How to Configure a CVR-X2-SFP, on Cisco 4900M switches>
siamaher52
Hi Guys,
I have an issue with couple of Cisco 4900M switches. We just got them and tried to use the
TwinGig Converter on the 4 ports 10G module.
The problem is that the switches sees the new module in slot 2 and when we are inserting the TwinGig Converters we are getting the error message and when we are trying  to type the command this command it does not work.
"hw-module module <slot> port-group <group> select gigabitethernet"
When we go to config T, the only thing we can type is
"hw-module module <slot> and if we do a ? the only thing is available is logging and power and we can't type
Port-Group or anything else. Does anybody know why? is this a hiden command or we have to something else?
Sia
Reza Sharifi
What type module are you installing these TwinGig converters?
It is only supported in this module:
Supported only on 8-port (2:1) 10 Gigabit Ethernet (X2) half card
See this doc for more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
