How to Configure NTP server on Cisco 4500x switch Possible or not??
Zohaib Khan
Hi all,
i want to configure an NTP server for my LAN on my cisco 4500x switch and all my LAN switch and other devices to NTP client is it possible and how??
Drew Browning
You can do this a few different ways.
Try looking at this
Leo Laohoo
Your 4500X can synchronize to a valid timesource and any clients can synchronize to your 4500X.
The main underlying question is your 4500X should have access to two or more valid NTP timesource.
You have multiple options to synchronize to a valid timesource:
1.  Go to NTP Pool Servers list and choose from the general pool or specify the nearest location where you are.
2.  Get a full NTP server.  Note, full NTP server is not dependent on internet connection.  Full NTP server has a built-in GPS receiver and an antenna.
WARNING:  Avoid using the command "NTP master".
Leo can u explain this warning??
It is not a wise idea to make your appliance an "NTP master".  Just make your NTP synchronize with a valid time source and you'll be fine.
