How to create flash: filesystem using bootloader commands
hufa97
Community Member
I have an IE3000 switch and during bootup, it failes to find an IOS so the bootloader prompt appears. a "dir flash:" shows that there is no flash: filesystem. I am having difficulty creating a flash filesystem from bootloader commands.
Can anyone provide suggestions?
Here is the current dir of the switch:
bs[0]
bs1[2]
xmodem[6]
null[7]
Thanks.
Latchum Naidu
See the below link may help you...
http://www.pluscom.ru/cisco_product/cc/td/doc/product/lan/cat3560/12119ea1/3560cr/bootldr.htm
Please rate the helpfull posts.
Naidu.
Latchum Naidu
Naidu.
