How to configure vlan comunicating
ramakanth
I have two vlan 42 and vlan 52
Vlan 42 10.10.42.0/24
vlan 56 10.10.56.0/24
i want to communciate vlan 56 should communicate vlan 42
i do not want to communicate vlan 42 should not communicate vlan 56
9 Replies 9
Mark Malone
You can use access list under the interface vlans to restrict or allow them speak to each other , something like below should work , base it in and out on each interface and test it
Int vlan 52
ip access-group TEST in
ip access-group TEST out
Int vlan 42
ip access-list extended TEST
permit ip 10.10.56.0 0.0.0.255 any
permit ip any 10.10.56.0 0.0.0.255
deny ip 10.10.42.0 0.0.0.255 10.10.56.0 0.0.0.255
permit ip 10.10.42.0 0.0.0.255 any
permit ip any any
I have configured buthave configured but still issue
Vlan 42 is communicating with vlan 56
but i want vlan 56 should not communicate vlan 42
brselzer
As Mark mentioned, you can write an ACL to block traffic in one direction. However, if you have a server in one vlan and users in another, putting an ACL is not going to work as the communication needs to be bi-directional even if you only want the users to be able to initiate the connection. If this is what you are trying to achieve, you might need to look into a statefull firewall or maybe configuring NAT to mask the clients on the inside.
Hope that helps!
-Bradley Selzer
CCIE# 60833
Actually traffic does not need to be bi-directional, but it's very unusual if it's not. For example, TCP won't work unless it's bi-directional, but UDP might.
If you want to allow VLAN 42 to TCP respond to VLAN 56, you can use an ACL ACE using the "established" option.
I have configured but still issue
Hello
Then you need to allow established tcp traffic to be able return into vlan 42, unfortunately this will not work for UDP as the protocol is connectionless so udp can be allowed or denied
vlan 42 =192.168.42.0/24
vlan 56 =192.168.56.0/24
Ip access-list extended TST
Permit tcp 192.168.56.0 0.0.0.255 any established
deny tcp 192.168.56.0 0.0.0.255 any
permit ip any any
int vlan 42
Ip access-group TST out
Kind Regards
Paul
The configuration which you have given me was not working
I will give you example
i have created two vlan vlan 42 and vlan 56
vlan 42 10.10.42.0
vlan 56 10.10.56.0
I have created 2 ACL
ip access-list extended comm_vlan
permit ip any any
ip access-list extended vcomm_vlan2
permit tcp 10.10.56.0 0.0.0.255 any established
deny tcp 10.10.56.0 0.0.0.255 any
permit ip any any
and
interface Vlan42
ip address 10.10.42.1 255.255.255.0
ip access-group comm_vlan in
ip access-group vcomm_vlan2 out
interface Vlan56
ip address 10.10.56.1 255.255.255.0
but both vlans are communicating
but i want only vlan 42 should communicate eith vlan 56
vlan 56 shoud not communicate with vlan 42
Hello
Remove the following and try again:
interface Vlan42
no ip access-group comm_vlan in
interface Vlan56
Kind Regards
Paul
I have done but same issue occurs
