -------- 0000A28C  Virtual Exec
026E6A30 0000000064 026E69C4 026E6A9C 001  -------- -------- 0000A28C  Virtual Exec
026E6A9C 0000000064 026E6A30 026E6B08 001  -------- -------- 0000A28C  Virtual Exec
026E6B08 0000000040 026E6A9C 026E6B5C 001  -------- -------- 000B2928  State Machine debug data
026E6FD4 0000000532 026E6F8C 026E7214 001  -------- -------- 0040174C  Virtual Exec
026E7810 0000000096 026E7798 026E789C 001  -------- -------- 00181640  Virtual Exec
026E89BC 0000000532 026E8954 026E8BFC 001  -------- -------- 0040174C  Virtual Exec
026EA30C 0000000532 026E9F78 026EA54C 001  -------- -------- 0040174C  Virtual Exec
0270A2E0 0000000040 0270A210 0270A334 001  -------- -------- 00ABE170  IP Sticky ARP subblock
027C5A8C 0000000532 027C596C 027C5CCC 001  -------- -------- 0040174C  Virtual Exec
027C6668 0000000532 027C62D4 027C68A8 001  -------- -------- 0040174C  Virtual Exec
027C69FC 0000000532 027C69A0 027C6C3C 001  -------- -------- 0040174C  Virtual Exec
027C7364 0000000040 027C6FD0 027C73B8 001  -------- -------- 000B2928  State Machine debug data
027C73B8 0000000080 027C7364 027C7434 001  -------- -------- 002857A4  PM vp_data
027C7818 0000000532 027C7484 027C7A58 001  -------- -------- 0040174C  Virtual Exec
027CA40C 0000000532 027CA340 027CA64C 001  -------- -------- 0040174C  Virtual Exec
027CB2A4 0000001488 027CB184 027CB8A0 001  -------- -------- 0016597C  *Software IDB*
027CBAF4 0000000532 027CBAA4 027CBD34 001  -------- -------- 0040174C  Virtual Exec
027CF6C0 0000000080 027CF504 027CF73C 001  -------- -------- 0041B9E8  Virtual Exec
027CFD6C 0000000024 027CFC8C 027CFDB0 001  -------- -------- 00C44314  Virtual Exec
027D04C8 0000000040 027D0478 027D051C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
027D9EF0 0000000028 027D9EA0 027D9F38 001  -------- -------- 00A8124C  IPC Name
027DB6D0 0000000040 027DB62C 027DB724 001  -------- -------- 000B28E0  State Machine debug meta data
027F0304 0000000024 027F02C0 027F0348 001  -------- -------- 00C44314  Virtual Exec
027FEBE4 0000000024 027FEBA0 027FEC28 001  -------- -------- 00C44314  Virtual Exec
028C9358 0000000432 028C92A8 028C9534 001  -------- -------- 008F342C  Chain Cache No
028D6E24 0000000032 028D6DD0 028D6E70 001  -------- -------- 00A89864  IPC Name String
028D9BA8 0000000532 028D9AD4 028D9DE8 001  -------- -------- 0040174C  Virtual Exec
028DAFC4 0000000040 028DAF6C 028DB018 001  -------- -------- 000B28E0  State Machine debug meta data
028E0F14 0000000040 028E0E84 028E0F68 001  -------- -------- 002CB9A0  PM app data
028E1208 0000000040 028E115C 028E125C 001  -------- -------- 002CB9A0  PM app data
028E125C 0000000032 028E1208 028E12A8 001  -------- -------- 007DDA80  Virtual Exec
028E9300 0000000532 028E92B8 028E9540 001  -------- -------- 0040174C  Virtual Exec
028EA954 0000000100 028EA8CC 028EA9E4 001  -------- -------- 00181640  Virtual Exec
0292EAEC 0000000040 0292EA6C 0292EB40 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0292EB40 0000000532 0292EAEC 0292ED80 001  -------- -------- 0040174C  Virtual Exec
0292ED80 0000000040 0292EB40 0292EDD4 001  -------- -------- 002CB9A0  PM app data
0292FA10 0000000532 0292F980 0292FC50 001  -------- -------- 0040174C  Virtual Exec
0292FF9C 0000000532 0292FEF0 029301DC 001  -------- -------- 0040174C  Virtual Exec
0294199C 0000000040 02941948 029419F0 001  -------- -------- 004CFB0C  Virtual Exec
02942100 0000000040 029420B4 02942154 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0294224C 0000000040 029421FC 029422A0 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02942A50 0000000204 029429FC 02942B48 001  -------- -------- 0127E93C  TCP Command
02944168 0000000048 029440C4 029441C4 001  -------- -------- 008573F0  TTY timer block
0295BAD8 0000000048 0295BA84 0295BB34 001  -------- -------- 008573F0  TTY timer block
0295CC30 0000000040 0295CBE0 0295CC84 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0295CE20 0000000040 0295CDD8 0295CE74 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0295CF18 0000000040 0295CEC8 0295CF6C 001  -------- -------- 00D4A914  Clock buffer
0295D9A8 0000000080 0295D904 0295DA24 001  -------- -------- 000863A0  SNMP IDB
02995758 0000000304 02995704 029958B4 001  -------- -------- 0097C16C  CEF: FIBIDB
029AA8CC 0000000040 029AA828 029AA920 001  -------- -------- 0041B92C  Virtual Exec
029C6310 0000000532 029C14C4 029C6550 001  -------- -------- 0040174C  Virtual Exec
029C68F8 0000000076 029C683C 029C6970 001  -------- -------- 00F07458  Virtual Exec
029C6F18 0000000048 029C6CFC 029C6F74 001  -------- -------- 008573F0  TTY timer block
029C72F8 0000000040 029C723C 029C734C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
029C7960 0000000080 029C790C 029C79DC 001  -------- -------- 002B6DB8  Virtual Exec
029CDF78 0000000452 029CDED4 029CE168 001  -------- -------- 008F333C  Chain Cache No
029CEE8C 0000000080 029CEE38 029CEF08 001  -------- -------- 002857A4  PM vp_data
029D26A0 0000000032 029D265C 029D26EC 001  -------- -------- 000B28E0  State Machine debug meta data
02A0AAF0 0000000040 02A0AAA0 02A0AB44 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02A0B874 0000000496 02A0B820 02A0BA90 001  -------- -------- 008F342C  Chain Cache No
02A1DAA8 0000000024 02A1D9F4 02A1DAEC 001  -------- -------- 007DDA80  Virtual Exec
02A1EA10 0000000024 02A1E960 02A1EA54 001  -------- -------- 007DDA80  Virtual Exec
02A20FE4 0000000040 02A20F40 02A21038 001  -------- -------- 000863A0  SNMP IDB
02A2293C 0000000040 02A22898 02A22990 001  -------- -------- 0041BA28  Virtual Exec
02A3D850 0000000040 02A3D7AC 02A3D8A4 001  -------- -------- 000B28E0  State Machine debug meta data
