How to delete a vlan
dan_track
When I do a show vlan brief, I get a list of vlans. There is one particular vlan I'd like to remove vlan130. How can I delete that vlan?
Thanks in advance
Dan
Amit Singh
Dan,
Which switch is this? If its a new switch like 2960,3560,3750, please go to config mode and delete the vlan. Do the following:
config t
no vlan 130
If its an older switch, you have to delete it using the Vlan data base mode:
Switch# vlan database
Switch(vlan)# no vlan 130
Switch(vlan)# apply
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/command/reference/cli3.html#wp2879531
HTH,Please rate if it does.
-amit singh
mahmoodmkl
Level 7
Level 7
Which series switch u r using.First determine the role of the switch in question i mean weather it is vtp server or vtp client.u cannot delte the vlan from the switch which is acting as a vtp client.
verify how u have created the vlan..ie..there are 2 ways of creating the vlans in vlan database mode or from global mode.if u have created the vlans from vlan database mode then go the vlan datase mode and issue the command no vlan vlanid
if it is in gobal mode then go to the global mode and issue no vlan (vlanname) vlanid.
Mahmood
hoogen_82
Level 4
Level 4
Is this switch a standalone or in a network. If its standalon then go to config mode and the command would be no vlan 130.
It its in a network, and having a vtp status of server, follow the above procedure. If its a client go to the core switch running on server and then delete in the config mode saying no vlan 130.
-Hoogen
Do rate if this helps :)
ankbhasi
Hi Dan,
Go to VLAN DATABASE mode and then issue a command "no vlan " and the apply
Switch#vlan database
Switch(vlan)#no vlan 130
Deleting VLAN 130...
Switch(vlan)#apply
APPLY completed.
Switch(vlan)#exit
Make sure this is not a VTP client switch and if you have a VTP server switch perform this task there and it will be updated on all your VTP clients switches.
Ankur
*Pls rate all helpfull post
