how to choose Router based on ISP Bandwidth
gthanigachalam
hi.. everyone..
pls help me, i need some clarification to choose router for my LAN network.
i have using 2 ISP link and Bandwidth nearest of 300 Mbps.
total end user above 800. we planned router for only data usage not a security and voice purpose.
which one router model suitable for our LAN network?. pls reply me as soon as possible.
advance thank you. awaiting your reply.
note: pls suggest me, if we consider any other input to choose router.
Ganesh Hariharan
Depends on your requirement and budget , like how you want to use this device .
If it is bandwidth with advance routing protocol support then you decide a product but if it with collaboration of voice and security services then different products are been recommended.
For your case check out ASR 1000 series next generation product which are normally been highlight of market.
Have a look on the below link for more detail on features of ASR series..
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1002-router/solution_overview_c22-450068.html
Hope it Helps..
-GI
HI Ganesh..
Thanks for your reply..
