11-12-2024 11:18 AM
%LINK-3-UPDOWN: Interface GigabitEthernet1/0/9, changed state to down
* %PM-4-ERR_DISABLE: inline-power error detected on Gi1/0/9, putting Gi1/0/9 in err-disable state
* %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/9: PD removed
* %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/9: Power Controller reports mosfet fault
How do I fix this issue? causing the specific port to not function.
11-12-2024 11:20 AM
disable PoE in port
it seem the port is fault
MHM
11-12-2024 01:22 PM
what is the device model ? try reboot the device if that fix the issue,
if not change to different port or if this in contract raise tac case for RMA.
11-12-2024 01:38 PM
Sorry but I dont prefer him try different port' it can device NIC issue and it maybe damage SW port' if he try different SW port he can damage another port.
This my opinion
MHM
11-13-2024 02:29 PM
Do not waste any time with troubleshooting MOSFET failure because it is a known design fault.
Contact Cisco TAC and RMA the switch.