02A3EC7C 0000000040 02A3EC2C 02A3ECD0 001  -------- -------- 000B28E0  State Machine debug meta data
02A65D64 0000000040 02A65D14 02A65DB8 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02A68090 0000000040 02A6803C 02A680E4 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02A793D0 0000000040 02A79380 02A79424 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02A7A704 0000000080 02A7A624 02A7A780 001  -------- -------- 00181640  Virtual Exec
02A7B5C8 0000000040 02A7B578 02A7B61C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02A9E290 0000000080 02A9E244 02A9E30C 001  -------- -------- 0041BA28  Virtual Exec
02A9EB30 0000000040 02A9EA8C 02A9EB84 001  -------- -------- 00FDB2C0  Virtual Exec
02AAA804 0000000040 02AAA760 02AAA858 001  -------- -------- 000B2928  State Machine debug data
02AAA858 0000000120 02AAA804 02AAA8FC 001  -------- -------- 002857A4  PM vp_data
02B1FE10 0000000532 02B1FA7C 02B20050 001  -------- -------- 0040174C  Virtual Exec
02B209EC 0000000532 02B20920 02B20C2C 001  -------- -------- 0040174C  Virtual Exec
02B21350 0000000532 02B212EC 02B21590 001  -------- -------- 0040174C  Virtual Exec
02B67844 0000000024 02B677E0 02B67888 001  -------- -------- 00E5E88C  Virtual Exec
02B88A6C 0000000048 02B88A18 02B88AC8 001  -------- -------- 008573F0  TTY timer block
02BB0B08 0000000040 02BB0ABC 02BB0B5C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02BC551C 0000000032 02BC52D8 02BC5568 001  -------- -------- 000B28E0  State Machine debug meta data
02BD9320 0000000080 02BD927C 02BD939C 001  -------- -------- 002CB9A0  PM app data
02BF11CC 0000000048 02BF1178 02BF1228 001  -------- -------- 00181640  Virtual Exec
02BF22E8 0000004600 02BF2244 02BF350C 001  -------- -------- 00652450  AAA Acct AVLnode chunk
02C24B84 0000000040 02C24B30 02C24BD8 001  -------- -------- 0097BCA4  Virtual Exec
02C36400 0000000040 02C363AC 02C36454 001  -------- -------- 000B2928  State Machine debug data
02C36454 0000000112 02C36400 02C364F0 001  -------- -------- 002857A4  PM vp_data
02C364F0 0000000132 02C36454 02C365A0 001  -------- -------- 00F07458  Virtual Exec
02C37264 0000000052 02C37210 02C372C4 001  -------- -------- 004CFB0C  Virtual Exec
02C4DD00 0000000040 02C4DCAC 02C4DD54 001  -------- -------- 000B28E0  State Machine debug meta data
02CA71E4 0000000532 02CA716C 02CA7424 001  -------- -------- 0040174C  Virtual Exec
02CA88C4 0000000432 02CA8530 02CA8AA0 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
02CA9060 0000011200 02CA8FF8 02CABC4C 001  -------- -------- 0080111C  AAA attr list handle IDs
02CABC4C 0000010000 02CA9060 02CAE388 001  -------- -------- 0081A17C  AAA Acct Rec chunk
02D3F8BC 0000000532 02D3F528 02D3FAFC 001  -------- -------- 0040174C  Virtual Exec
02D402BC 0000000532 02D4022C 02D404FC 001  -------- -------- 0040174C  Virtual Exec
02D404FC 0000000532 02D402BC 02D4073C 001  -------- -------- 0040174C  Virtual Exec
02D4073C 0000000532 02D404FC 02D4097C 001  -------- -------- 0040174C  Virtual Exec
02D4191C 0000000532 02D418D8 02D41B5C 001  -------- -------- 0040174C  Virtual Exec
02D42184 0000000040 02D41DF0 02D421D8 001  -------- -------- 0097BCC4  Virtual Exec
02DD83C8 0000000040 02DD77E4 02DD841C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
02DD841C 0000000288 02DD83C8 02DD8568 001  -------- -------- 001F3820  DTP SWSB
02E1F4E0 0000000040 02E1F490 02E1F534 001  -------- -------- 000B2928  State Machine debug data
02E1FA14 0000000532 02E1F9C0 02E1FC54 001  -------- -------- 0040174C  Virtual Exec
02E20504 0000000048 02E2044C 02E20560 001  -------- -------- 00F32430  Ext Vlan entry
02E21034 0000000532 02E20FE0 02E21274 001  -------- -------- 0040174C  Virtual Exec
02E23D90 0000000532 02E23CC8 02E23FD0 001  -------- -------- 0040174C  Virtual Exec
02E6E458 0000010000 02E508F0 02E70B94 001  -------- -------- 00408368  Flashfs Sector Pointers
02E70B94 0000003000 02E6E458 02E71778 001  -------- -------- 00402F84  file_map_entry_chunk
02E71778 0000010000 02E70B94 02E73EB4 001  -------- -------- 004031AC  Flashfs Sector
02E73EB4 0000010000 02E71778 02E765F0 001  -------- -------- 004031AC  Flashfs Sector
02E765F0 0000010000 02E73EB4 02E78D2C 001  -------- -------- 004031AC  Flashfs Sector
02E78D2C 0000010000 02E765F0 02E7B468 001  -------- -------- 004031AC  Flashfs Sector
02E7B468 0000010000 02E78D2C 02E7DBA4 001  -------- -------- 004031AC  Flashfs Sector
02E7DBA4 0000010000 02E7B468 02E802E0 001  -------- -------- 004031AC  Flashfs Sector
02E802E0 0000010000 02E7DBA4 02E82A1C 001  -------- -------- 004031AC  Flashfs Sector
02E82A1C 0000010000 02E802E0 02E85158 001  -------- -------- 004031AC  Flashfs Sector
02E85158 0000010000 02E82A1C 02E87894 001  -------- -------- 004031AC  Flashfs Sector
02E87894 0000010000 02E85158 02E89FD0 001  -------- -------- 004031AC  Flashfs Sector
02E89FD0 0000010000 02E87894 02E8C70C 001  -------- -------- 004031AC  Flashfs Sector
02E8C70C 0000010000 02E89FD0 02E8EE48 001  -------- -------- 004031AC  Flashfs Sector
02E8EE48 0000010000 02E8C70C 02E91584 001  -------- -------- 004031AC  Flashfs Sector
02E91584 0000010000 02E8EE48 02E93CC0 001  -------- -------- 004031AC  Flashfs Sector
02E93CC0 0000010000 02E91584 02E963FC 001  -------- -------- 004031AC  Flashfs Sector
02E963FC 0000010000 02E93CC0 02E98B38 001  -------- -------- 004031AC  Flashfs Sector
02E98B38 0000010000 02E963FC 02E9B274 001  -------- -------- 004031AC  Flashfs Sector
02E9B274 0000010000 02E98B38 02E9D9B0 001  -------- -------- 004031AC  Flashfs Sector
02E9D9B0 0000010000 02E9B274 02EA00EC 001  -------- -------- 004031AC  Flashfs Sector
02EA00EC 0000010000 02E9D9B0 02EA2828 001  -------- -------- 004031AC  Flashfs Sector
