port going into blocking mode because sees its own BPDU
greycrx87
6509 trunks with Aruba 3600 controller that connects (VPN IPSec) to around 110 Aruba APs, these are usually home offices, some of which are having switches connected to the Aruba ports for switchport expension.
There is only one uplink to the controller and no alterneate path what so ever. The port is going into "Back BLK" because of seeings its own BPDU. So after working with Cisco TAC, we deterimed that there has to be a physical loop somewhere behind the 3600 controller ( hub device) or potential software bug that cauases the BPDU to turn around.
Now TAC has recommened to implement bpdu filter on the uplink trunk to help determine the source of the loop and look at MAC flaps/notification. The uplink trunk has 3 VLANs and only 956 is being affected. The senior mgmt is affraid that implementing the bpdu filter will cause more harm.
We dont't have access to all RAPs because of how big the network is, so the only place where we do configuration changes is Cisco. Aruba saying there is nothing with their software that could be casuing this.
Any advice here is highly appriciated
Attaching a hand written network diagram
VLAN0956
  Spanning tree enabled protocol rstp
  Root ID    Priority    8192
             Address     x.x.x.x x.x.x.x x.x.x.x
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    8192
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Gi2/27              Back BLK 4         128.155  P2p
interface GigabitEthernet2/27
switchport
switchport trunk native vlan 955
switchport trunk allowed vlan 954-956
switchport mode trunk
yusuf habibi
Hi, i think your problem with aruba, you can try with disable DTP on trunk port "switchport nonegotiate"
and make sure uplink interface from both side have 1 connection with vlan 956
Habibi
Regards, Habibi
Leo Laohoo
you can try with disable bpdu on trunk port "switchport nonegotiate"
To disable BPDU Guard, the interface-level command is "spanning-tree bpduguard disable".
Hi leo, sorry i means disable DTP service on trunk port...thx for correct
Habibi
Regards, Habibi
Leo Laohoo
Let me get this straight ... You have an uplink port configured as a trunk but you also enabled BPDU Guard?
It sure defies logiec.  My recommendation is to disable BPDU Guard on this trunk port.
