How to Block Netflix on cisco IOS
only1gmose
I'm trying to block netflix from our network using a catalyst 3550 switch, I can't just block www.netflix.com, but want to block the word "netflix" as a whole that way i'm assured that i will block it for sure.
Karthick Murugan
I don't this 3550 supports content based filtering but we should be able to filter using IP address.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
my 2cents.. blocking IP may not not work fully as IP can change. Unless you have proxy etc, you can add a DNS entry in your internal DNS server (if available) points null or if you got only handful of PCs, add an entry in the 'host' file and make sure that users cannot edit the the hosts file.
Thx
MS
