How to clear memory DEAD in switch
krishnakomiti
How to clear memory DEAD in switch...............appriciate your help
Leo Laohoo
You don't/can't.  Cisco won't read your config.  It's part of their service.
Due to DEAD memory, my switch is using high memory. how to kill dead memory
hobbe
Level 7
Level 7
what is dead ?
if it is the powersupply then exchange it for another similar powersupply from a working switch.
erase the config
turn off the switch and switch the working powersupply with the broken one.
if the motherboard is the broken part then I do not know of a way you can erase the configuration.
Good luck
aahhh forget my posting
sorry thought you had a hardware problem and wanted to erase the config before sending it to cisco..
my mistake..
Message was edited by: hobbe
