Cant access LAN with OSPF routing
baba_yaga
I have configured this ospf topology like this below with goals is every node can access each other.
OSPF.PNGPKT file : https://drive.google.com/open?id=1c6g0tgbqI9S2FKl9JREWGPjnKmXWRWmy
Problem : From R1_area1 cant connect to local area network(server) and gateway from each router in OSPF area 0
Do I miss configuration?
Some verification of my configuration this below
Spoiler
R1_Area1#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
2.2.2.2           0   FULL/  -        00:00:36    12.1.1.2        Serial0/3/0
R1_Area1#sh ip ospf da
R1_Area1#sh ip ospf database
            OSPF Router with ID (1.1.1.1) (Process ID 1)
                Router Link States (Area 1)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.1.1.1         1.1.1.1         1005        0x80000004 0x00136c 3
2.2.2.2         2.2.2.2         1005        0x80000002 0x004a4b 2
                Summary Net Link States (Area 1)
25.1.1.0        2.2.2.2         1011        0x80000001 0x00cf72
R1_Area1#
Spoiler
R2_Area1_2#sh ip ospf neighbor
3.3.3.3           1   2WAY/DROTHER    00:00:36    25.1.1.3        GigabitEthernet0/0
4.4.4.4           1   FULL/BDR        00:00:36    25.1.1.4        GigabitEthernet0/0
5.5.5.5           1   FULL/DR         00:00:36    25.1.1.2        GigabitEthernet0/0
1.1.1.1           0   FULL/  -        00:00:36    12.1.1.1        Serial0/3/0
R2_Area1_2#sh ip os
R2_Area1_2#sh ip ospf da
R2_Area1_2#sh ip ospf database
            OSPF Router with ID (2.2.2.2) (Process ID 1)
                Router Link States (Area 0)
2.2.2.2         2.2.2.2         1035        0x80000003 0x0062a6 1
5.5.5.5         5.5.5.5         1035        0x80000004 0x004dab 2
4.4.4.4         4.4.4.4         1035        0x80000004 0x00ab70 2
3.3.3.3         3.3.3.3         1026        0x80000006 0x00a450 2
                Net Link States (Area 0)
25.1.1.2        5.5.5.5         1026        0x80000003 0x0032b6
                Summary Net Link States (Area 0)
12.1.1.0        2.2.2.2         1070        0x80000001 0x000a02
7.1.1.0         2.2.2.2         1060        0x80000002 0x0065a6
2.2.2.2         2.2.2.2         1071        0x80000002 0x004a4b 2
1.1.1.1         1.1.1.1         1071        0x80000004 0x00136c 3
25.1.1.0        2.2.2.2         1077        0x80000001 0x00cf72
Spoiler
R3_Area0#sh ip ospf neighbor
2.2.2.2           1   2WAY/DROTHER    00:00:39    25.1.1.1        GigabitEthernet0/0
4.4.4.4           1   FULL/BDR        00:00:39    25.1.1.4        GigabitEthernet0/0
5.5.5.5           1   FULL/DR         00:00:39    25.1.1.2        GigabitEthernet0/0
R3_Area0#sh ip os
R3_Area0#sh ip ospf da
R3_Area0#sh ip ospf database
            OSPF Router with ID (3.3.3.3) (Process ID 1)
2.2.2.2         2.2.2.2         1131        0x80000003 0x0062a6 1
4.4.4.4         4.4.4.4         1131        0x80000004 0x00ab70 2
5.5.5.5         5.5.5.5         1131        0x80000004 0x004dab 2
3.3.3.3         3.3.3.3         1122        0x80000006 0x00a450 2
25.1.1.2        5.5.5.5         1122        0x80000003 0x0032b6
12.1.1.0        2.2.2.2         1166        0x80000001 0x000a02
7.1.1.0         2.2.2.2         1156        0x80000002 0x0065a6
Spoiler
R4_area0#sh ip ospf neighbor
2.2.2.2           1   FULL/DROTHER    00:00:37    25.1.1.1        GigabitEthernet0/0
5.5.5.5           1   FULL/DR         00:00:37    25.1.1.2        GigabitEthernet0/0
3.3.3.3           1   FULL/DROTHER    00:00:37    25.1.1.3        GigabitEthernet0/0
R4_area0#sh ip ospf da
R4_area0#sh ip ospf database
            OSPF Router with ID (4.4.4.4) (Process ID 1)
4.4.4.4         4.4.4.4         1175        0x80000004 0x00ab70 2
2.2.2.2         2.2.2.2         1175        0x80000003 0x0062a6 1
5.5.5.5         5.5.5.5         1175        0x80000004 0x004dab 2
3.3.3.3         3.3.3.3         1166        0x80000006 0x00a450 2
25.1.1.2        5.5.5.5         1166        0x80000003 0x0032b6
12.1.1.0        2.2.2.2         1210        0x80000001 0x000a02
7.1.1.0         2.2.2.2         1200        0x80000002 0x0065a6
Spoiler
R5_Area0#sh ip ospf neighbor
2.2.2.2           1   FULL/DROTHER    00:00:33    25.1.1.1        GigabitEthernet0/0
4.4.4.4           1   FULL/BDR        00:00:33    25.1.1.4        GigabitEthernet0/0
3.3.3.3           1   FULL/DROTHER    00:00:33    25.1.1.3        GigabitEthernet0/0
R5_Area0#sh ip ospf da
R5_Area0#sh ip ospf database
            OSPF Router with ID (5.5.5.5) (Process ID 1)
5.5.5.5         5.5.5.5         1212        0x80000004 0x004dab 2
2.2.2.2         2.2.2.2         1211        0x80000003 0x0062a6 1
4.4.4.4         4.4.4.4         1211        0x80000004 0x00ab70 2
3.3.3.3         3.3.3.3         1202        0x80000006 0x00a450 2
25.1.1.2        5.5.5.5         1202        0x80000003 0x0032b6
12.1.1.0        2.2.2.2         1247        0x80000001 0x000a02
7.1.1.0         2.2.2.2         1237        0x80000002 0x0065a6
Thanks in advance
Deepak Kumar
It is looking a Packet tracer bug. I tested the same configuration in my lab and GNS3. it is working fine. I created another lab in Packet tracer and there is the same issue.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Predrag Jovic
Level 3
Level 3
Maybe I am missing something, but it should work as it is written. It looks like Packet tracer bug.
When show ip ospf database is issued there should be entry for each route that is advertised into OSPF, however present are only routes between OSPF neighbors (on other hand all routes from the same area are present in routing table).
Solution to go around ping problem (but not to remove root cause itself) would be to configure on ABR:
ip route 0.0.0.0 0.0.0.0 null0
router ospf 1
  default-information originate
Ok thanks for check my pkt file.
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Ok thanks, I created again on gns3 and it works.
