How to check CMP telnet vulnerability
HI All,
I want to check on my network for CMP vulnerability on IOS/IOS XE devices. I'm having more than 4000 switches installed and running in my production environment.
Could you please give me any suggestion to check all the devices, without logging into each and every device?
Thanks in Advance!
Prakash.
Mark Malone
You only need to check the ios-xe for vulnerability and turn it off in IOS completely as per doc
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20170317-cmp
Do you have management software that you can run commands from to your devices if you have that many switches , Prime can do it , just run the below it will rule out the known vulnerability for ios and you could also run a report for the show commands there suggesting to check the ios-xe and have it report back if a device is effected
line vty 0 15
no transport input telnet
no transport input all
transport input ssh
Hi Mark,
Appreciate your response!
I'm using solarwinds tool. can I do from this?
Thanks!
I dont use solar winds personally just Prime and Live action for pushing configs and running reporting  but I would think you can solarwinds is a powerful app
quick google says the NCM section can do it
https://support.solarwinds.com/Success_Center/Network_Configuration_Manager_(NCM)/How_to_use_NCM_to_make_config_changes_on_multiple_nodes
Thanks!
Will check with the tool.
