how to calculate subnet?
daveporter123
any easy method to calculate subneting?
devang_etcom
Level 7
Level 7
5 Replies 5
devang_etcom
Level 7
Level 7
http://www.solarwinds.net/downloads/index.aspx
look at this subnet calculator...
You can download the subnet calculator from:
http://bosondownload.com/utils/bos_sub.exe
If you want an online website where you can do this use this:
http://www.subnet-calculator.com/
If you want to learn it yourself use this document:
http://www.xs4all.nl/~itbg077/studieavond/IP/IP-Summary.pdf
http://www.petri.co.il/subnetting_table.htm
and for small videos on subnetting :
http://www.learntosubnet.com/
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
Danilo Dy
Step-by-step tutorial from http://www.ralphb.net/IPSubnet/ just select "Next" to go to next page.
Subnet calculator from Boson and other utilities http://www.boson.com/FreeUtilities.html
IP Subnet calculator from Cisco and other utilities if you have CCO Account http://www.cisco.com/en/US/support/tsd_tools_by_category.html
It's better to learn to calculate without any tools
Yup, but when you are working in a production network, it's better to have a calculator, not only its faster, it's good to double-check your subnetting before putting it in the live network .
Unless you are studying for exam or you are burning manhour in your lab, yes its better to calculate :)
