How to block inter Vlan in 6504 HSRP
anishbn
i have two 6504 switch enable HSRP. I want to block intervlan routing .How can I achieve the same .
vlan 10 data
vlan 100 Management
vlan 20 voice
vlan 30 guest
   I don’t want guest and data to communicate with management vlan .
thank you
luis_cordova
Hi @anishbn ,
This you could achieve through ACL.
For example:
access-list 1 deny <IP network vlan guest> <wildcard of vlan guest>
access-list 1 deny <IP network vlan data> <wildcard of vlan data>
access-list 1 permit any
In the interface that routes the vlan Management , you apply the ACL:
ip access-group 1 in
