how to connect to internet ?
kaustubhchavan
how do i connect to internet using router & i have an public ip purchase from ISP?
9 Replies 9
passioncas
Configure the Public IP address on the interface where the ISP link is terminated and do PAT(port Address Translation )for the internal clients.Please let me know the exact requirement and will help you
i have 20 users their private as follows :
192.168.2.2/24
192.168.2.22/24
My static ip is 210.242......
so how will i do plz send me configuration?
where will i terminate cable coming from broadband modem ?
Hi ,
The broadand modem itself act as a Router ,no need to put the Router.
Rahul
but if i want to use my cisco router then ?
Actually, if you have only a modem, you'll need a router to route traffic out. Your modem would connect to the WAN port on your router, and then your ethernet port would connect to the LAN side. You would configure NAT on the router so all of your hosts would be able to get on the internet.
If you have a broadband router, you'll need to have your ISP help you configuring their router that they sent you in bridging mode. Bridging allows all of the public traffic through their device and allows your Cisco router to handle all of it.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi kausthub
chk out the floowing confing and change it according to ur ip setup
interface ethernet x/x
ip address 192.168.2.x 255.255.255.0
ip nat inside
interface serial x/x
ip address 210.242.x.x 255.255.255.x
ip nat outside
ip nat pool ovrld 192.168.2.2 192.168.2.22 prefix 24
ip nat inside source list 7 pool ovrld overload
access-list 7 permit 192.168.2.0 0.0.0.31
"Pls rate if it helps"
Ullas
It is possible to connect a Router..Connect the Broadband modem to the router through ethernet port..then Lan will be connected to the router..Do a default route on the Router pointing towards the Broadband modem..
to connect broadband modem it require adsl port on router & lan segment on fastethernet if i am right ?
Dear kaustubh,
go through following link.http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Hope to help
suryakant
