How to configure link between 2921 and SM-D-ES3G-48-P EtherSwitch Service Module
ogor
hi,
I can't do that like the procedure given by Cisco.
http://www.cisco.com/en/US/partner/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#wp1942894
Cisco Procedure :
interface gi10/0
ip address x.x.x.x x.x.x.x
service-module gigabitethernet 1/0 session
My result :
R2921-8CPITR-1(config)#int gi 1/1
R2921-8CPITR-1(config-if)#ip address 2.2.2.2 255.255.255.192
% IP addresses may not be configured on L2 links.
R2921-8CPITR-1(config)#interface gigabitEthernet 1/1.1 ?
% Unrecognized command
R2921-8CPITR-1(config)#interface gigabitEthernet 1/1 ?
  <cr>
the session is not possible also ?
R2921-8CPITR-1#service-module gigabitEthernet 1/1 sess
% Invalid input detected at '^' marker.
R2921-8CPITR-1#
The routeur said that it's not a L3 port, so how to configure it to allow communication between the 2921 and the card ?
Is there a bug with that version I'm in 15.1(4)M4 ????
R2921-8CPITR-1#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
R2921-8CPITR-1 uptime is 19 hours, 21 minutes
System restarted at 16:00:45 GAB Fri Sep 14 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL1618119E
6 Gigabit Ethernet interfaces
2 terminal lines
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL1618119E
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
R2921-8CPITR-1#
Reza Sharifi
What is the output of "sh ip int bri" on the router?
Is interface gi1/0 in up and up mode?
Same issue here.
I just waited a few minutes and the interface went down and back up, this time it was a L3 interface.
My guess is that it was booting the switch module IOS, and it detected it until it was fully booted:
Apr 11 05:26:52.091: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Apr 11 05:26:52.091: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
Apr 11 05:26:52.091: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Apr 11 05:26:52.091: %LINK-3-UPDOWN: Interface GigabitEthernet1/0, changed state to up
Apr 11 05:26:52.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Apr 11 05:26:53.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
Apr 11 05:26:53.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
Apr 11 05:26:53.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
Apr 11 05:26:53.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0, changed state to up
Apr 11 05:27:46.895: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
Apr 11 05:27:46.895: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
Apr 11 05:27:46.947: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
Apr 11 05:27:47.031: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
Apr 11 05:27:47.083: %LINK-5-CHANGED: Interface GigabitEthernet1/0, changed state to administratively down
Apr 11 05:27:47.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
Apr 11 05:27:48.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0, changed state to down
Apr 11 05:27:49.283: %IP-5-WEBINST_KILL: Terminating DNS process
Apr 11 05:27:52.499: %LINK-3-UPDOWN: Interface GigabitEthernet1/1, changed state to up
Apr 11 05:27:53.087: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Compiled Tue 04-Sep-12 16:50 by prod_rel_team
Apr 11 05:27:53.255: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Apr 11 05:27:53.499: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1, changed state to up
Apr 11 05:28:21.435: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Apr 11 05:29:22.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1, changed state to down
Apr 11 05:29:22.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Router>en
Router#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES unset  administratively down down
GigabitEthernet0/0         unassigned      YES unset  administratively down down
GigabitEthernet0/1         unassigned      YES unset  administratively down down
GigabitEthernet0/2         unassigned      YES unset  administratively down down
GigabitEthernet1/0         unassigned      YES unset  administratively down down
GigabitEthernet1/1         unassigned      YES unset  up                    down
Vlan1                      unassigned      YES unset  down                  down
Router#
Apr 11 05:29:46.106: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1, changed state to upconf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int g1/0
Router(config-if)#ip add 1.1.1.1 255.255.255.0
Router(config-if)#no shut
Router(config-if)#
Apr 11 05:30:09.046: %LINK-3-UPDOWN: Interface GigabitEthernet1/0, changed state to up
Apr 11 05:30:10.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0, changed state to up
Router(config-if)#end
Manuspillai01
Hi ,
try the below config..i think it should work as i have tried it in my new cisco2921 router and SM-ES3-16-P card installed in the SM slot
router(config)#interface GigabitEthernet1/0
description -CONNECTION FROM ROUTER TO SM CARD-
ip address 192.168.0.1 255.255.255.252
#end
router#service-module gigabitethernet 1/0 session
it will show trying to connect..enter once to get into the SM card config terminal as shown below
switch>en
switch#config t
switch(config)#int gigabitethernet 1/0/18
ip add 192.168.0.2 255.255.255.252
no shut
