How to configure tx-queue on Cat9300
Hi all,
I am currently converting QoS config from a Cat4500 to a Cat9300. How do I set the tx-queue specific configuration on the 9300?
On the 4500 under an interface I can configure it like so:
interface GigabitEthernet1/1
 switchport mode trunk
 qos trust cos
 auto qos voip trust
 tx-queue 3
   bandwidth percent 10
   priority high
   shape percent 10
end
I don't think there is a one-to-one translation for the tx-queue command. The closest you get is probably the 'queue-buffers ratio 10' command under the policy map and class.
Hi Georg,
Thank you for your reply. I will try and amend the policy map to replicate the config.
