How to connect two core switch C4510R+E SUP 7-E
Ciscoman2851
I have 2 units core swicth C4510R+E SUP7-E  need to connect together for redundant purpose , i bought also 4X 10GE uplinks for each core switches .
May i know how i shall connect both core switches together using my spec Catalyst 4500 E-Series 12-Port 10GbE (SFP+) ?
Thank you
6 Replies 6
Leo Laohoo
The best method to connect two switches is using VSS.  Unfortunately, VSS for the Sup7E is "not yet" available.  There are rumours about something coming out before the end of December 2012.  Otherwise, the IOS that will support VSS on a Sup7E might come out on March 2013.
For the time being, you can settle with HSRP/VRRP.
What shall i do on the physical connection to provide best redundancy?
How about of physical connection, how should i connect?
Below is the graphic of the C4510R+E
One 10 Gbps link (each) on the supervisor card going to the other.
Abzal
Level 7
Level 7
I think it's better to configure between them EtherChannel bundle and configure it as a trunk.
Abzal
Best regards,
Abzal
Ciscoman2851
How about refer to below? Shall i connect both core switch parallel or cross connect?
Ciscoman2851
Hi Anyone know how to connect?
