how to create a route-map policy that will route a particular subnet
the_crooked_toe
I am having trouble routing one particular subnet. I have no experience in policy-based routing so I'm asking the gurus.
I have 5 cities:
A = 10.110.0.0
B = 10.120.0.0
C = 10.130.0.0
D = 10.140.0.0
E = 10.150.0.0
How do i create some sort of policy-based route that says:
10.A.2.0, 10.B.2.0, 10.C.2.0, 10.D.2.0and 10.E.2.0 to send to one particular router?
At the same time, leave all other routing in place.
Thanks!
Or something else.
How do you stop a particular router from advertising a particular route via EIGRP?
If i could make one router no advertise 10.120.2.0, 10.130.2.0, 10.140.2.0, and 10.150.2.0, from a particular interface, I think it would accomplish this problem also.
I would permit the desired subnets and use a deny at the end of the statement
ip access-list standard PERMIT-SUBNETS-OUT
remark allowed SUBNETS
permit x.x.x.0 0.0.0.255
permit y.y.y.0 0.0.0.255
deny any
router eigrp 10
network z.z.z.0 0.0.0.3
passive-interface default
distribute-list PERMIT-SUBNETS-OUT out int fa0/0.2
no auto-summary
regards,
6 Replies 6
Tshi M
Level 5
Level 5
you could use acl
ip access-list stand 99
permit ip 10.A.2.0 0.0.0.255 any
permit ip 10.B.2.0 0.0.0.255 any
route-map permit_subnets permit 10
match ip address 99
set ip next-hop x.x.x.x
For the EIGRP you could use redistribute ACL.
ok i'm thinking out of the box again.
Forget the first question all together.
How would I be able to stop the router from advertising 10.A.2.0, 10.B.2.0, 10.C.2.0, 10.D.2.0, and 10.E.2.0 from being advertised via EIGRP through one particular interface. While allowing all other routes be advertised through that interface?
use distribute-list on your eigrp process. you create an ACL that permit the desired subnets and denied the others. you then use distribute-list acl out int x
regards
access-list 99 deny 10.120.2.0
access-list 99 deny 10.130.2.0
access-list 99 deny 10.140.2.0
access-list 99 deny 10.150.2.0
access-list 99 permit any
router eigrp 101
distribute-list 99 out Fa0/0.2
would this work?
Is the acl 99 permit any necessary?
deny any
router eigrp 10
no auto-summary
regards,
thanks. this worked. I went the other way by denying the networks, then permitting the rest. Granted, I know with your config there is a lot more control of what is routed, but mine doesn't need all that maintenance.
Thanks again!