02EA2828 0000010000 02EA00EC 02EA4F64 001  -------- -------- 004031AC  Flashfs Sector
02EA4F64 0000010000 02EA2828 02EA76A0 001  -------- -------- 004031AC  Flashfs Sector
02EA76A0 0000010000 02EA4F64 02EA9DDC 001  -------- -------- 004031AC  Flashfs Sector
02EA9DDC 0000010000 02EA76A0 02EAC518 001  -------- -------- 004031AC  Flashfs Sector
02EAC518 0000010000 02EA9DDC 02EAEC54 001  -------- -------- 004031AC  Flashfs Sector
02EAEC54 0000010000 02EAC518 02EB1390 001  -------- -------- 004031AC  Flashfs Sector
02EB1390 0000010000 02EAEC54 02EB3ACC 001  -------- -------- 004031AC  Flashfs Sector
02EB3ACC 0000010000 02EB1390 02EB6208 001  -------- -------- 004031AC  Flashfs Sector
02EB6208 0000010000 02EB3ACC 02EB8944 001  -------- -------- 004031AC  Flashfs Sector
02EB8944 0000010000 02EB6208 02EBB080 001  -------- -------- 004031AC  Flashfs Sector
02EBB080 0000010000 02EB8944 02EBD7BC 001  -------- -------- 004031AC  Flashfs Sector
02EBD7BC 0000010000 02EBB080 02EBFEF8 001  -------- -------- 004031AC  Flashfs Sector
02EBFEF8 0000010000 02EBD7BC 02EC2634 001  -------- -------- 004031AC  Flashfs Sector
02EC2634 0000010000 02EBFEF8 02EC4D70 001  -------- -------- 004031AC  Flashfs Sector
02EC4D70 0000010000 02EC2634 02EC74AC 001  -------- -------- 004031AC  Flashfs Sector
02EC74AC 0000003000 02EC4D70 02EC8090 001  -------- -------- 00402FA8  file_map_entry
02EC8090 0000010000 02EC74AC 02ECA7CC 001  -------- -------- 004031AC  Flashfs Sector
02ECA7CC 0000010000 02EC8090 02ECCF08 001  -------- -------- 004031AC  Flashfs Sector
02ECCF08 0000010000 02ECA7CC 02ECF644 001  -------- -------- 004031AC  Flashfs Sector
02ECF644 0000010000 02ECCF08 02ED1D80 001  -------- -------- 004031AC  Flashfs Sector
02ED1D80 0000010000 02ECF644 02ED44BC 001  -------- -------- 004031AC  Flashfs Sector
02ED44BC 0000010000 02ED1D80 02ED6BF8 001  -------- -------- 004031AC  Flashfs Sector
02ED6BF8 0000010000 02ED44BC 02ED9334 001  -------- -------- 00401F3C  Flashfs Sector
02ED9334 0000000040 02ED6BF8 02ED9388 001  -------- -------- 00A3DFDC  vegas_flash init
02ED9388 0000000024 02ED9334 02ED93CC 001  -------- -------- 00419010  vegas_flash init
02ED93CC 0000000040 02ED9388 02ED9420 001  -------- -------- 00A3E00C  vegas_flash init
02ED9420 0000000532 02ED93CC 02ED9660 001  -------- -------- 0040174C  vegas_flash init
02ED9660 0000000532 02ED9420 02ED98A0 001  -------- -------- 0040174C  vegas_flash init
02ED98A0 0000000024 02ED9660 02ED98E4 001  -------- -------- 00414A1C  vegas_flash init
02ED98E4 0000000024 02ED98A0 02ED9928 001  -------- -------- 00414A4C  vegas_flash init
02ED9928 0000000532 02ED98E4 02ED9B68 001  -------- -------- 0040174C  vegas_flash init
02ED9B68 0000000532 02ED9928 02ED9DA8 001  -------- -------- 0040174C  vegas_flash init
02ED9DA8 0000000024 02ED9B68 02ED9DEC 001  -------- -------- 00414A2C  vegas_flash init
02ED9DEC 0000000024 02ED9DA8 02ED9E30 001  -------- -------- 00414A1C  vegas_flash init
02ED9E30 0000000024 02ED9DEC 02ED9E74 001  -------- -------- 00414A4C  vegas_flash init
02ED9E74 0000000024 02ED9E30 02ED9EB8 001  -------- -------- 00414A2C  vegas_flash init
02ED9EB8 0000000024 02ED9E74 02ED9EFC 001  -------- -------- 00414A1C  vegas_flash init
02ED9EFC 0000000024 02ED9EB8 02ED9F40 001  -------- -------- 00414A4C  vegas_flash init
02ED9F40 0000000028 02ED9EFC 02ED9F88 001  -------- -------- 00414A2C  vegas_flash init
02ED9F88 0000000024 02ED9F40 02ED9FCC 001  -------- -------- 00414A1C  vegas_flash init
02ED9FCC 0000000024 02ED9F88 02EDA010 001  -------- -------- 00414A4C  vegas_flash init
02EDA010 0000000024 02ED9FCC 02EDA054 001  -------- -------- 00414A2C  vegas_flash init
02EDA054 0000000024 02EDA010 02EDA098 001  -------- -------- 00414A1C  vegas_flash init
02EDA098 0000000024 02EDA054 02EDA0DC 001  -------- -------- 00414A4C  vegas_flash init
02EDA0DC 0000000024 02EDA098 02EDA120 001  -------- -------- 00414A2C  vegas_flash init
02EDA120 0000000024 02EDA0DC 02EDA164 001  -------- -------- 00414A1C  vegas_flash init
02EDA164 0000000024 02EDA120 02EDA1A8 001  -------- -------- 00414A4C  vegas_flash init
0303123C 0000003128 03030EA8 03031EA0 001  -------- -------- 0016595C  *Hardware IDB*
03031EA0 0000001008 0303123C 030322BC 001  -------- -------- 0097CB40  CEF: FIBHWIDB
03053F3C 0000000532 030538EC 0305417C 001  -------- -------- 0040174C  Virtual Exec
030543A8 0000000532 0305417C 030545E8 001  -------- -------- 0040174C  Virtual Exec
03055C98 0000000532 03055A74 03055ED8 001  -------- -------- 0040174C  Virtual Exec
0306E9B4 0000000452 03061988 0306EBA4 001  -------- -------- 008F333C  Chain Cache No
0306EE68 0000000532 0306EDF0 0306F0A8 001  -------- -------- 0040174C  Virtual Exec
03070C00 0000000076 030705E0 03070C78 001  -------- -------- 00F07458  Virtual Exec
03070C78 0000000532 03070C00 03070EB8 001  -------- -------- 0040174C  Virtual Exec
03070EB8 0000000532 03070C78 030710F8 001  -------- -------- 0040174C  Virtual Exec
03071324 0000000080 03071270 030713A0 001  -------- -------- 002857A4  PM vp_data
030713A0 0000000040 03071324 030713F4 001  -------- -------- 000B2928  State Machine debug data
030714D4 0000000032 03071480 03071520 001  -------- -------- 002B6DB8  Virtual Exec
0307183C 0000000080 030717E4 030718B8 001  -------- -------- 002857A4  PM vp_data
030718B8 0000000040 0307183C 0307190C 001  -------- -------- 000B2928  State Machine debug data
030719DC 0000000400 03071960 03071B98 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
03072DD0 0000000532 03072D7C 03073010 001  -------- -------- 0040174C  Virtual Exec
03073F38 0000000532 03073CA0 03074178 001  -------- -------- 0040174C  Virtual Exec
030B7878 0000000160 030B7824 030B7944 001  -------- -------- 0127E93C  Router Init
