How to create a port-channel on NK7
rfuentes1111
Hi Team,
I need help on creating a port-channel on a NK7 I'm kind of new on this  I have the following port-channel 105 now i need to create a port-channel 205 can someone  help need to be like the one below.
Thank you,
interface port-channel105
  (SS105005)
  switchport
  switchport mode trunk
  switchport access vlan 10
  switchport trunk native vlan 10
  vpc 105
5 Replies 5
Reza Sharifi
What is the physical interfaces you want to add to Portchannel 205?
example:
config t
Interface e1/10
channel-group 205 mode active
This command will create Portchannel 205 and keep it shut. You can than "no sh" the Portchannel and add the commands you need to add.
I need to add it to et3/1 will this also create the vpc 205 or once the port-channel is create do i need to add it and what is the command.
No, you need to add the vpc command to it
vpc 205
Thank you for helping out also I need to create the port channel on noth core switches correct. and if i make a mistake how can i delete the port-channel.
Hi;
On creating port-channel is the same way as you configured on other Cisco switches. If you want to configure the port in vPC you just need to add vPC command under port-channel to make your server port active/active.
Just like I have a server configured as Active/Active LACP teaming which is connected on port Ethernet3/1 on both Nexus switches:
Configuration: (N7K1/N7K2 both switches)
interface port-channel205
  switchport
  switchport mode access
  switchport access vlan 100
  vpc 205 (Note: always recommend to use same vPC id as port-channel no.)
interface ethernet3/1
  switchport
  channel-group 205 force mode active
Thanks & Best regards;
