How to connect a Cat 3550 PWR with Cat 2948G
maddox-mp
Beginner
Beginner
Hi, I want to connect a 2948G Switch with 3550 PoE switch together.
-2948G Switch (ver. 120-7.wx5.15a.bin)
3 Vlans
-3550 PWR PoE (122-25.SEE2)
3 Vlans
connected to internet
Requirement:
I want servers with diff. subnet connected on both switches to ping each other and to access internet too.
Pls. suggest a method with commands.
andrew.prince
Advocate
Advocate
You need to configure VTP for VLAN management between the switches, you need a trunk between the 2 switches. You need to configure layer 3 interfaces on the 3550 to handle the interVLAN IP traffic or pass this up to a router with ethernet sub-interfaces. You need to configure a default gateway for your internet traffic.
HTH.
HTH,
Unfortunately CAT 2948G cannot do trunking , only bridging , L3 (using BVI Interfaces)and also does encap dot1q, and Vlan's.
See the following link to find out how limited is : http://www.cisco.com/en/US/products/hw/switches/ps606/products_configuration_guide_chapter09186a008007e6ce.html
Knowing all the above how can we configure the connectivity between CAT 2948G and CAT 3550 PWR (knowing that is already connected to Internet) . Only servers/workstation connected to 2948G cannot connect to Internet.
Thanks for your help in advance.
Maddox
Recognize Your Peers
