3850 Stack Member Firmware Downgrade
avilt
Level 3
Level 3
I need to downgrade OS from  16.03.07 to 3.06.09 for some testing.
As per the downgrade procedure I need to execute the following command on the switch but it’s not available. Please advise.
SW#switch all
% Invalid input detected at '^' marker.
SW#switch ?
  <1-9>  Switch Number
the "switch all" referred to is not a command on its own
it is an option to the install command s
Switch# request platform software package clean switch all file flash:
Switch# request platform software package install switch all file flash:cat3k_caa-universalk9.SPA.03.07.02.E.152-3.E2.bin new auto-copy
balaji.bandi
That command switch all option to clean up all switches in your stack.
you can use below document to downgrade.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/release_notes/ol-16-3-3850.html#pgfId-1195184
hope you have backup config and doing this maintenance window (in production environment).
BB
