How to delete default ACL on Cisco 2960 switch
IT Support
I.m trying to delete following ACL which came with the factory default settings, but each time i delete the ACL it appear once again.
Switch Ports       Model                           SW Version   SW Image
1- 28                 WS-C2960X-24PS-L   15.2(2)E6      C2960X-UNIVERSALK9-M
Extended IP access list preauth_ipv4_acl (per-user)
10 permit udp any any eq domain
20 permit tcp any any eq domain
30 permit udp any eq bootps any
40 permit udp any any eq bootpc
50 permit udp any eq bootpc any
60 deny ip any any
Seb Rupik
Hi there,
It is an in-built ACL which is applied to a 802.1x enabled switchport in the absence of a DACL being pushed to the switch.
You won't be able to remove it, and it is probably a cosmetic bug that it is visible.
cheers,
Seb.
