How to configure port mirroring in L2 switch..
vinothlb1
Pls provide many links for port mirroring and also whether all the IOS supports port mirroring..
6 Replies 6
andrew.prince
Level 10
Level 10
what is your switch platform?
Catalyst 2900 series xl
on the port you have you sniffing device connected to:-
int fa 0/x
port monitor fastEthernet 0/x
HTH>
what command to check whether port mirroring working or not?
Firstly - you shhould be receving alot of traffic on your port niffing software - a clear indication is receving frames destined for the MAC address on the port your are monitoring.
Secondly issue the command "show port monitor fa x/x" at the command line and it will output what ports are being monitored and which ports the info is being sent to.
HTH>
brandon.bennett
The configuration is specific to the switching platform you are using.
Cisco calls it SPAN (Switched Port ANalyzer) and here is link that should cover every switching and describing how to it it up
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