030E8174 0000000532 030E7DE0 030E83B4 001  -------- -------- 0040174C  Virtual Exec
030E87CC 0000000040 030E8738 030E8820 001  -------- -------- 000E0200  Virtual Exec
030E9A80 0000000532 030E9614 030E9CC0 001  -------- -------- 0040174C  Virtual Exec
030E9D64 0000000532 030E9CC0 030E9FA4 001  -------- -------- 0040174C  Virtual Exec
030EAC00 0000000532 030EAB30 030EAE40 001  -------- -------- 0040174C  Virtual Exec
030EB898 0000000040 030EB844 030EB8EC 001  -------- -------- 00058A8C  Virtual Exec
030EBC58 0000000532 030EBB84 030EBE98 001  -------- -------- 0040174C  Virtual Exec
030EC0E8 0000000532 030EC068 030EC328 001  -------- -------- 0040174C  Virtual Exec
030EC470 0000000080 030EC3CC 030EC4EC 001  -------- -------- 0097BBC8  Virtual Exec
030EEC4C 0000000040 030EEBF8 030EECA0 001  -------- -------- 008D8E0C  Virtual Exec
030EFE48 0000000532 030EFDF4 030F0088 001  -------- -------- 0040174C  Virtual Exec
030F044C 0000000040 030F03FC 030F04A0 001  -------- -------- 000B28E0  State Machine debug meta data
030F25C8 0000000040 030F256C 030F261C 001  -------- -------- 000B28E0  State Machine debug meta data
030F3414 0000000028 030F33D0 030F345C 001  -------- -------- 00E5E88C  Virtual Exec
030F606C 0000000532 030F5FA0 030F62AC 001  -------- -------- 0040174C  Virtual Exec
030F7130 0000008192 030F7084 030F915C 001  -------- -------- 012469CC  SSH Process
030FA864 0000000532 030FA7C4 030FAAA4 001  -------- -------- 0040174C  Virtual Exec
030FB64C 0000000532 030FB5D0 030FB88C 001  -------- -------- 0040174C  Virtual Exec
030FB9D8 0000000444 030FB908 030FBBC0 001  -------- -------- 00E5E87C  Virtual Exec
030FBC08 0000000032 030FBBC0 030FBC54 001  -------- -------- 002B6DB8  Virtual Exec
030FBC54 0000000072 030FBC08 030FBCC8 001  -------- -------- 004CFA94  DWL SWSB
030FBE30 0000000400 030FBDDC 030FBFEC 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
030FD0A4 0000000432 030FD028 030FD280 001  -------- -------- 008F333C  Chain Cache No
031148B8 0000000076 0311484C 03114930 001  -------- -------- 00F07458  Virtual Exec
03114D9C 0000000064 03114D18 03114E08 001  -------- -------- 0000A28C  Virtual Exec
03114E08 0000000064 03114D9C 03114E74 001  -------- -------- 0000A28C  Virtual Exec
03114E74 0000000064 03114E08 03114EE0 001  -------- -------- 0000A28C  Virtual Exec
03114EE0 0000000040 03114E74 03114F34 001  -------- -------- 000B2928  State Machine debug data
03114F34 0000000080 03114EE0 03114FB0 001  -------- -------- 002857A4  PM vp_data
03114FB0 0000000040 03114F34 03115004 001  -------- -------- 000B2928  State Machine debug data
0311556C 0000000080 031154A0 031155E8 001  -------- -------- 002857A4  PM vp_data
03115C40 0000000028 03115B2C 03115C88 001  -------- -------- 00E5E88C  Virtual Exec
03116DD8 0000000532 03116D84 03117018 001  -------- -------- 0040174C  Virtual Exec
03119108 0000000040 03119064 0311915C 001  -------- -------- 002B6DB8  Virtual Exec
0311991C 0000000532 031196DC 03119B5C 001  -------- -------- 0040174C  Virtual Exec
03119B5C 0000000532 0311991C 03119D9C 001  -------- -------- 0040174C  Virtual Exec
0311C258 0000000032 0311C1F4 0311C2A4 001  -------- -------- 000B28E0  State Machine debug meta data
0311EF60 0000000532 0311E734 0311F1A0 001  -------- -------- 0040174C  Virtual Exec
0312012C 0000000432 031200A4 03120308 001  -------- -------- 008F3254  Chain Cache No
03191DF0 0000000532 03191D9C 03192030 001  -------- -------- 0040174C  Virtual Exec
031AE928 0000000160 031AE874 031AE9F4 001  -------- -------- 0127E93C  Router Init
031AEA90 0000000068 031AE9F4 031AEB00 001  -------- -------- 00873F14  Parser Mode Q1
03384B0C 0000000032 03384AB8 03384B58 001  -------- -------- 002CB9A0  PM app data
03399D88 0000000532 03399D38 03399FC8 001  -------- -------- 0040174C  Virtual Exec
03399FC8 0000000532 03399D88 0339A208 001  -------- -------- 0040174C  Virtual Exec
0339C49C 0000000532 0339C454 0339C6DC 001  -------- -------- 0040174C  Virtual Exec
033D017C 0000000216 033D0118 033D0280 001  -------- -------- 0127E93C  Router Init
033F1A74 0000000532 033F1A20 033F1CB4 001  -------- -------- 0040174C  Virtual Exec
033F3A10 0000000040 033F39BC 033F3A64 001  -------- -------- 00ABE170  IP Sticky ARP subblock
033F4C00 0000000532 033F4B84 033F4E40 001  -------- -------- 0040174C  Virtual Exec
033F503C 0000000532 033F4FE8 033F527C 001  -------- -------- 0040174C  Virtual Exec
033F527C 0000000064 033F503C 033F52E8 001  -------- -------- 0000A28C  Virtual Exec
033F6414 0000000532 033F6368 033F6654 001  -------- -------- 0040174C  Virtual Exec
033F6FF0 0000000064 033F6F9C 033F705C 001  -------- -------- 0000A28C  Virtual Exec
033F705C 0000000064 033F6FF0 033F70C8 001  -------- -------- 0000A28C  Virtual Exec
033F70C8 0000000064 033F705C 033F7134 001  -------- -------- 0000A28C  Virtual Exec
033F7134 0000000040 033F70C8 033F7188 001  -------- -------- 000B2928  State Machine debug data
033F7188 0000000144 033F7134 033F7244 001  -------- -------- 002857A4  PM vp_data
033F7244 0000000104 033F7188 033F72D8 001  -------- -------- 0000A28C  Virtual Exec
033F72D8 0000000532 033F7244 033F7518 001  -------- -------- 0040174C  Virtual Exec
033F7BD8 0000000040 033F7B10 033F7C2C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03409C14 0000000532 03409B68 03409E54 001  -------- -------- 0040174C  Virtual Exec
0340AB04 0000000032 0340AAB0 0340AB50 001  -------- -------- 002CB9A0  PM app data
0340AE78 0000000532 0340AE0C 0340B0B8 001  -------- -------- 0040174C  Virtual Exec
0340F7F4 0000000040 0340F7A0 0340F848 001  -------- -------- 000B28E0  State Machine debug meta data
03420CC0 0000000532 03410C94 03420F00 001  -------- -------- 0040174C  Virtual Exec
