How to configure inter vlan communication in L3 switch
vinothlb1
How to configure inter vlan communication in L3 switch.. Pls provide any cisco doc for creating vlans and implementinginter vlan communication in L3 switch..
6 Replies 6
Mark Yeates
Level 7
Level 7
You did not indicate which L3 switch you are using. Here is a guide for the 3550/3560/3750 series switch.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Mark
how to create inter vlan communication. I m using Cisco 4000 series L3 switch
mahmoodmkl
Level 7
Level 7
On the L3 switch suppose u r having 3 vlans ie 10,20,30 then
conf t#interface vlan 10
ip address (specific subnet ip which u want to use for this vlan)
likewise u have to create it for all the vlans.
Mahmood
U need to just take care of the ip routing enabled on the switch.
For the clients point their default gateway to the ip address of the specific SVI.
The routing is going to take automatically.
Mahmood
a.alekseev
Level 7
Level 7
conf t
ip routing
vlan 10
vlan 20
vlan 30
int vlan 10
ip add 10.0.10.1 255.255.255.0
no sh
int vlan 20
ip add 10.0.20.1 255.255.255.0
no sh
int vlan 30
ip add 10.0.30.1 255.255.255.0
no sh
