how to configure magement IP on 2960 switch
aniefiok essien
please can anyone help me with syntax config for management IP on 2960 switch which has its gigabit/01 port receiving radio access to share resource to a fiber converter on g/02 while the f/1 -- f/24 are meant to vlan for access to other users.
the users are meant to be use to manage the other remote fiber nodes that are on different 2960 switches.
drherring
Once in global config mode (configure terminal)
Interface Vlan1
ip address <ip address> <subnet mask>
Hope this helps!
Thanks will try it
Essien Aniefiok
Kapstone solutions Nig. ltd.
080892119994, 08057827485
Dennis,
Thanks will try it out and also what syntax so I use to change an already set IP address on same switch
Essien Aniefiok
In global config mode:
Interface Vlan1
no ip address <ip address> <subnet mask>
Hope this helps.
- Bhasker