0349B1C8 0000000044 0349637C 0349B220 001  -------- -------- 00C5FF64  Router Init
0349CD38 0000000044 0349CCF4 0349CD90 001  -------- -------- 00C5FF64  Router Init
0349CD90 0000000044 0349CD38 0349CDE8 001  -------- -------- 00C5FF64  Router Init
0349CDE8 0000000044 0349CD90 0349CE40 001  -------- -------- 00C5FF64  Router Init
0349CE40 0000000044 0349CDE8 0349CE98 001  -------- -------- 00C5FF64  Router Init
035DC068 0000000532 035DBFA0 035DC2A8 001  -------- -------- 0040174C  Virtual Exec
035DCF88 0000000468 035DCBF4 035DD188 001  -------- -------- 008F333C  Chain Cache No
035DD188 0000000532 035DCF88 035DD3C8 001  -------- -------- 0040174C  Virtual Exec
035DD6B0 0000000064 035DD638 035DD71C 001  -------- -------- 0000A28C  Virtual Exec
035DD71C 0000000064 035DD6B0 035DD788 001  -------- -------- 0000A28C  Virtual Exec
035DD788 0000000064 035DD71C 035DD7F4 001  -------- -------- 0000A28C  Virtual Exec
035DD7F4 0000000096 035DD788 035DD880 001  -------- -------- 000B2928  State Machine debug data
035EA208 0000000532 035EA1C0 035EA448 001  -------- -------- 0040174C  Virtual Exec
035F0334 0000000532 035F02A4 035F0574 001  -------- -------- 0040174C  Virtual Exec
035F0ED4 0000000532 035F0B40 035F1114 001  -------- -------- 0040174C  Virtual Exec
03616D4C 0000000040 03616CA8 03616DA0 001  -------- -------- 000B2928  State Machine debug data
03616DA0 0000000132 03616D4C 03616E50 001  -------- -------- 002857A4  PM vp_data
0361A51C 0000000040 0361A4C8 0361A570 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0361B854 0000000040 0361B808 0361B8A8 001  -------- -------- 00FDA328  Virtual Exec
0361BCEC 0000000040 0361BC98 0361BD40 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0361C184 0000000040 0361C130 0361C1D8 001  -------- -------- 00D4A914  Clock buffer
0361C6C4 0000000040 0361C670 0361C718 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0361C814 0000000040 0361C7BC 0361C868 001  -------- -------- 00C9A850  Virtual Exec
0361CAB4 0000000040 0361CA60 0361CB08 001  -------- -------- 00ABE170  IP Sticky ARP subblock
036290A0 0000000044 03628FFC 036290F8 001  -------- -------- 0097BCA4  Virtual Exec
0363BF98 0000000040 0363BF44 0363BFEC 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0363CDB8 0000000040 0363CD14 0363CE0C 001  -------- -------- 0097BBE8  Virtual Exec
03643690 0000000040 036435EC 036436E4 001  -------- -------- 008FABFC  Virtual Exec
0364C834 0000000080 0364C4A0 0364C8B0 001  -------- -------- 002857A4  PM vp_data
0364CF14 0000000532 0364CD90 0364D154 001  -------- -------- 0040174C  Virtual Exec
0364DA18 0000000532 0364D958 0364DC58 001  -------- -------- 0040174C  Virtual Exec
0364ED90 0000000040 0364ECC0 0364EDE4 001  -------- -------- 0041B92C  Virtual Exec
03654410 0000000532 03654394 03654650 001  -------- -------- 0040174C  Virtual Exec
03654720 0000000080 036546A4 0365479C 001  -------- -------- 002857A4  PM vp_data
03655F74 0000000460 03655F20 0365616C 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
03668A78 0000000040 03668A24 03668ACC 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03668B70 0000000040 03668ACC 03668BC4 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03668CF8 0000000040 03668C68 03668D4C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
036692C8 0000000040 03669278 0366931C 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0366A5A8 0000000040 0366A558 0366A5FC 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0366ADF8 0000000040 0366AD54 0366AE4C 001  -------- -------- 000B28E0  State Machine debug meta data
0367D704 0000000040 0367D660 0367D758 001  -------- -------- 0008D654  Virtual Exec
036957A4 0000000040 03695700 036957F8 001  -------- -------- 00ABE170  IP Sticky ARP subblock
0369589C 0000000040 0369584C 036958F0 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03695994 0000000040 03695944 036959E8 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03695A9C 0000000024 036959E8 03695AE0 001  -------- -------- 002B6DB8  Virtual Exec
0369729C 0000000040 036971CC 036972F0 001  -------- -------- 00D4A914  Clock buffer
03698AFC 0000000040 03698A58 03698B50 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03698E1C 0000000040 03698D78 03698E70 001  -------- -------- 00ABE170  IP Sticky ARP subblock
036E3504 0000000128 036E34B8 036E35B0 001  -------- -------- 0000A28C  Virtual Exec
03707C08 0000000040 03707B80 03707C5C 001  -------- -------- 000B28E0  State Machine debug meta data
03718ACC 0000000532 03718738 03718D0C 001  -------- -------- 0040174C  Virtual Exec
037193B4 0000000532 037192EC 037195F4 001  -------- -------- 0040174C  Virtual Exec
03719764 0000000532 037196EC 037199A4 001  -------- -------- 0040174C  Virtual Exec
037199A4 0000000532 03719764 03719BE4 001  -------- -------- 0040174C  Virtual Exec
0371BA1C 0000000532 0371B7DC 0371BC5C 001  -------- -------- 0040174C  Virtual Exec
0371C2E0 0000000532 0371C24C 0371C520 001  -------- -------- 0040174C  Virtual Exec
0371C8A8 0000000532 0371C644 0371CAE8 001  -------- -------- 0040174C  Virtual Exec
0371D210 0000000040 0371CE7C 0371D264 001  -------- -------- 000B2928  State Machine debug data
0371D264 0000000080 0371D210 0371D2E0 001  -------- -------- 002857A4  PM vp_data
0371D2E0 0000000040 0371D264 0371D334 001  -------- -------- 000B2928  State Machine debug data
03725EAC 0000000040 03725E58 03725F00 001  -------- -------- 000B28E0  State Machine debug meta data
0372EC58 0000000040 0372EC04 0372ECAC 001  -------- -------- 0041B9E8  Virtual Exec
0374D398 0000000532 0374D004 0374D5D8 001  -------- -------- 0040174C  Virtual Exec
0374DFCC 0000000532 0374DC38 0374E20C 001  -------- -------- 0040174C  Virtual Exec
