How to configure OpenFlow on Catalyst 2960X-24TS-L Switch
av_CPP
I am trying to configure/enable OpenFlow capability on the Catalyst 2960X-24TS-L switch. I am following this configuration guide: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_7_e/b_1527e_consolidated_2960x_cg/openflow.html
I am able to successfully complete Steps 1 and 2. However, the command outlined in Step 3 does not appear to be a valid command. When I enter feature openflow, nothing occurs, and I am unable to proceed further.
Can anyone help guide me on how to configure OpenFlow on this switch?
Thank you
Deepak Kumar
What is the firmware version? A minimum firmware version 15.2(5)E is required for this command.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
