how to allow vlan info to reach switch 3
akhanwaterloo
Current scenario
Site A - switch A fibre connectivity between A and B
Site B - Switch B fibre connectivty between B and C
Site C - Switch C
Switch A is connected to switch B through fibre port-
Switch B is connected to switch C through fibre
there are some ip phones in site C on switch C
I have two vlans vlan 301 DATA and vlan 310 VOIP information available on switch A and that when connected to switch B as a TRUNK is available on switch B
how to send these vlans info to the ip phones on switch C on site C
Any help is appreciated
Asif
Exactly ... Just need to continue the trunk on to swich C.  Your config looks correct.
Robert Taylor
Do you have a trunk between switch B and switch C?
A trunk between the two devices needs to be configured to allow those two vlans to pass between the two switches.
Do "show int trunk" and "show run int x", where x is the B-C interface, on both switch B and switch C, and send us the info.
thats where i was confused so to make my concept clear
switch A and B connected through trunk on port 25 fibre
config on switch A and B are port 25
int gi0/25
switchport trunk allowed vlan 301,310
switchport mode trunk
so if I create a trunk on switch B and C on available port 26 and connect them
config on switch B and C would be on port 26
int gi0/26
so my ip phones on switch C will get voip and data vlan info to connect
Asif
int gi0/25
int gi0/26
Asif
Asif
Yes that is what you need to do.
Jon
