how to clear counter in Cat OS
Wlewx11
Cat OS
WS-C4506 Software, Version NmpSW: 7.4(1)
i have try perform clear counter, and below error still occured. any advice???
Xmit-Err Rcv-Err U
3148308 1564
glen.grant
It should work with just a "clear counters " command or a clear counter slot/port command. If you still see errors after clearing then you have an issue , could be a speed/duplex issue with the nic card attached to the port. Both ends should match, if switchport is set as auto the the user nic has to be set as auto also , if hardcoded to a speed and duplex both ends must be hardcoded.
