How to Configure switch to switch PPPoE? Attached network diagram..
rankcybernet
How to Configure switch to switch PPPoE? Attached network diagram..Mikt to Cisco Network 2.jpg
5 Replies 5
Hiko
hi All vlan create in all switch and you must configure trunk port between all switches and which one connect to AP to switch this port must me access port
Deepak Kumar
You didn't share switch model number so some command may differ. Here I am sharing a basic configuration with you.
Cisco Switch 1 configuration:
Interface range gig 1/0/3-4
Description <type any description>
Switchport mode trunk
switchport  trunk allowed vlan add all
switchport trunk native vlan <>   --> If any
no shut
Cisco Switch 2 configuration:
Interface range gig 1/0/2-4
no shut
If a command "Switchport mode trunk" will showing error then first run a command "Switchport trunk encapsulation dot1q"
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Switch model : SF300-24
Sorry bro its not working.
here i attached conf of switch 1 & 2 configure screen shoot
Switch 1:
switch1 config screen shoot 1switch1 config screen shoot 1switch1 config screen shoot 2switch1 config screen shoot 2
switch1 config screen shoot 3switch1 config screen shoot 3
Switch 2 Cong=fig Screen shoot
switch2 config screen shoot 1switch2 config screen shoot 1
switch2 config screen shoot 2switch2 config screen shoot 2
switch2 config screen shoot 3switch2 config screen shoot 3
sivam siva
Level 3
Level 3
Disable the switch port by executing the" no switch port " command and build the routing then configure  PPPOE between two switches.use the below link to know about PPPOE configuration.
https://www.youtube.com/watch?v=YCyvaAn6u1U
