How to copy image from USB to Nexus 7000
adeelmir mir
I am trying to copy the IOS image saved in USB drive to Nexus 7010 , anyone familiar with the process please? Do I need to format my USB to a specific file system first?
Mark Malone
Yes needs to be FAT usb you can format it , FAT32 format works for me on my nx-os , then copy usb....... bootflash: to transfer the image
when the usb is recognized it will appear in logs and also in dir ? you will see the usb depending which slot you connected it as 7ks have multiple
Mark Malone
Leo Laohoo
As long as the USB stick is supported, it'll work.
If you have a Nexus 7K, then Cisco would include a 2 Gb USB stick free with every purchase of a Sup card.
A Samsung Bar also works beautifully (16 Gb).
Samsung Bar 16 GbSamsung Bar 16 Gb
i have usb formatted fat 32 but N7K cannot see the files inside the usb.
i tried with 3 USBs.
If you stick the USB flash drive in, what does it say in the logs?
