how to clear the RX and TX rate stats of an interface
Mike Assel
Level 4
Level 4
On a catalyst switch when I use the command "show interfaces summary" I get great stats on the interfaces.  Issuing the command "clear counters" clears the numbers for these stats regarding dropped packets (and a lot of other things, I know), but it doesn't clear the tx and rx rate stats.  So my question is:
1) is there a way I can clear them
2) how are they calculated in the first place
Thanks,  Mike
Leo Laohoo
I believe tx and rx rate stats are not cumulative counters.  If you have no traffic (and your refresh rate is 30 seconds) then those values will be 0.
