How to disable dhcp pool
Can you confirm that if I want to disable temporarily a dhcp pool on a 4500, I need just to shutdown the interface VLAN corresponding to a specific dhcp pool?
ip dhcp pool test
   network 10.X.27.0 255.255.255.0
   default-router 10.15.27.250
   domain-name test
interface Vlan200
ip address 10.15.27.250 255.255.255.0
shutdown
Thanks and regards,
Vin
smehrnia
Level 7
Level 7
Yes, shutting down the vlan interface (SVI) or removing its up address, causes the switch to lose the VLAN's L3 up status, so simply DHCP wont work for that specific vlan.
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
smehrnia
Level 7
Level 7
Soroush.
Hope it Helps!
Soroush.
Ok thanks Soroush!
Leo Laohoo
Command:  no ip dhcp pool test
If you shutdown the interface and you need to manage the appliance using the same VLAN it is not possible.
