how to control bandwidth at individual interface in cisco 4948?
winnthu
I have cisco 4948 switch and I want to control in and out bandwidth of individual interface in Cisco 4948. I try to search cisco site and I am out of luck. I tried with class-map configuration and it can only control to only one interface. Once I add another interface the configure bandwidth does not work. Here is my config
class-map match-all Client-pc
match any
class-map match-all Any-traffic
match any
policy-map 2Mb
class Any-traffic
police 2 mbps 256 kbyte conform-action transmit exceed-action drop
policy-map 1Mb
class Any-traffic
police 1 mbps 128 kbyte conform-action transmit exceed-action drop
policy-map 1Mb_client
class Client-pc
police 1.5 mbps 32 kbyte conform-action transmit exceed-action drop
policy-map 2Mb_client
class Client-pc
police 2 mbps 32 kbyte conform-action transmit exceed-action drop
interface GigabitEthernet1/4
description server
switchport access vlan 2
switchport mode access
duplex full
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input 1Mb
service-policy output 2Mb
end
Collin Clark
Here's a working config (note this is for a 3550 though).
class-map match-all c_Outbound
match access-group 101
class-map match-all c_MarkDSCP
match access-group 102
class-map match-all c_Inbound
match ip dscp 60
policy-map p_Outbound
class c_Outbound
police 1528000 8000 exceed-action drop
policy-map p_MarkDSCP
class c_MarkDSCP
set dscp 60
policy-map p_Inbound
class c_Inbound
interface FastEthernet0/11
switchport access vlan 110
service-policy input p_MarkDSCP
interface FastEthernet0/12
switchport access vlan 12
service-policy input p_Outbound
service-policy output p_Inbound
access-list 101 permit ip host 112.81.61.79 any
access-list 102 permit ip any host 112.81.61.79
7 Replies 7
Collin Clark
match ip dscp 60
class c_Outbound
class c_MarkDSCP
set dscp 60
class c_Inbound
Thanks for the prompt reply collin. I will try with access-list and will post the result here.
Cheers
I tried with your solution. It can control, but I found that inbound and outbound bandwidth rate with police does not reflect the actual bandwidth going in and out. Is that normal?
Thanks in advance for your help.
No, it should police the traffic. I don't have a whole lot of experience on the 4948's, their queuing is probably different.
Thanks Collin, after I increase the burst rate it reflects the in and out that I control.
Great, what did you set it too (so I can change my doc)?
Hi Collin,
I raise the burst rate to 512KB. Here is my policy setting.
policy-map srv_in
class srv_in
police 4096000 bps 512000 byte conform-action transmit exceed-action drop
policy-map srv_out
class c_in
police 2048000 bps 512000 byte conform-action transmit exceed-action drop
Looks like burst rate setting speaks a lot. I tried with Passmark advance network test. If I use fixed data block size with the above setting I got the bandwidth that I set. But not exact though. Very close. If I use variable data size, the bandwidth result get higher.