0374F028 0000000532 0374EF5C 0374F268 001  -------- -------- 0040174C  Virtual Exec
0374F4DC 0000000532 0374F47C 0374F71C 001  -------- -------- 0040174C  Virtual Exec
03750F6C 0000000532 03750EA4 037511AC 001  -------- -------- 0040174C  Virtual Exec
03751FFC 0000000532 03751F84 0375223C 001  -------- -------- 0040174C  Virtual Exec
037A8790 0000000040 037A873C 037A87E4 001  -------- -------- 000B28E0  State Machine debug meta data
037A8A60 0000000532 037A8980 037A8CA0 001  -------- -------- 0040174C  Virtual Exec
0382CC64 0000001024 0381CC38 0382D090 001  -------- -------- 00801C28  AAA attr list handle IDs
0382D0E4 0000000040 0382D090 0382D138 001  -------- -------- 00ABE170  IP Sticky ARP subblock
03862A3C 0000000040 038629E8 03862A90 001  -------- -------- 000B28E0  State Machine debug meta data
038641C0 0000000024 0386417C 03864204 001  -------- -------- 007DDA80  Virtual Exec
03865C30 0000000040 03865BDC 03865C84 001  -------- -------- 0097BBE8  Virtual Exec
03878160 0000000532 03878110 038783A0 001  -------- -------- 0040174C  Virtual Exec
0387C6F0 0000000532 0387C64C 0387C930 001  -------- -------- 0040174C  Virtual Exec
0387CBA4 0000000532 0387CB54 0387CDE4 001  -------- -------- 0040174C  Virtual Exec
0387CF8C 0000000400 0387CEE0 0387D148 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
0387DEFC 0000000120 0387DEA0 0387DFA0 001  -------- -------- 00CE4F7C  IPv4 FIB subblock
03880040 0000000024 0387FF80 03880084 001  -------- -------- 000B28E0  State Machine debug meta data
03899BB0 0000004096 03899B5C 0389ABDC 001  -------- -------- 0089A6A0  AAA Unique Id Hash Table
0395C418 0000000448 0395C374 0395C604 001  -------- -------- 008F333C  Chain Cache No
0398E788 0000000532 0398E6F8 0398E9C8 001  -------- -------- 0040174C  Virtual Exec
0398EEF0 0000000532 0398EEAC 0398F130 001  -------- -------- 0040174C  Virtual Exec
0398F4E8 0000000080 0398F498 0398F564 001  -------- -------- 000B28E0  State Machine debug meta data
039914D0 0000000532 0399113C 03991710 001  -------- -------- 0040174C  Virtual Exec
03991A74 0000000532 039919A8 03991CB4 001  -------- -------- 0040174C  Virtual Exec
03996A0C 0000065536 03992B8C 039A6A38 001  -------- -------- 00812BC0  AAA DB Elt Chunk
039A6A38 0000020000 03996A0C 039AB884 001  -------- -------- 00817F14  AAA Acct DB chunk
03AAAB38 0000000532 03AAA530 03AAAD78 001  -------- -------- 0040174C  Virtual Exec
03AABBD4 0000000024 03AABB90 03AABC18 001  -------- -------- 007DDA80  Virtual Exec
03AEDEE4 0000000024 03AEDDCC 03AEDF28 001  -------- -------- 007DDA80  Virtual Exec
03BD5308 0000000024 03BD52C4 03BD534C 001  -------- -------- 00897E5C  Virtual Exec
03BE5D80 0000000024 03BE5D3C 03BE5DC4 001  -------- -------- 00E5E88C  Virtual Exec
03BE617C 0000000024 03BE6138 03BE61C0 001  -------- -------- 00897DDC  Virtual Exec
03C28490 0000032768 03C18464 03C304BC 001  -------- -------- 00653B80  AAA Acct Req chunk
03C93864 0000000532 03C934D0 03C93AA4 001  -------- -------- 0040174C  Virtual Exec
03C93AA4 0000000532 03C93864 03C93CE4 001  -------- -------- 0040174C  Virtual Exec
03C94078 0000000532 03C93CE4 03C942B8 001  -------- -------- 0040174C  Virtual Exec
03C95764 0000000532 03C95710 03C959A4 001  -------- -------- 0040174C  Virtual Exec
03C9649C 0000000532 03C96450 03C966DC 001  -------- -------- 0040174C  Virtual Exec
03CC6B74 0000000532 03CB6B48 03CC6DB4 001  -------- -------- 0040174C  Virtual Exec
03CC6DB4 0000000532 03CC6B74 03CC6FF4 001  -------- -------- 0040174C  Virtual Exec
03CC7E10 0000000532 03CC7DC8 03CC8050 001  -------- -------- 0040174C  Virtual Exec
03CC8820 0000000284 03CC87CC 03CC8968 001  -------- -------- 0041B3E8  Virtual Exec
03CC9234 0000000532 03CC8EA0 03CC9474 001  -------- -------- 0040174C  Virtual Exec
03CCA360 0000000320 03CCA294 03CCA4CC 001  -------- -------- 0097C16C  CEF: FIBIDB
03CCAA4C 0000000532 03CCA9F8 03CCAC8C 001  -------- -------- 0040174C  Virtual Exec
03CCB1CC 0000000532 03CCAF8C 03CCB40C 001  -------- -------- 0040174C  Virtual Exec
03CCB884 0000000532 03CCB7AC 03CCBAC4 001  -------- -------- 0040174C  Virtual Exec
03CCBE74 0000000532 03CCBE24 03CCC0B4 001  -------- -------- 0040174C  Virtual Exec
03CCC370 0000000532 03CCC324 03CCC5B0 001  -------- -------- 0040174C  Virtual Exec
03CCD900 0000000532 03CCD894 03CCDB40 001  -------- -------- 0040174C  Virtual Exec
03CCE7C4 0000000532 03CCE748 03CCEA04 001  -------- -------- 0040174C  Virtual Exec
03CCEC78 0000000532 03CCEBF8 03CCEEB8 001  -------- -------- 0040174C  Virtual Exec
03CCFA94 0000000532 03CCFA44 03CCFCD4 001  -------- -------- 0040174C  Virtual Exec
03CCFCD4 0000000532 03CCFA94 03CCFF14 001  -------- -------- 0040174C  Virtual Exec
03CD0338 0000000532 03CD02A8 03CD0578 001  -------- -------- 0040174C  Virtual Exec
03CD0A2C 0000000532 03CD0960 03CD0C6C 001  -------- -------- 0040174C  Virtual Exec
03CD1E84 0000000532 03CD1E08 03CD20C4 001  -------- -------- 0040174C  Virtual Exec
03CE24C8 0000000532 03CE2134 03CE2708 001  -------- -------- 0040174C  Virtual Exec
03CE609C 0000000532 03CE2708 03CE62DC 001  -------- -------- 0040174C  Virtual Exec
03CE6550 0000000532 03CE62DC 03CE6790 001  -------- -------- 0040174C  Virtual Exec
03CE6A04 0000000532 03CE6790 03CE6C44 001  -------- -------- 0040174C  Virtual Exec
03D0790C 0000000532 03D07840 03D07B4C 001  -------- -------- 0040174C  Virtual Exec
03D07DC0 0000000532 03D07D10 03D08000 001  -------- -------- 0040174C  Virtual Exec
03D084B4 0000000532 03D083E8 03D086F4 001  -------- -------- 0040174C  Virtual Exec
03D08968 0000000532 03D0889C 03D08BA8 001  -------- -------- 0040174C  Virtual Exec
03D476BC 0000000532 03D4766C 03D478FC 001  -------- -------- 0040174C  Virtual Exec
