Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to check amount of memory sup and msfc have in 6509
mahesh18
Level 6
Level 6
How we can check amount of memory in 6509 switch with dual supe and msfc on modules  5 and  6 each ?
Many thanks
mahesh
3 Accepted Solutions
Jon Marshall
Maheh
6500# sh version
should show you all the memory details.
Jon
MAhesh, that is correct   1GB total ram
When seen memory output  such as  for example  your device , and also output examples in link provided by Francisco
simply add  these two figures 983008K/65536K     e.g  983008K + 65536   and devide by 1024 ,  it should give you  very close to exact memory amount .
983008K + 65536 / 1024 =   1024 Megabytes  which  actually is 1 GB
Jorge Rodriguez
6 Replies 6
Jon Marshall
Maheh
6500# sh version
Jon
Hi Jon
Thanks for reply.
Here is sh ver
cisco WS-C6509-E (R7000) processor (revision 1.4) with 983008K/65536K bytes of memory.
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
2 Virtual Ethernet/IEEE 802.3 interfaces
212 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Now which one is supe memory and which one is flash?
Also when we have two supes and msfc then both have same memory?
thanks
mahesh
Hi Francisco
Thanks  for reply.
so as per sh ver  in this case we have
MSFC  and SUPE  with 1 gigabyte of memory?
MAhesh
Jorge Rodriguez
Hi all,
Thanks eveyone for their reply  and wonderfull explanation.
Best regards
Mahesh
