How to configure VLAN with 3 cisco swicthes, core switch and ASA5510
petermikula
I have a big  network that requires separation on 3 switches to be used for another  group of users in one building to access internet but be completely  separated from the internal network. There three switchers in the  building and some of the ports on these switches  need to have their own  VLANs that the traffic will go over thru the core switch to ASA and out  to the internet. I'm looking for general design idea how to approach  this project. I have attached the core switch config. The ASA firewall  has one unused port that I will connect to the core switch, I would like the traffic that would go over the new VLAN, to be passed thru the core switch to that unused port on the ASA
------------------ show version ------------------
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 24-Jan-07 14:38 by pwade
Image text-base: 0x10000000, data-base: 0x114EECF0
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 4
Core-Switch uptime is 25 weeks, 5 days, 23 hours, 28 minutes
System restarted at 10:56:59 PDT Mon Oct 18 2010
System image file is "bootflash:"
cisco WS-C4503 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX11050KFJ
MPC8245 CPU at 267Mhz, Supervisor II+TS
Last reset from PowerUp
8 Virtual Ethernet interfaces
38 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
------------------ show running-config ------------------
Building configuration...
Current configuration : 7571 bytes
! Last configuration change at 11:24:09 PDT Mon Oct 25 2010 by admin
! NVRAM config last updated at 10:10:04 PDT Sun Apr 17 2011 by admin
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
hostname Core-Switch
boot-start-marker
boot-end-marker
username monitor password 7 <removed>
username admin privilege 15 password 7 <removed>
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec default local
aaa authorization commands 1 default local
aaa authorization commands 15 default local
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
ip subnet-zero
ip domain-name xxx
no file verify auto
spanning-tree mode pvst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
power redundancy-mode redundant
vlan internal allocation policy ascending
interface FastEthernet1
 no ip address
 shutdown
 speed auto
 duplex auto
interface GigabitEthernet1/1
 description EquiLogic1
 switchport access vlan 201
 switchport mode access
 switchport voice vlan 200
interface GigabitEthernet1/2
 description device1
 switchport voice vlan 201
 duplex full
interface GigabitEthernet1/3
 description device1
 speed 1000
interface GigabitEthernet1/4
 description device3
 speed 1000
interface GigabitEthernet1/5
interface GigabitEthernet1/6
 description device4
 speed 1000
interface GigabitEthernet1/7
 description WirelessController
 speed 100
interface GigabitEthernet1/8
 description APC UPS
interface GigabitEthernet1/9
 description dev5
interface GigabitEthernet1/10
 description EquiLogic2
interface GigabitEthernet1/11
 speed 100
 duplex full
interface GigabitEthernet1/12
 description VOICEMAIL
interface GigabitEthernet1/13
 description SERVERROOM
 switchport trunk native vlan 201
interface GigabitEthernet1/14
 description Corporate Voice-Data Port
interface GigabitEthernet1/15
interface GigabitEthernet1/16
 description dev7
interface GigabitEthernet1/17
 description dev8
interface GigabitEthernet1/18
interface GigabitEthernet1/19
 description B&G Switch Uplink
 switchport mode trunk
interface GigabitEthernet1/20
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
 description Fiber to buikding 5
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
 description Library HP 6108
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
interface GigabitEthernet2/18
 description vmHost02
interface Vlan1
 no ip address
interface Vlan200
 description device9
 ip address 10.2.0.20 255.255.0.0
interface Vlan201
 description dev10
 ip address 10.0.0.20 255.255.0.0
interface Vlan300
 description dev11
 ip address 10.78.0.20 255.255.255.0
 ip rip send version 1 2
 ip rip receive version 1 2
interface Vlan400
 description dev12
 ip address 10.4.0.20 255.255.0.0
interface Vlan500
 description dev13
 ip address 10.5.0.20 255.255.0.0
interface Vlan600
 description dev14
 ip address 10.6.0.20 255.255.0.0
interface Vlan700
 description dev15
 ip address 10.7.0.20 255.255.0.0
router rip
 version 2
 network 0.0.0.0
 no auto-summary
ip default-gateway 10.0.0.25
ip route 0.0.0.0 0.0.0.0 10.0.0.25
ip http server
ip http authentication local
ip http max-connections 16
ip http timeout-policy idle 180 life 180 requests 25
access-list 10 permit 10.0.0.9
access-list 10 permit any
access-list 11 permit 10.0.0.16
access-list 11 permit any
access-list 100 permit ip any any
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server location "MDF"
snmp-server contact Site Admin
snmp-server chassis-id "Core-Switch"
radius-server source-ports 1645-1646
alias exec crs copy run start
alias exec sib show ip int brie
alias exec shr show run
alias exec c config t
line con 0
 exec-timeout 15 0
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 transport input telnet
 transport output telnet
line vty 5 15
ntp clock-period 17179368
ntp access-group peer 10
ntp access-group serve-only 11
ntp master 6
ntp server 10.0.0.16 prefer
end
Roman Rodichev
Level 7
Level 7
A simple way to do it is to extend your isolated VLAN via layer 2 all the way to he ASA and deliver these VLANs over a 802.1q trunk to the unused port on the ASA. You can then configure firewall rules to prevent communication between the "isolated" interfaces and the rest of the network, allowing access only to the Internet.
If you can't extend those VLANs layer 2 and need to route through somewhere before getting to the ASA, then you will need to use VRFs on that router.
If you want to go even further, you can configure virtual contexts on the ASA to create complete isolation.
Your three methods for isolation are:
Layer 2 - VLANs
Layer 3 - VRFs
Firewall - Virtual Contexts
