06-26-2021 03:10 AM
Hello everyone...
I did a factory reset everything on a 9300 switch, now I need to restore it as this was an error when executing the command, which are the steps to restore this switch model.
Thank you very much
Solved! Go to Solution.
06-26-2021 04:08 AM
If the switch is in ROMMON, then the only way to bring this back is to use Emergency-Install.
emergency-install usbflash0:IOS_filename.bin
06-26-2021 03:04 PM
recovery try below step by step guide :
06-26-2021 04:08 AM
06-26-2021 03:04 PM
07-27-2021 08:33 PM
thanks for your help it helped me a lot
