How to configure interface Nexus 7000?
I am just trying to configure the ethernet interfaces on my Nexus 7010 48 port module. When I do a "show interface" I only see the management interface on the management module and not the 48 port module. When I run a "show hardware" I am able to see that the module is plugged in to slot 1 and the status is "ok." I thought the interfaces would just show up once I connected the module. Is this not correct? And then I could access the ports with "interface ethernet 1/x" for the ports on module 1.
14 Replies 14
fb_webuser
Level 6
Level 6
Check out this document http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_basic.html
Posted by WebUser Janet Doe from Cisco Support Community App
Looked in there already. Seemed like the command should just be "interface ethernet 1/1" to configure port 1 on the module in slot 1. However I get an invalid range error and when I run "show interface" I only see the management blade interfaces rather than the 48 ethernet interfaces on the module.
Any ideas?
Hi Nathaniel,
Are you using non default VDC or RBAC on this switch. Can you attach show command output / show runn to check further.
-Subhash
Subhash, I believe I am using the default vdc on the switch.
show run shows:
_____________________________________
Nexus-7000(config)# show running-config
!Command: show running-config
!Time: Tue Jul  9 19:21:30 2013
version 6.1(2)
poweroff xbar 4
poweroff xbar 5
hardware fabrics max 3
license grace-period
switchname Nexus-7000
system admin-vdc
vdc Nexus-7000 id 1
  cpu-share 5
  limit-resource vlan minimum 16 maximum 4094
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource monitor-session-erspan-dst minimum 0 maximum 23
  limit-resource vrf minimum 2 maximum 4096
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 96 maximum 96
  limit-resource u6route-mem minimum 24 maximum 24
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
  limit-resource monitor-session-inband-src minimum 0 maximum 1
username admin password 5 $1$jyn3hULs$7iGtrdO2BwgjGOJIRHkN81  role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x3688458ab63c86695ec6a773488d138c
priv 0x3688458ab63c86695ec6a773488d138c localizedkey
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
vrf context management
  ip route 0.0.0.0/0 10.102.102.1
vlan 1
interface mgmt0
  ip address 10.102.102.24/23
line console
line vty
boot kickstart bootflash:/n7000-s2-kickstart.6.1.2.bin sup-1
boot system bootflash:/n7000-s2-dk9.6.1.2.bin sup-1
__________________________________________________________
show interface shows
Nexus-7000(config)# show interface
mgmt0 is up
admin state is up,
  Hardware: GigabitEthernet, address: 8478.ac57.3e2c (bia 8478.ac57.3e2c)
  Internet Address is 10.102.102.24/23
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  full-duplex, 1000 Mb/s
  Auto-Negotiation is turned on
  Auto-mdix is turned off
  EtherType is 0x0000
  1 minute input rate 1656 bits/sec, 1 packets/sec
  1 minute output rate 3048 bits/sec, 1 packets/sec
  Rx
    55430 input packets 9389 unicast packets 7792 multicast packets
    38249 broadcast packets 5342508 bytes
  Tx
    6401 output packets 6397 unicast packets 1 multicast packets
    3 broadcast packets 947681 bytes
It's as if the interfaces are not there. But with show hardware, I can see that the module is seen.
Module1  ok
  Module type is : 1/10 Gbps Ethernet Module
  0 submodules are present
  Model number is N7K-F248XP-25E
  H/W version is 1.0
  Part Number is 73-14976-02
  Part Revision is A0
  Manufacture Date is Year 17 Week 12
  Serial number is JAF1712BFCB
  CLEI code is CMUIAFCCAA
Take a read of the post Nexus 7009 does not show the N7K-F248XP-25 modules ethernet ports n sh run.
The solution there appears to be the use of the system module-type command.
Thanks Steve. That seems to be very close to what I am looking for. We are running 6.1(2) right now but I see that it does not support the "system module-type" command. THat is only in 6.1(3). We are not able to get the upgrade yet due to SmartNet problems. Don't think there is a work around command on 6.1(2) that does the same thing...
Do you have any other I/O modules in the same chassis, either the M1, M2 or F1 series I/O modules? Currently the F2 and F2E modules needs to be in their own VDC.
As per the section Integrating F2 Series Modules Into a Cisco Nexus 7000 Series System in the NX-OS 6.1 release notes:
  • An F2 Series module requires its own F2 Series module VDC. This VDC is restricted to the F2 Series module; M1 and F1 ports cannot be in the F2 Series module VDC. The default VDC can also be configured as an F2 Series module VDC.
Check output of 'show vdc membership' command. These interfaces will all appear
in VDC 0, which is reserved for unallocated interfaces:
vdc_id: 0 vdc_name: Unallocated interfaces:
Ethernet15/1          Ethernet15/2          Ethernet15/3
Ethernet15/4          Ethernet15/5          Ethernet15/6
Ethernet15/7          Ethernet15/8          Ethernet15/9
This needs to be allocated to your current VDC id 1. Refer below link for more information.
Allocating interfaces to a VDC: http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/vdc_mgmt.html#wp1186878
If still it doesn't work, then you will need to create a separate VDC, configure that VDC to support the F2 module, and then allocate the appropriate interfaces to that new VDC.
-Subhash
Thank you very much guys. I was not able to add the ethernet ports to vdc1 since the admin vdc was not specified to handle f2 (and could not be set to handle it with limit-resources). Instead, I created another vdc and was able to allocate the interfaces and configure them.
Many thanks to both of you for your help!
HI Skapadi,
Thanks...I was also stucked  on same issue, given link helped me...Thank you so much..live long..
Tran Van Loi
Hi all,
I have problem it same you!!
Ethernet2/4 Ethernet2/5 Ethernet2/6
Ethernet2/7 Ethernet2/8 Ethernet2/9
Ethernet2/10 Ethernet2/11 Ethernet2/12
Ethernet2/13 Ethernet2/14 Ethernet2/15
Ethernet2/16 Ethernet2/17 Ethernet2/18
Ethernet2/19 Ethernet2/20 Ethernet2/21
Ethernet2/22 Ethernet2/23 Ethernet2/24
Ethernet2/25 Ethernet2/26 Ethernet2/27
Ethernet2/28 Ethernet2/29 Ethernet2/30
Ethernet2/31 Ethernet2/32 Ethernet2/33
Ethernet2/34 Ethernet2/35 Ethernet2/36
Ethernet2/37 Ethernet2/38 Ethernet2/39
Ethernet2/40 Ethernet2/41 Ethernet2/42
Ethernet2/43 Ethernet2/44 Ethernet2/45
Ethernet2/46 Ethernet2/47 Ethernet2/48
N7K_01# configure t
Enter configuration commands, one per line. End with CNTL/Z.
N7K_01(config)# vdc B
N7K_01(config-vdc)# interface ethernet 2/1
Error: Invalid range: Ethernet2/1
N7K_01(config)# ^C
N7K_01(config)#
how do slove problem?
Tran Van Loi
hi all
who can help me?
Tran Van Loi
Hi @skapadi , can you help me solove prolem??
Thank you