03D4959C 0000000060 03D49208 03D49604 001  -------- -------- 00181640  Virtual Exec
03D49668 0000000532 03D49604 03D498A8 001  -------- -------- 0040174C  Virtual Exec
03D4A948 0000000040 03D4A880 03D4A99C 001  -------- -------- 000B28E0  State Machine debug meta data
03D4B43C 0000000532 03D4B31C 03D4B67C 001  -------- -------- 0040174C  Virtual Exec
03D4CFC8 0000001384 03D4CBF4 03D4D55C 001  -------- -------- 00843758  Connection
03D4D75C 0000000532 03D4D55C 03D4D99C 001  -------- -------- 0040174C  Virtual Exec
03D4DB00 0000012960 03D4DA94 03D50DCC 001  -------- -------- 00D4F6B8  Virtual Exec
03D555A8 0000000532 03D55508 03D557E8 001  -------- -------- 0040174C  Virtual Exec
03D6CBF4 0000000532 03D68D4C 03D6CE34 001  -------- -------- 0040174C  Virtual Exec
03D7E34C 0000000040 03D7E2A0 03D7E3A0 001  -------- -------- 00181640  Virtual Exec
03D7E3E4 0000000532 03D7E3A0 03D7E624 001  -------- -------- 0040174C  Virtual Exec
03D7E624 0000000532 03D7E3E4 03D7E864 001  -------- -------- 0040174C  Virtual Exec
03D7EC30 0000000080 03D7EBA8 03D7ECAC 001  -------- -------- 00058A8C  Virtual Exec
03D87B98 0000000076 03D87B4C 03D87C10 001  -------- -------- 00F07458  Virtual Exec
03D87C10 0000000532 03D87B98 03D87E50 001  -------- -------- 0040174C  Virtual Exec
03D87E50 0000000532 03D87C10 03D88090 001  -------- -------- 0040174C  Virtual Exec
03D882BC 0000000040 03D88230 03D88310 001  -------- -------- 000B2928  State Machine debug data
03D8D9E4 0000000080 03D88718 03D8DA60 001  -------- -------- 002857A4  PM vp_data
03D8DF14 0000000532 03D8DE70 03D8E154 001  -------- -------- 0040174C  Virtual Exec
03D8E978 0000000460 03D8E5E4 03D8EB70 001  -------- -------- 008F333C  Chain Cache No
03D8F0C4 0000000532 03D8EF04 03D8F304 001  -------- -------- 0040174C  Virtual Exec
03D9507C 0000001008 03D90230 03D95498 001  -------- -------- 0097CB40  CEF: FIBHWIDB
03D954EC 0000000080 03D95498 03D95568 001  -------- -------- 002857A4  PM vp_data
03D95568 0000000040 03D954EC 03D955BC 001  -------- -------- 000B2928  State Machine debug data
03D955BC 0000000080 03D95568 03D95638 001  -------- -------- 002857A4  PM vp_data
03D95638 0000000040 03D955BC 03D9568C 001  -------- -------- 000B2928  State Machine debug data
03D9568C 0000000400 03D95638 03D95848 001  -------- -------- 00EA1A8C  Spanning Tree Control Block
03D964B8 0000000532 03D9645C 03D966F8 001  -------- -------- 0040174C  Virtual Exec
03D9FBDC 0000000532 03D9F848 03D9FE1C 001  -------- -------- 0040174C  Virtual Exec
03DA0B14 0000000048 03DA0780 03DA0B70 001  -------- -------- 00C437BC  IPRTG SWSB
03DA0B70 0000000532 03DA0B14 03DA0DB0 001  -------- -------- 0040174C  Virtual Exec
03DA0F54 0000000204 03DA0DB0 03DA104C 001  -------- -------- 009803C4  CEF: FIBSWSB control
03DA1094 0000000532 03DA104C 03DA12D4 001  -------- -------- 0040174C  Virtual Exec
03DA14F0 0000000532 03DA1474 03DA1730 001  -------- -------- 0040174C  Virtual Exec
03DA3B98 0000000532 03DA3910 03DA3DD8 001  -------- -------- 0040174C  Virtual Exec
03DA6664 0000000040 03DA62D0 03DA66B8 001  -------- -------- 000B2928  State Machine debug data
03E55EB8 0000000040 03E55B24 03E55F0C 001  -------- -------- 000B2928  State Machine debug data
03E57564 0000003128 03E56444 03E581C8 001  -------- -------- 0016595C  *Hardware IDB*
03E581C8 0000001488 03E57564 03E587C4 001  -------- -------- 0016597C  *Software IDB*
03E587C4 0000000096 03E581C8 03E58850 001  -------- -------- 00C8DA70  IDB: IPINFO
03E71F94 0000000532 03E71EC8 03E721D4 001  -------- -------- 0040174C  Virtual Exec
03E73338 0000000532 03E732EC 03E73578 001  -------- -------- 0040174C  Virtual Exec
03E73B24 0000000028 03E738F0 03E73B6C 001  -------- -------- 00E5E88C  Virtual Exec
03E870D0 0000000532 03E841C4 03E87310 001  -------- -------- 0040174C  Virtual Exec
03E87584 0000000532 03E87310 03E877C4 001  -------- -------- 0040174C  Virtual Exec
         776976
          I/O memory
#     show memory dead total
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
      I/O   80000000     8388608     3330660     5057948     4822244     4783168
--More--
Dead Proc Summary for: Processor
    PC          Total  Name
0x0040174C        167  Virtual Exec
0x004031AC         41  Flashfs Sector
0x00ABE170         35  IP Sticky ARP subblock
0x000B28E0         26  State Machine debug meta data
0x000B2928         26  State Machine debug data
0x002857A4         20  PM vp_data
0x0000A28C         18  Virtual Exec
0x00414A1C         11  vegas_flash init
0x00414A2C         11  vegas_flash init
0x00414A4C         11  vegas_flash init
0x007DDA80          9  Virtual Exec
0x008F333C          8  Chain Cache No
0x0040174C          7  vegas_flash init
0x002B6DB8          6  Virtual Exec
0x00E5E88C          6  Virtual Exec
0x00181640          6  Virtual Exec
0x002CB9A0          6  PM app data
0x00EA1A8C          6  Spanning Tree Control Block
0x00F07458          5  Virtual Exec
0x00C5FF64          5  Router Init
0x00A3DFDC          4  vegas_flash init
0x00A3E00C          4  vegas_flash init
0x00D4A914          4  Clock buffer
0x008F342C          4  Chain Cache No
0x008573F0          4  TTY timer block
0x00C44314          3  Virtual Exec
0x0127E93C          3  Router Init
0x00419010          2  vegas_flash init
0x00C8DA70          2  IDB: IPINFO
0x00C437BC          2  IPRTG SWSB
0x0097BBC8          2  Virtual Exec
0x004CFA94          2  DWL SWSB
0x0041B3E8          2  Virtual Exec
0x0097BCC4          2  Virtual Exec
--More--                               PC          Total  Name
0x0016597C          2  *Software IDB*
0x0041B9E8          2  Virtual Exec
0x004CFB0C          2  Virtual Exec
