How to configure etherchannel trunk between Cisco and Nortel
ARP HIEMSTRA
We would like to configure a etherchannel trunk between a Cisco 3020 blade switch and a Nortel 8310 core switch.
There are two 3020 blade switches in the HP enclosure. We would like to configure each switch to have an etherchannel uplink to the core consisting out off 4 1000 Mbit links.
I would like to know what design considerations and known errors we could run into.
There is a PortChannel with 4 interfaces as a Trunk dot1q to the 8310.
Do we need to use spanning tree on these trunks or can we safely disable this?
The mode of channel group is set to on at this time. The 8310 supports LACP thru the use of a MLT setting.
What would be the recommended setting for the mode I would think active or passive?
Any insights are greatly apreciated.
Kind regards,
Arp
Giuseppe Larosa
Hello Arp,
you should use mode active to implement LACP, mode on is not recommended it sets the bundle unconditionally.
About  STP: STP handles a bundle as a single link, I would use it for more safety.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Arp,
Hope to help
Giuseppe
