How to change default gateway for LAN subnet?
SACHIN SHARMA
All,
we have uesrs complaining slowness when accessing few urls on internet currently which are routed through mpls  ,now we want to re-direct the traffic from that user subnet and only to certain destination url /ips which are critical to the users to a different internet link terminated on ASA ,can this be done?
Thank You,
Kalyan.
Jon Marshall
Kaylan
If the user vlan is routed on a L3 device before going to either the MPLS router or the firewall you could use PBR on the L3 device (if supported).
But as Reza says, we need more info on your network layout.
Jon
Reza Sharifi
So you have separate Internet connection for one user and that terminates on an ASA?  If yes, you can put the default gateway for that user on the ASA and have it go out that specific connection.
Thanks for replying but i am looking to achieve this in a different way as Jon suggested below.
Jon Marshall
Kaylan
Jon
Thanks Jon for replying.