0x000863A0          2  SNMP IDB
0x0097C16C          2  CEF: FIBIDB
0x0041B92C          2  Virtual Exec
0x0041BA28          2  Virtual Exec
0x0097BCA4          2  Virtual Exec
0x0016595C          2  *Hardware IDB*
0x0097CB40          2  CEF: FIBHWIDB
0x00058A8C          2  Virtual Exec
0x0097BBE8          2  Virtual Exec
0x004115C8          1  vegas_flash init
0x004115F8          1  vegas_flash init
0x0041163C          1  vegas_flash init
0x004131CC          1  vegas_flash init
0x004131E8          1  vegas_flash init
0x0041328C          1  vegas_flash init
0x0041332C          1  vegas_flash init
0x00413760          1  vegas_flash init
0x0041377C          1  vegas_flash init
0x0041381C          1  vegas_flash init
0x004138B4          1  vegas_flash init
0x0040958C          1  vegas_flash init
0x00409694          1  vegas_flash init
0x004097D8          1  Flashfs Sector buffers
0x0040980C          1  vegas_flash init
0x00A45F18          1  vegas_flash init
0x00416F24          1  vegas_flash init
0x007FFD78          1  AAA MI SG NAME
0x0127E93C          1  Virtual Exec
0x0008D6A0          1  Virtual Exec
0x00AEED88          1  Virtual Exec
0x0003922C          1  shelf_info
0x00074EE0          1  DNS Host
0x00871C9C          1  Parser Linkage
0x00A81220          1  IPC Port
0x00873EA8          1  Parser Mode
0x00873F38          1  Parser Mode Q2
0x00A8124C          1  IPC Name
0x00A89864          1  IPC Name String
0x0127E93C          1  TCP Command
0x00FDB2C0          1  Virtual Exec
0x00652450          1  AAA Acct AVLnode chunk
0x0080111C          1  AAA attr list handle IDs
0x0081A17C          1  AAA Acct Rec chunk
0x001F3820          1  DTP SWSB
0x00F32430          1  Ext Vlan entry
0x00408368          1  Flashfs Sector Pointers
0x00402F84          1  file_map_entry_chunk
0x00402FA8          1  file_map_entry
0x00401F3C          1  Flashfs Sector
0x000E0200          1  Virtual Exec
0x008D8E0C          1  Virtual Exec
0x012469CC          1  SSH Process
0x00E5E87C          1  Virtual Exec
0x008F3254          1  Chain Cache No
0x00873F14          1  Parser Mode Q1
0x00FDA328          1  Virtual Exec
0x00C9A850          1  Virtual Exec
0x008FABFC          1  Virtual Exec
0x0008D654          1  Virtual Exec
0x00801C28          1  AAA attr list handle IDs
0x00CE4F7C          1  IPv4 FIB subblock
0x0089A6A0          1  AAA Unique Id Hash Table
0x00812BC0          1  AAA DB Elt Chunk
0x00817F14          1  AAA Acct DB chunk
0x00897E5C          1  Virtual Exec
0x00897DDC          1  Virtual Exec
0x00653B80          1  AAA Acct Req chunk
0x00843758          1  Connection
0x00D4F6B8          1  Virtual Exec
0x009803C4          1  CEF: FIBSWSB control
Dead Proc Summary for: I/O
Hi All,
Waiting for the reply.
It looks to me that  the device is facing a memory fragmentation or memory leak issue.
%SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0xF2D894, alignment 0
Pool: Processor  Free: 322388  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Virtual Exec", ipl= 0, pid= 148
-Traceback= 8E27BC 8E2ED0 F7F440 F882F4 127CB98 F2D898 F2CB0C F29EAC F31950 14637C 146408 86B6B4 8E862C 8E89EC 8E877C 897110
The process here is a victim and not the exact cause of the problem. In the above example there is no free (contiguous) memory for “virtual exec” and hence the tracebacks. Decoding the traceback does not help in this case. These are the standard procedures to troubleshoot these issues.
Collect the following outputs after every 20 mins over a period of 4 hours ( this time interval may vary depending on the rate of leak/fragmentation )
? Show mem stat
Check whether the “free” memory is decreasing or not. If it is decreasing then we have a memory leak condition. If the “free” memory is constant and “largest” memory is decreasing then we have a memory fragmentation issue. The challenge here is to find the offending process.
? Sh proc mem sort
Check the process for which the “holding” part of the memory is gradually increasing. If over an interval of time the memory holding of the process has decreased even once then this might not be the process.
? Sh proc mem alloc total ( not available in all the IOS/platform).
This output will tell you which process was allocated memory most number of times. This is an easy way of troubleshooting memory issue.
Once you have found out the offending process then you can do “sh proc mem “ and decode the PC values to gather more information about what the process was doing during the leak. Search with the decode/process/IOS for bugs.
? Show buffer
See if there are any buffer where you see incrementing “failure” counts . once you have identified the buffer where there are “failures” then take the output of “show buffer summary”. The output will look something like this.
--------- show buffer summary --------
Pool: Small
  Caller Summary
     pc = 0x403A338C           count = 149173  <===
     pc = 0x409C2110            count = 13
In the above let us say you have observed buffer failure for small pool. PC value 0x403A338C was called most number of times. Decode this PC value and search for bugs.
It is not recommended to use “show mem debug leak” ( not available in all the platforms)  in a production switch as it can make things worse. If at all you need to use this please use during off production hours.
Recommendation.
1.       Usually when this situation occurs, we need to schedule a maintenance window and  reload the device.
2.       In the event the device is not reloaded pro-actively, it would crash and will overcome the memory fragmentation issue.
Do kindly share your opinion on the above explanation and recommendation
Inayath
*Plz rate all usefull posts.
